maybe with jdm goodies we can have kpro
i think i just figured out how we can have k-pro. the ctr doesnt have a maf right? if we use the jdm ecu, harness, we could have kpro because isnt the ctr ecu just like the itr and the ctr has 2 dashes just like us?
if someone has anything better to say please post on this thread. |
Tuna Fiddle™
I don't know but I'm just thinking. Does the CTR use the same MAP sensor as the FG? Is it mounted in the same location? I have a feeling that because the FG uses a MAF as the primary way to measure air flow, that the MAP sensor on it doesn't read the same as it would if the FG used a speed density (MAP) system to measure air flow. I'm not sure of this, but it just was the 1st thing that popped into my head.
#6 (permalink) | |
the more interesting question is if the JDM engine harness is basically the same as USDM (besides the MAF part)?. if you unplug the MAF sensor and the JDM ecu only reads information for the MAP sensor, i dont see why this wouldnt work. unless there is a whole bunch of other wiring thats differrent. Last edited by NIGHTHAWKSI; 02-06-2008 at 01:38 PM. |
#7 (permalink) | |
Tuna Fiddle™
Tuna Fiddle™
yeah, that could be true. I haven't ever actually looked at a removed cluster. Hopefully its like that, but it could also be just more pins on the same connectors. If thats the case you should still be able to cut the connectors off the JDM harness and solder on the USDM connectors.
#11 (permalink) |
Tuna Fiddle™
if I had the funds I would deff be down to try this, but it seems like alot of money to invest for unknown results. I'm gonna consult the guy who imported parts for my old accord tonight and see exactly how much it would cost to get something like this. Unfortunately since the CTR is so new the parts would have to be purchased new. It's not like theres already a ton of them laying in junkyards in japan yet.
#14 (permalink) |
the harness probably isnt necssary. the motors wiring is probably 95% the same except the CTR harness wouldnt have a MAF plug on it. so lets say the CTR ECU is plugged into the USDM harness, just leave the MAF plug unattached from the sensor and it should just be ignored.
i actually couldnt picture it being more difficult than getting the CTR ecu reflashed for the immobilizer and plugging it in. as far as the car running corretlt with the wrong tune in it, k-pro should be able to fix it. |
