draining coolant for img install...
hey y'all!! i'm gonna be installin my p2r throttle body spacer soon and while i'm at it, i'm going to go ahead and install the intake manifold gasket. i was reading the diy and it seems pretty staright forward and i saw that you gotta drain the coolant, but how much coolant does the 8th gen si hold so i can put an appropriate sized catch pan under the car. thanks a lot.
#8 (permalink) | |
![]() Thanks PM Sent |
#13 (permalink) | |
![]() thankx a lot man!!!!
#14 (permalink) | |
#15 (permalink) |
Thanks bro. Thats what this is all about. Helping each other. If anyone needs help with this PM me. And if anyone wants to do a DIY with my trick go for it. It's so cold out up here and my boss is an ass and wont let me do it at work that's why I haven't done a DIY yet.
#17 (permalink) |
I'd rather guess so I'd say that your uber secret is something along the lines of:
1) Remove the stock intake manifold studs. 2) Remove the stock intake manifold bolts. 3) Pull intake manifold away from the block enough to grab and remove the stock metal gasket. 4) Insert the IMG and line up everything. 5) Reinstall all bolts and studs. 6) Clean up any spills. 7) Add more coolant. |
#18 (permalink) |
Pretty close dude. There is alittle more to it than that but that's the basics. And it was never an uber secret. I was only being a goof. I just never got around to doing it. Plus I work on cars all day. The last thing I want to do is take apart my car when I get home. Unless I'm installing something new.
| DIY: HONDATA IMG INSTALL | BATANG CITY JAIL | Mechanical Problems & Technical Chat | 103 | 02-22-2008 04:22 PM |
| How to drain coolant for IMG Install?? | hondaonchrome | Bolt-Ons And All-Motor | 3 | 07-08-2007 12:18 AM |
| Problem after IMG install | CaliGuy | Mechanical Problems & Technical Chat | 24 | 07-05-2007 09:17 PM |
| Hondata IMG Install ? on 06 Si | Nox | Bolt-Ons And All-Motor | 4 | 09-14-2006 12:58 PM |
| IMG install?!? | SonicK20Z | Bolt-Ons And All-Motor | 1 | 06-21-2006 05:45 PM |
