#1062 (permalink) |
Resident Si Sedan Hater
I'm still going back and reading through all the pages, I had a question on one thing I noticed:
![]() The lower CRV box looks very airflow-restrictive, as the opening is very small. Do you have plans on opening that up? |
#1063 (permalink) |
I read quite a bit and skipped to the end. Since it's so close to being together, I figured it'd be best to wait for the final presentation before asking NitrousG35 & soxfan143 more questions, especially since I probably missed earlier answers on pages 5 through 52.
#1064 (permalink) |
Chris "DJ Disturbed"
He is not using the bottom inlet for the (main) airflow, he is cutting a new opening that the cowl induction will run into in the top of the intake box
#1065 (permalink) | |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
Remember that I am using the CRV airbox primarily as an enclosure for a cone style filter with a larger surface area than a flat style filter. The airbox cover will be opened up to connect to a duct which in turn will connect to the base of the windshield wiper cowl area. Between the factory cold air inlet and the cowl induction, I should have an enormous amount of air being rammed into the intake.
#1068 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
So, with that information, I may initially try out the airbox with both the cowl induction and the factory cold air. I will just have to experiment. I will also try it with the factory cold air inlet sealed off to see if there are any differences with or without the cold air tube.
#1069 (permalink) |
I suppose it's hard to test something that creates power best when the car is moving. I would expect there to be vacuum at a stop, but once the car gets moving, I imagine the added pressure from the cowl induction would turn the vacuum into a pressure leak. I don't doubt that it would suck a paper at stand-still, but whether it would do the same thing with air blowing into the cowl at 35-60mph is the question. I'm sure you could test this with a fan or blowing shop vacuum though.
If this is the case (and I can't see why it wouldn't be at highway speeds), maybe a rudimentary valve/flapper component for the bottom section would benefit the device. If there's anything I can do to help this along, please PM me. I love tinkering and hate gas mileage. I live in high altitude too (not that I think that matters..)! |
#1071 (permalink) |
Mr. Cowl Induction
Wild VTEC'n Bill
Grizam303, thanks for the insight. Yes, there may be a pressure drop at speed. The only way to really find out is to test it with and without the cold air inlet attached. I am going on my own intuition and knowledge gleaned from car manufacturers. I wish I could be more scientific, but I have zero instrumentation to measure vacuum, pressure and air velocity.
I wish I could design a flapper valve that would do just what you mentioned. I can fabricate things to a certain extent, but designing valves that open and close is not one of them. I am also searching [in vane], for some type of grille/inlet/face plate that is about 3 inches tall and maybe 4-6 inches long with downwards angled louvers. I would like to make a cut in the wiper cowl on the driver's side as this is really the most ideal place to pull air in from. So far, I have come up snake-eyes. If you or anyone else could find something like that for me, I would greatly appreciate it.
#1073 (permalink) |
That'd probably work ok. If variability becomes desirable, then a gas model could be used.
Here's some thoughts on your grillwork. Browse through a local salvage yard until you happen upon the perfect part. Lots of oddball interior HVAC vents might be in that size range. If that doesn't work, a local tinner at a HVAC shop might be able to make something functional for you. A quick, temporary option might be to pull some pantyhose or some other mesh fabric over the cowl inlet. |
#1074 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
#1075 (permalink) | |
i guess making sure the streamer or whatever u decide to use would also be a good idea to ensure it is tied on good to so it isnt sucked into the engineLast edited by c130turboprop; 05-01-2008 at 06:32 PM. |
#1076 (permalink) |
When I think flapper, I think of the dealy on the bottom of the toilet tank.. I'd guess that there might be some plumbing part that could do the job, but I really can't tell the dimensions that you're working with in regards to both the box and clearances for the filter. I doubt it would have to be very complex though, you wouldn't even need it to be air-tight.
However, as far as testing pressure goes, you really only need to know if pressure exists in the box at speed, not so much the magnitude. Again, I can't really see the box, but could you use some kind of cork (this could probably be as simple as a pen cap or something) so that if the box became pressurized, it would pop out? I really wouldn't expect the box not to be pressurized at speed. If the box had a vacuum, that would defeat the premise for cowl induction in its entirety, would it not? |
#1078 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
I got Soxfan's MAF housing on Monday, so I will try and finish things up this weekend. I will first do a trial run with just the modded MAF housing and CRV airbox and share the results for those interested in just that mod. I may not post a DIY or show the final product as I have been attacked pretty viciously by 5 or 6 people both on the forum and in PM's. I am getting sick and tired of the nastiness of some people who feel that it would be best if I left the forum. So, I will PM people like you and Koop and a few others with pics and results and just let the thread die. Some people have accused me of thinking I own the site or that I think I know everything. This has never been my intent and I do things to try and help others out. As a result, I don't post much in the Bolt On Section anymore. Matt, I'll PM you when I get finished. Maybe we can talk on the phone.
#1079 (permalink) |
1337 h4xZ0r
There are really people that PM you constantly with that crap? Are they highly respected members of the community?
