#27 (permalink) |
Question, for those who have a Weapon-R Defouler and have or plan to use with a Vibrant RH w/HFC. Now that I have both items, I took a look at both items to do some test fitting and I noticed that the delouler's thread or screw portion, is pretty long, so I was wondering if others had screwed the whole thing in or only screw it in to the point that it would not disrupt air flow? Or even cut the defoulers thread so that its well seated and not disrupting air flow?
#28 (permalink) | |
I've brought this up a couple times because mines only threads in about half way before the long portion of the defouler eventually hits the header flange. I just went as far as I could with it, made sure it was parallel to the cat, and tightened the nut on the header and it seems to be pretty sturdy and I wouldn't think it would leak or anything. But I still haven't had time to install my header to test yet. However, Yo Nadz didn't have this problem for some reason with his Weapon R defouler, so I guess it's just the luck of the draw. Is this happening to you? Last edited by tehcodeman; 03-14-2008 at 04:29 PM. |
#29 (permalink) |
I came I saw I conquered!
![]() Join Date: Feb 2007
Nick
anyone tried this w/ the Comptech Header and a test-pipe?
I WIN YOU LOSE Sexiest Taffy FG2 Ever!!!http://www.8thcivic.com/forums/intro...uild-pics.html |
#30 (permalink) |
What? A defouler? It's a defouler, it does what it does. Get an angled one, and you'll be fine. If you're referring to anyone running that setup, then no, I don't think so, and if they have, I haven't heard anything about it. It was a route I was debating about going, but I didn't. You should dyno it before and after to see what you gain from it to help the community.
#32 (permalink) | |
Mr. Cowl Induction
#36 (permalink) | |
Brilliant. Stickied.
![]() search · FAQ · rules · report bad post · learn how to spell Quote:
#38 (permalink) |
Talked to sctuned carlos and they should in places like penn. but here in good ol' boy california nobody knows for sure. I'm wondering how much variation there is bewteen these cats as some people get cels and others do not.
My idea to improve your chances was to wrap up the header to increase the amount of heat being sent to the cat, which I believe is a good thing in that it might make it more efficient at burning gasses and removing heat from the engine bay as well, since I didn't realize you don't even keep the stock heat shield up top when installing the header. Just an idea though not sure if it would make the cat work any better, just know thats why on older cars you always bring the car in warmed up already. |
#39 (permalink) | |
With OBD2 cars all they do is plug a computer into the test port to make sure everythings working. Older cars get the tailpape sniffer and may not pass. |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| k20z3civic |
