#22 (permalink) |
I've been working on this too over the last few weeks too and am goingg along the same lines. However, I've found that you don't need to cut the firewall to get cool high pressure air. There is a metal panel just below the plastic wiper cowl, just cut through this piece & you will have access to the vent holes in the cowl.
![]() *EDIT* Bill, I reread your post & now see you already have the same idea as I Last edited by Turbotezza; 02-23-2008 at 10:27 AM. |
#23 (permalink) |
Moderator
It is a great idea, but I'm not sure if the cowl area on our car would be pressurized as much as with older cars due to the design of the parts near the base of the windshield. The plastic cowl sits almost flush with the hood with vents on its front side. The back side of the cowl dips down before coming into contact with the windshield and would be the best place to have air enter however, there are no vents on that side.
You would still get cold air thanks to the vents on the front side of the cowl, but the cowl itself would be more pressurized if there were vents on the back side of the cowl. |
#24 (permalink) | |
If you were in Arizona you could open extra holes at the back, but where I am snow will block those shut.
#27 (permalink) | |
Mr. Cowl Induction
#29 (permalink) | |
#31 (permalink) |
I think this is the right piece just the wrong price.. I'd be willing to bet something like this can be sourced from a race web page much cheaper. I think what your looking for is generally used in brake ducting. Not that dryer hose material more like a molded plastic.
#32 (permalink) |
here are some
NACA Ducts this one could work in our cowl Carbon Fiber Ducting and Sheets - Genesis Technologies 3 IN C/F A-PILLAR DUCT |
#34 (permalink) |
Mr. Cowl Induction
Here are three classic ways that have been used to bring cold, ram air into a motor. All use high pressure zones.
1969 Chevrolet Camaro ZL2 Cowl Induction Hood: ![]() 1968 Hurst Olds with bumper scoops ducted to the air cleaner assembly: ![]() ![]() NHRA Pro Stock car with high mounted hood scoop: ![]() Picture of where high pressure area is on a Civic: ![]()
#35 (permalink) | |
Mr. Cowl Induction
Right. There will need to be a box fashioned that will enclose the filter element. At the end of the box, a circle will be made with a round duct fitting. This would then connect to the duct on the firewall via some tubing used for brakes or cold air packages.
#36 (permalink) | |
Mr. Cowl Induction
Peter, I love you twice. Man, this is great. Obviously you are an F1 guy because they are into the engineering of a car outside the box. Repped +
#39 (permalink) | |
Looks like it's time to buy the K&N. I'm not big on "barking intakes" so the enclosure idea makes alot of sense in terms of performance and stealth factor.... |
