#61 (permalink) |
Kill Your Self Krew
xfactorwrx hit redline with the cams and reflash in the video. that he made.
#63 (permalink) | |
![]() ![]() ![]() ![]() ![]() BUILD MY CITY!:http://whocares05050.myminicity.com/sec http://whocares05050.myminicity.com/ind
#66 (permalink) |
I have a K&N Drop in filter. the car is completly 100% stock other than that.
#69 (permalink) |
man, you're making a good amount of power for what you've gotten done. Are you one of those folks w/ factory freaks? i dont remember, there were some other dudes making a lot stock. anyhow, the sniffer (for the a/f readings) may be off which is why its showing the a/f to be rich.
#70 (permalink) | |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
Thanks. I should probably do a dyno run on the car as it is and then see what happens with the cam swap. I am currently working on an X/K intake that will use cowl induction to introduce ram air into the intake. Hopefully, I can pick up a few more ponies along the way. BTW, John Vang at Hopkins Honda says, "Hi"!
#71 (permalink) | |
#73 (permalink) | |||
Pit Stop !?
Do you have the exact same modifications as he does? Sometimes the power of cams are unlocked when complimented by other parts,
![]() If the price difference between regular and premium gas is greater than 20 cents where you fill up you are paying for the profit loss on regular unleaded. Last edited by KidnKorner; 03-10-2008 at 06:10 PM. |
#74 (permalink) | |
its always nice to see new ideas come about as far as intakes. But, yeah, you should do a before and after dyno for the tsx cams. i believe nbilyue has been the only one other than xfactorwrx w/ dynos. w/ more dynos, we all can make a more concise opionion on aftermarket parts.
#75 (permalink) |
They are, but he's talking about an additional one for monitoring purposes only. a wideband AFR gauge for the cabin.
#77 (permalink) |
CLARIFICATIONS:
Doug said... and it only makes sense... because the longer stroke in the K24... 99mm... it gets too much side to side movement.. the oil pumps on those cars can not lubricate the crank over probally 8000 rpm.. If you rev a K24 STOCK BOTTEM END over the recommended 7600 redline by Hondata, you are asking for trouble. Camshafts can be spun to 1000000000000 rpms.. Cams limitations are based on there actual designs.. amount of lift and duration. 06+ TSX CAMS Are larger then JDM TYPE R CAMS intake and exhaust on both lobes. Dyno will be up after the weekend Possibly some time slips. And NBILYUE, I am running CRV tubing and UNMODIFIED MAF, 63mm exhaust, and BCRH, At the same time as the cams, I also installed my IMG and did a TB/Coolant BYPASS. And I have a wideband coming, its on order with the Emanage Ultimate and Vmanage. |
