#50 (permalink) |
Mr. Cowl Induction
I think this is how things got out of hand for X! First he had an idea, then he made his own setup, tested it and then published the results. Next thing you know, people were clamoring to buy one. The poor guy got flooded with orders and was not set up to mass produce things.
For my part, I would like to work with someone who could help construct an airbox shroud and a duct on the firewall area.
#51 (permalink) |
I will find out. I sent an email to a buddy of mine. I used to work in the aftermarket and still have a few friends involved. The reason I ask becus if we come up with an enclosure there would need to be enough free air space as not to starve the engine or throw a CEL.
#53 (permalink) |
Mr. Cowl Induction
I wonder if the K&N aluminum tube could be sectioned by the MAF sensor area? A silicone tube could be used to connect the throttle body to the MAF sensor and the setup could be shortened a little, therefore giving more room for a Cold Air box.
#54 (permalink) |
The only company I know who could make a piece strong enough to support the weight of the filter and still maintain it's structure would be Samco. I've contacted them a few times, it doesn't look like they have any plans to make something that would work with out maf. GRRRRRRRRRRRRRR
#55 (permalink) |
Kill Your Self Krew
you can buy something from home depo.
#56 (permalink) |
Initially I was only going to reveal my plans once my DIY induction box was completed, but since this thread is here...oh well.
![]() Notes: 1) The sillicone pipes are from scilliconeintakes.com 45deg 2.5", 45deg 3" to 2.5" angle reducer & 3" straight coupler. 2) Airfilter is a K&N unit 6.5" long & has a 6" opening for a Blox intake stack. 3) The MAF holder is from Pep Boys. Features a MAF adapter I made from 1/4" basswood. I added in some fins from 0.5mm alum and epoxied(the white stuff) them in. The leading edge of both fins have been bent a little to direct more airflow into the MAF unit to compensate for the intake, headers & exhaust. I haven't as yet dynoed with a/f measuring, so the current agle of the fins is just a guess. As is I don't have any bogging or surging so I should be fine for now. 4) The throttle response is noticeably better & probably gained a few hp also. |
#57 (permalink) | |
Mr. Cowl Induction
#58 (permalink) |
You should make one that works the same way as the j's racing intake for the s2k.
http://www.boomplustoys.net/images/Js%20Racing/J's%20Racing%20CAI%20for%20S2000%20AP1.jpg That would get you the air that you want and no water. Bingo. Now, to make it work, figure out the rectangular piping you want to use or whatever, line it up, then cut out enough of the black cover that you see at the front of your open hood to fit the piece through it, but not have any gaps. This would scavenge air that is hitting the radiator and create a cool charge. If I had the resources to do this, I would. Just an I idea for you. |
#59 (permalink) | |
#60 (permalink) | |
Mr. Cowl Induction
The issue here is more than just cold air. It is air being rammed in. Ram Air is a great way to enhance performance.
