#941 (permalink) | |
Mr. Cowl Induction
![]() Join Date: May 2007
Wild VTEC'n Bill
My only concern is that there is almost no room to run any ducting. All the flexible tubing I bought was for nothing. The best I could do is to use a 4 inch flex coupler that came with the Spectre Industries tubing and just connect it to the wiper cowl and the airbox cover. If the airbox sloped downwards on the top like the Si cover, I could use the flexible tubing I bought and the duct, but now I can't. I also have to figure out a way to make sure no water goes directly onto the air filter. What I would have to do is to attach some rubber moulding at the base of the duct so that water could not get in. I need to first get the windshield wiper cowl off first. Then, I can determine how much material I need to cut away. In a way, the airbox is almost designed to work with cowl induction. I just to need to figure out how to make the right connections.
#942 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
The other issue I still have to address is the pipe inside the airbox for the filter to make sure it will fit snugly. I tried calling you and will do so again later. I think if we can talk on the phone, I can get it all figured out.
#943 (permalink) |
Unless you're planning on enough water getting in there to fill the box, this won't be an issue. The filter will still suck in 100% air even if slightly submerged in water, and even if a little water did get through, no big deal - it's just cleaning the carbon off the pistons. |
#945 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
People don't know that the Ford Mustang was named after the P51. Also, the 1970 Dodge Challenger T/A gave credit to the design of its hood scoop to the P51's lower intake scoop. The P51 is the first plane to actually use laminar flow principles completely on the wing and fuselage. It was way ahead of its time.
#946 (permalink) |
Oh yeah, I've seen the "Top Ten - Fighters" a couple of times also. As a kid that was my favorite aircraft; it's basically the epitome of fighters in WWII.
And thats the reason I love Ford Mustangs. I remember seeing an ad not too long ago from the 60's that showed both the car and the aircraft together. Pure ******* sex. I think the P-51(F-82) was also the first to be conjoined twins. I don't know what the purpose was, but the two connected Mustangs in the Korean War were odd. Looked like a P-38 Lightning. And next in line has to be the F-15E. Last edited by mO 64 StAnG 06; 04-06-2008 at 10:06 PM. |
#947 (permalink) |
Louder than 4 F404-GE-400
Everyone knows the P-38 is the best looking USAF plane of WW2 and the F7F is the best looking USN plane of WW2 (I go to the Reno Air Races every year and the Mustangs dominate so I always root against them even though they do look damn good (did I just say that?)). The best looking plane of WW2 is the ME-262. Currently, the F-22 is the hottest thing on the market. It can out turn, out climb, out accelerate, and out stealth any front line fighter ever built. (I have 2 uncles that work for Lockheed so I'm a little bias) Best looking fighter ever, F-16XL, a delta wing design F-16 that my uncle helped designed.
Totally sucks balls about the CR-V box not fitting. If worse comes to worse, you could just run a tube to the bottom part of the stock Si air box. Some positive pressure is better than no positive pressure at all.
You know what the sun's all about when the light go out. |
#948 (permalink) | |
Blown at last
#949 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
You need to read the classic book "Pursue and Destroy" by Kitt Carson. Carson flew the P39, P47, P38 and P51, but he said by far, the Mustang was the greates of them all. He noted that when behind a P38, those twin booms were a tasty target for German fighters. The Mustang was faster, had longer range, and was a superb gun platform. As for the Tigercat, it came to late too enter the war. Same for the F8F Bearcat. Both were of the superb Grumman engineering and were rugged, fast, and could climb and turn with the best of them. Given time, maybe the F22 will be the all time best fighter, but remember, the planes were judged based on a number of factors and are judged in light of the time they flew. Thus, the ME262, while the ultimate fighter of WWII, had limited production, had problems with the engines and didn't make the impact that say the ME109 or FW190 did. Regarding the CRV airbox, I am not giving up. I will cut the cowl, once I figure how to get it out. Soxfan143 may have to walk me through it on the phone. It will be close, but I think it will still work. I will probably just use a small, ovular piece of firm, but flexible plastic to make the connection.
#950 (permalink) |
I remember when I was a kid, my Dad took me to see the movie Empire of the Sun, and the main character kid was all about the P-51 Mustang. then later in the movie a bunch of them flew real low over a building, and I thought it was a beautiful piece of machinery.
Of course, we all know that the most awesome, beautiful planes ever made were the X-15 ( which really isn't a plane at all, but made a huge impression on me as a child after I saw The Right Stuff, then went to the Air and Space Museum), and the SR-71 Blackbird, one of the baddest planes ever. I thought this was the Cowl Induction Thread, not Everybody's Favorite Planes of All Time ![]() |
#951 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
one else for that matter. I think we can tie in the Mustang and the cowl induction with the principles of laminar flow.... ![]()
#953 (permalink) |
You just have to pop the cowl off. It's just held with clips. The 3 along the base are all you have to take out. The rest of the clips are connected to the under side of the cowl. Just pull man. Over the years, I have lost all three pin clips along the base and on of the 5 clips that are attached to the cowl and it still stays in place. Clips are cheap.
#954 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
Thanks Paul. Soxfan143 told me the same thing. I just didn't want to muscle it out and break something. Now that I know I have removed all the clips I need to, it is just a matter of a tug of war and get that beast out of there.
#958 (permalink) | |
Mr. Cowl Induction
Wild VTEC'n Bill
I could not imagine a Mustang making a pass without that delicious Merlin roaring by. There is something about the sound on takeoff, flybys and startups that is the greatest thing this side of heaven. I am a Mustang fanboy. Have been since 1955, which would have made me 3 years old. ![]()
