Closed Thread
Old 03-04-2008, 04:13 PM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
silverspoon1996's Avatar
JJ
Just got off the phone with Doug from Hondata...
I own a K24 and Brian Crower stage 2 cams. He said because our cars have a MAF sensor... it accepts changes in air flow well.. it will run correct Air fuel ratios ONLY IF YOU USE THE ORIGINAL INTAKE PIPING. He also said Hondata has tested with the TSX cams in our cars, and the 06+ TSX camshafts are a Type R high cam on the intake with the 04 tsx small lobe on the intake.. and the Exhaust has been unchange.. they are LARGER then any other Type-R cam.. Most of us know this..
He hasnt tested any other aftermarket camshafts but said they POSSIBLY could work as long as there is no valve/piston Valve/Valve clearence problems.
also.. our cars with a reflash.. can run a K24 engine with good air fuels.. People say they lean out uptop... but he assured me the Air fuel because we have a MAF isnt the problem.. its the fact that the K24 is not mechanically designed to spin to 8,000+ that it will blow up.. ITS NOT HOW... its WHEN it will.
and With hessitation.. he wouldnt say when.. but did say it will be sometime this year.. hopefully, He assured me they know how desperate people are to get tuning products. Its not that they arent working hard to get the product to us. Its getting a product that is 100% functional to us that is importiant.
So in short..:
1)OUR CARS ARE MEANT TO RUN WITH THE STOCK INTAKE PIPING!!!!!
2)we can use aftermarket cams.. but dont go crazy.
3)K24s work.. and dont run lean.. but dont rev it over what hondata raises the rev limiter to on a K24a2 TSX.
4)It will be here soon.. CHILL OUT PEOPLE..
(I still got Greddy Emanage Ultimate and VManage.. but I will 100% change back to the original intake piping..)
Originally Posted by Hondata View Post
Ok, we know the members this forum are fairly rabid Civic enthusiasts, but some corrections are necessary. (We should know better by now than to try and offer helpful suggestions 8-; )
The comments were made about one particular K24 setup in which intake headers, K24 and emanage were all simultaneously installed.
My suggestion was not to do everything at once. Start with the stock intake and K24. Dyno and measure the air fuel. Then swap to the aftermarket intake. It should measure the same as stock.
The air fuel ratio is determined by the airflow and pipe sizing around the MAF. There is a variation in aftermarket intakes. A well designed intake will keep the stock air fuel ratio and make more power.
A little more information.
We are working on a programmable system for the Civic.
1) It is our TOP priority. We have purchased two Civics for this reason.
2) It will not be called K-Pro
We know from the volume of email and phone calls the level of interest. More calls however, cannot make the development proceed at a faster rate, so please be patient.
silverspoon1996 is offline
Old 03-04-2008, 04:16 PM   #2 (permalink)
What will? KPRO?
llckll is offline
Old 03-04-2008, 04:17 PM   #3 (permalink)
caveman74's Avatar
Kevin
good to know
caveman74 is offline
Old 03-04-2008, 04:21 PM   #4 (permalink)
i-VTEC su madre
BLouIsGod's Avatar
everyone is going back to the stock intake tract lol.
2008 ASM FA5 w/ Navi and Summer Tires
BLouIsGod is online now
Old 03-04-2008, 04:26 PM   #5 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
as usual, x intake ftw.
Good info. I would rep you if I could. Thanks for covering more than just kpro. It's nice to know that I could run tsx cams if needed.
Excalibur is offline
Old 03-04-2008, 04:29 PM   #6 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
Lol. Now people will praise the stock intake.
And bash any aftermarket intake.
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Zeuceone is online now
Old 03-04-2008, 04:34 PM   #7 (permalink)
Enjoi This!™
I<3MyHonda's Avatar
John
sooo this is for the K24, not us with a K20Z3...
I<3MyHonda is offline
Old 03-04-2008, 04:37 PM   #8 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
No, this is for us.
Old 03-04-2008, 04:50 PM   #9 (permalink)
Caper's Avatar
See a trend?
