Old 02-25-2008, 07:35 PM   #41 (permalink)
Originally Posted by NitrousG35 View Post
Contact either Robear or SCTuned. Both said they would get on it and try and provide angled defoulers for sale.
thanks again...
geffsi111 is offline   Reply With Quote
Old 02-26-2008, 04:31 PM   #42 (permalink)
02civicsi's Avatar
I am the Juggernaut!!!
I thought the Strutking price was crap but now that they don't sell this anymore for some reason the price went up another $15. WTF is up with that!!! I wouldn't pay $30 for it before & there is no chance in hell that I would pay $45 for it now.
02civicsi is offline   Reply With Quote
Old 02-27-2008, 05:15 PM   #43 (permalink)
Stealthcivic's Avatar
I already my vibrant race header w/ hfc...so maybe I will wait and see if the CEL light comes on........................ or purchase a defouler now??????
Stealthcivic is offline   Reply With Quote
Old 02-27-2008, 08:16 PM   #44 (permalink)
oHsevenGG_Si's Avatar
Well i have the bcrh, cat-delete and I havent thrown a cel yet... granted its not completely on, i have a small small leak cuz i have the wrong gasket on it but still, no cel.
oHsevenGG_Si is offline   Reply With Quote
Old 02-27-2008, 08:31 PM   #45 (permalink)
soxfan143's Avatar
I just installed my DCRH with the DIY defouler setup and it works awesome. I've put on about 35 miles with nothing yet. Knock on wood. I'm pretty sure I will not have any problems. But the difference with the header is unbelieveable. The low end tourque is great and Vtec is awesome.
soxfan143 is offline   Reply With Quote
Old 02-28-2008, 04:32 AM   #46 (permalink)
i should've knocked on wood. just threw a cel as i was driving home jus now. yay me.
Old 02-28-2008, 09:57 AM   #47 (permalink)
NcSi's Avatar
Bryan
went over 10k with no cel with dcrh and diy defouler :) Never had a cel just took the header off over the weekend
oh and here you go bitches Forums -> Mechanical O2 Simulator
NcSi is offline   Reply With Quote
Old 02-28-2008, 10:02 AM   #48 (permalink)
NcSi's Avatar
Bryan
this is for you lazy mofo's
note a defouler is only need for the downstream(where cat normally would be) o2 sensor
Old 03-01-2008, 12:49 PM   #49 (permalink)
jaybirn's Avatar
I have been thinking about this issue quite a bit recently and I have a theory regarding the use of defoulers and Vibrant headers with high-flow cats. From the information I have seen, CEL problems are hit or miss for people that have this header. What this leads me to believe is that the HFC brings the emission levels of the vehicle to a point that is right on the border of throwing a CEL, making it a coin toss as to whether or not a code will be thrown. Given that a defouler is meant to bring the oxygen sensor away from the stream of exhaust, it makes sense to me that in a HFC installation (more specifically with the Vibrant header), that ultimately less deflection of exhaust gases is needed than a catless setup.
So here's my theory for a DIY defouler. Rather than using two of the "Help!" defoulers stacked on each other (causing clearance issues), one defouler that has been drilled out can be used. I haven't seen how long the tip of the oxygen snsor is, but my thought is that the end of the tip would be exposed to the direct stream of exhaust while most of the tip (with 90% of metering capability) would be deflected. It wouldn't make a huge difference, but it might make enough of one for people that are running HFC's and don't want to fork out the money for an angled defouler.
Has anybody thought of or tried this? Any thoughts?
jaybirn is offline   Reply With Quote
Old 03-01-2008, 06:06 PM   #50 (permalink)
soxfan143's Avatar
When I drilled out my defouler for my race header I left the small opening on both my deoulers. I stopped drilling about 1 or 2 mm before the bit went through so there is plenty of room for the O2 sensor to fit but the hole at the base is the original size. I wanted to make SURE I wasn't going to get a CEL by doing this and it worked great.
Your theory is good. You can use just one by doing this. All you have to do is stop drilling right before you're about to get through the other side. I used a bench vise to keep the defouler from moving while I did it.
Old 03-01-2008, 08:14 PM   #51 (permalink)
ezcivic type r's Avatar
any pics of this?
ezcivic type r is offline   Reply With Quote
Old 03-01-2008, 08:21 PM   #52 (permalink)
onefastsi's Avatar
I M SPEED
I got my Weapon R defouler today...mmm..."F" this greenpeace! :)
here are some pics and size info....Cars and rants
onefastsi is offline   Reply With Quote
Old 03-01-2008, 08:27 PM   #53 (permalink)
have you installed it yet? how is the clearance on that? you have the vibrant RH right?
Old 03-01-2008, 08:30 PM   #54 (permalink)
onefastsi's Avatar
I M SPEED
man, do you guys just look at the pictures!!?? :) When I get playboy, I only read the articles...I swear!!
Old 03-01-2008, 08:33 PM   #55 (permalink)
LOL, yeah I only looked at the pics. my bad.
Old 03-01-2008, 08:35 PM   #56 (permalink)
onefastsi's Avatar
I M SPEED
Old 03-01-2008, 09:23 PM   #57 (permalink)
jaybirn's Avatar
Ah man I went through and drilled out my first defouler all the way. When I install my header tomorrow I'm going to try mine and see how it goes (and post up results). If it doesn't work I'll try it other ways (specifically, how you reccomended). Gotta love the $4 pack of defoulers!
Oh, and I put the one I drilled in a vise too
Old 03-01-2008, 09:46 PM   #58 (permalink)
i'm gonna ask a kooky question.
i was lookin at the pics of the diy and it looks like the o2 sensor sits almost flush with the base of the nonfouler which is the reason to drill one out not to bottom out the o2 and break it. has anyone thought of not drilling the nonfouler and just use a couple of washers between the o2 sensor and the nonfouler?
i know that 2 is prolly needed to get the o2 sensor far enough out of the main exhaust stream but i had to ask.
nandro is offline   Reply With Quote
Old 03-01-2008, 09:50 PM   #59 (permalink)
very interesting
Old 03-01-2008, 09:52 PM   #60 (permalink)
BRSi's Avatar
Subscribed. I really don't feel like paying almost $50 for this, so if the cheap ones work
BRSi is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/78145-diy-defouler.html
8th Generation Honda Civic Forum This thread Refback 02-20-2008 09:47 AM
BCRH and Defouler palinekeki Bolt-Ons And All-Motor 23 02-11-2008 08:41 PM
exhaust defouler mitsukaiSI Bolt-Ons And All-Motor 0 02-01-2008 01:15 PM
Defouler GlxyGry06Si Bolt-Ons And All-Motor 10 06-27-2007 06:41 PM
Mechanical Defouler iVTECpower Civic SI 3 02-27-2007 09:17 AM
