#1183 (permalink) |
I am kinda curious about something. Does anyone actually know the pressure that is devoloped at speed near the cowl? the volume of the box would be dependant on the amount of air that could *charge it* wouldnt it?
#2000 Last edited by 20strong; 05-12-2008 at 10:07 AM. |
#1184 (permalink) | |
#1185 (permalink) |
We talked about using a leaf blower as a crude simulator for creating a charge. The Sportbike testing methodology linked a page or two back looks like a good way to go about it, but it also doesn't look particularly cheap, unless you have free access to HVHP compressors, a dyno, and instrumentation. Even all of that would be easier to gain access to than a rolling road or dyno equipped wind tunnel.
Keep the airbox and ducting ideas coming. It may take awhile, but once Bill gets his latest design on a dyno, we'll have some numbers to discuss. It'll be interesting to see non-charged output vs. simulated charged output. Even if the simulation isn't known to be realistic, at least those numbers would prove or disprove the basic theory and design. |
#1186 (permalink) |
Just having the intake pulling cold air from outside the engine bay will be a huge power adder to my MAF housiong design. Because the SRI is super prone to pulling the heated air from around the header in warm weather. Now adding the RAM air effect from moving will only add to the power. This design is sweet. it's too bad I won't be needing my intake anymore since I'm bolting on a GReddy kit next month. YAY. Boost is awesome. I will still be following this thread tho just to see how everything turns out.
I'm sorry to hear about your car Bill. I hope you are OK. How bad is the damage? I think you should order up the Type R rear bumper. That thing is Freakin Sweet. Keep the USDM Tail lights but get the JDM rear bumper. After my GReddy kit goes on that's my next mod. |
#1187 (permalink) |
I have been thinking a lot. This has been on my mind for a while, as in way before this thread was started but I've been looking at more and more things now. Here's my rant:
We know the Si engine bay is not only small, has an unusual location for the intake (as does the RSX-S), but is susceptable to heatsoak, and in general a very hot engine bay with almost no where for the heat to go. So we not only need air from colder locations, but we need to block engine heat! Here is what I have come up with: ![]() Above is an 06-08 GTI 2.0T with an aftermarket SRI. Notice that the SRI comes with a heatshield around it and the rubber insulation on the edges which presses against the inside of the hood where the liner is when the hood is closed. This creates a seal and will help keep engine heat away from the filter and the air it sucks in. Next, note the insulation over the piping of the SRI, it helps block engine heat since it surrounds the engine. We might not need this insulation, but definitely a heat shield "wall" is necessary. Here is our main problem: ![]() Above is an Si with an Injen SRI. Notice the area from where the intake starts (throttle body) to where the battery is... there is only one general direction for a Short Ram intake to go, and that is towards the back of the engine bay. We can't go to where the battery is unless we re-route the battery or use the smaller one that sits lower. I might go that direction, depending on price, but right now I'm aiming at a much simpler direction. What might be the best idea thus far(not including ram air) when it comes to cold air and safety and performance is to take the stock box, fit a conical filter inside, and cut a large hole in the bottom of the stock box, towards the battery. I also want to make a heatshield around that area so we will have even cooler air coming in. The heatshield isn't exactly necessary because that is what the stock box would be doing, but it is do-able. I have been playing around with a bunch of ideas in my head and I have come up with this setup: Stock box: top modded to fit the filter of your choice but still remain enclosed; bottom modded to have large cutout underneath. This leaves stock mounting points, as well as colder air. Think about it, heat rises. Much hotter air will be at the top of the engine bay than at the bottom ![]() Now all that is left to do is figure out how the hell to do this all XD. I will probably end up fiberglassing the rest of the enclosure of the top box just to make it all fit well and still reflect heat. |
#1188 (permalink) | |
Chris "DJ Disturbed"
#1190 (permalink) |
Alright, sorry for the double post. I don't exactly know what this tube is for, but it sure as hell is getting cool air in. AND the area that this, the battery, and the ECU surround which is to the inner side of the drivers fender is REALLY cool air. Check it out:
![]() ![]() ![]() This is the area I'm talking about ![]() |
#1192 (permalink) |
Grab her face
![]() ^ You know you want it. My Si For sale: ![]() http://www.8thcivic.com/forums/8th-g...brand-new.html Partout: http://www.8thcivic.com/forums/parti...ibrant-rh.html |
#1195 (permalink) |
Honda found a cool air source, but they also had Dr. Seuss on retainer for intake development. The stock intake is very convoluted, which constricts the air flow to the point where it affects engine output, regardless of air temperature. After using a SRI, it would seem Honda would've done better to have developed a cowl intake system with a significantly smoother, shorter, cooler, pressurized, and dare I say, better sounding intake tract, but then Bill wouldn't have a hobby.
#1197 (permalink) | |
We would need to get basically a bent pipe, not sure of the angle yet, attach the Si intake tube to the MAF housing, then the MAF housing to the tube then the filter =D and then route it behind the battery =D Please post pics! |
#1200 (permalink) | |
As for the battery reloc kit I was looking at the password kit, it's right on their web page |