Caper is offline
Old 03-04-2008, 06:00 PM   #10 (permalink)
sheek360's Avatar
so a car with a mass air flow sensor cant possibly run lean? or after the reflash the si wont run lean? im sorry dude but i had a hard time understanding u
sheek360 is offline
Old 03-04-2008, 06:34 PM   #11 (permalink)
ImAuthenticFTW's Avatar
Mike Wagner
the MAF will automatically adjust thr fuel for the amount of air coming in as long as the stock piping is being used. The MAF was calibrated for the stock intake piping so i tcan adjust accordingly when it see's its needed.
ImAuthenticFTW is offline
Old 03-04-2008, 06:58 PM   #12 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
I'm assuming that means no modding of the maf vanes then or what?
Old 03-04-2008, 07:04 PM   #13 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
While the OP's writing style makes it a little difficult to follow, I have gleaned this from what he said:
1. Our MAF sensor, as long as we use stock intake piping, will make adjustments in the Air/Fuel ratio.
2. Running cams like the TSX, will probably be the best cam mod. We need to be careful when running very high lift and duration cams with higher overlap.
3. There is light at the end of the tunnel: K-Pro is coming, sometime this year. Well, miracle of miracles.
OP, thanks for posting this. It is good to hear about what works and doesn't work.
NitrousG35 is offline
Old 03-04-2008, 07:35 PM   #14 (permalink)
thabends's Avatar
So Hondata said to use the stock intake, but their site says you have to have mods to get good results from the reflash. We know exhaust doesnt really do much, so a header is the only thing left. Is Hondata saying that a header is all that is needed to reflash? Unless it's a race header, it won't have much in the way of gains anyway. So we need a race header (illegal), stock intake, and any exhaust (OEM or aftermarket) to get the reflash? Or do we need what they say on the site, at least an intake?
thabends is offline
Old 03-04-2008, 07:38 PM   #15 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
I think the gist of what the OP said was that if we use the stock piping with our MAF sensor, the MAF will compensate for increased air velocity. So, an X factor type intake might be the best at the moment. Couple that with a header and cat-back and you will make the most of a Hondata reflash.
Old 03-04-2008, 07:43 PM   #16 (permalink)
WHOcaREs05050
Whocares05050's Avatar
Good info.
Originally Posted by splew View Post
I'm not liking that sig mike. The under every post reminds me of those people who constantly laugh at themselves. Those people annoy the shit out of me.
Whocares05050 is offline
Old 03-04-2008, 07:46 PM   #17 (permalink)
klk15's Avatar
Kerry
so like always X's intake FTW!!!
klk15 is offline
Old 03-04-2008, 07:50 PM   #18 (permalink)
Post Counts Mean Nothing!
Jalal
Great info!!!
-Jalal
www.TeamXXXRacing.com Northeast Motorsports Club
K-Series Transmission Table - Throw some i into your VTEC diet.
Canon EOS 30D|BG-E2|EF 28mm f/1.8 USM|EF 50mm f/1.8 II|EF 85mm f/1.8 USM|EF-S 10-22mm f/3.5-4.5 USM|Tamron SP AF17-50mm F/2.8 XR LD Aspherical (IF)
MJ23FE is offline
Old 03-04-2008, 07:50 PM   #19 (permalink)
udumkid's Avatar
Rene....
Sounds like they are going back and foward...
From this post:
Taken from Reflash - K20Z3 06/07 Civic Si
You must have a minimum of an intake or header.
It is not designed to work with a stock 06/07 Civic Si and will lose power between 4500rpm and 5600 rpm if installed.
The 06 Civic employs a mass air flow sensor that automatically adjusts the air-fuel ratio for increases in air flow from intakes and race headers. Race headers will not cause this engine to run lean.
udumkid is online now
Old 03-04-2008, 07:56 PM   #20 (permalink)
JEA86's Avatar
Jeremy
i dont know what to believe anymore jeez every week there is a diffrent post. Stock piping FTW, wait injen adds 15 WHP, wait X-INTAKE come on what is it already lol
JEA86 is offline
Closed Thread
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/82534-just-got-off-phone-doug-hondata.html
8th Generation Honda Civic Forum This thread Refback 03-04-2008 11:18 PM
