#1241 (permalink) |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
I think I will do a write up about air temperature, humidity, barometric pressure, air density, air velocity and and air pressure and their effects on the performance of a motor.
Also, we should have a discussion about materials as some materials have a propensity to absorb heat while others reflect heat more. There is actually a lot of science out there about air intakes and what to consider when designing a system or modifying one.
#1243 (permalink) | ||||
![]() Quote:
Oh yeaaa lol Quote:
^ What wouldn't hold up? |
#1246 (permalink) |
Mr. Cowl Induction
Wild VTEC'n Bill
Dan, the hacking up is actually quite minimal. Only a very small piece of the plastic/metal shelf needs to be removed. The wiper cowl needs to have an opening at its base, but if you wanted to return to stock, it is pretty inexpensive to do so as a replacement cowl is cheap.
#1251 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
The problem is, as Matt said, is that I am a little short on real progress.
#1253 (permalink) |
Ha, I quit work a little early yesterday, went out to my car and stared at the engine bay for a while but I almost felt like I had moved backwards realizing how I've had zero actual progress either... now I can't decide between trying to copy the GTI intake design with a battery re-locator and hood seal or try to devise a plan to make the cowl work... it's the metal shelf that has me discouraged with cowl induction.
#1255 (permalink) |
Mr. Cowl Induction
Wild VTEC'n Bill
The metal shelf only needs a small amount to be cut out and would be covered by the plastic shelf and rubber molding if you want to return to stock.
#1256 (permalink) | |
#1257 (permalink) |
Well my concerns are a. I don't have the tools to cut the metal shelf and b. it seems like that shelf works as a trough to have rain water filter down to the sides rather than pouring into the engine bay so whatever space is cut, it would have to pretty much be sealed to the sides of the cowl induction tubing which means that cutting the metal shelf almost has to be the last step so you know exactly how much to cut...
#1258 (permalink) | |
Holy run on sentence Batman! |
#1259 (permalink) | |||
