Old 01-27-2008, 03:26 PM   #1 (permalink)
LoverOfCivics's Avatar
Javier
One Question.
Alright guys just looking for an answer to a question i have because i just ordered the Injen CAI
Do you have to cut the wheel wale wall for this mod to fit?? or will it work but just barely fit??
I remember seeing some threads about this but it was along time ago and i tried searching but i couldnt find anything nor could i remember what happened so if you could either give me the straigh answer or the link thanks in advance!!!
Ps. what im really looking for is the people who didnt cut it that did something different or the people who just left it as a snug fit and what happened to it if it wound up working good like that thanks again
LoverOfCivics is offline   Reply With Quote
Old 01-27-2008, 04:38 PM   #2 (permalink)
i cut it
i think u can do it without cutting, but it's going to be very very difficult to work that tubing into the engine bay.
hope that helps
loves to speed is offline   Reply With Quote
Old 01-27-2008, 04:46 PM   #3 (permalink)
FG2uner's Avatar
Mark
you need to cut it because if you dont its gonna rub on the fender well..... mamke sure u cut it right. i cut mine too much and now i got a giant hole where water can get in..
FG2uner is offline   Reply With Quote
Old 01-27-2008, 04:48 PM   #4 (permalink)
sgtpruitt's Avatar
Tim
I didn't cut it and it was cool for a while unitl I installed fogs. Then I had to cut it to get the fogs to fit. I noticed when I cut it that the piping was getting cut on the side of the car.
Just cut it man. You can replace the splash chields for cheap if you need to on down the road. If not you can try and manufacture some kind of cushion between the intake and the wheel well to keep it from slicing the pipe.
Daily philosophy:
Each person has their own moment and place in thought. The Red Wheelbarrow means nothing except to the doctor.
sgtpruitt is offline   Reply With Quote
Old 01-27-2008, 05:03 PM   #5 (permalink)
Jeremy
you can do it without cutting, i did cut it and its all sloppy and i still gotta cut it out more to make it a better fit, like sgtpruitt said its a bitch when you go to install fogs cuz then the filter hits the fog assembly. so hopefully after i cut it more it will fit better
jeremy0203 is offline   Reply With Quote
Old 01-27-2008, 06:20 PM   #6 (permalink)
Daniel
Same ^^I cut mine.If I had to do over I would have cut small first time then bigger.
Forklift352 is offline   Reply With Quote
Old 01-28-2008, 01:58 AM   #7 (permalink)
Javier
thanks for all your replys helping me alot!, now where exactly is it coming into contact with the wheel wale wall? i know its infront of the tire but how low and wouldnt cutting a hole let debris get thrown right in there??!?!
Old 01-28-2008, 02:06 AM   #8 (permalink)
MRK20's Avatar
You have to cut when you get fogs? That sucks...
MRK20 is offline   Reply With Quote
Old 01-28-2008, 10:08 AM   #9 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Well, you should cut the splashguard just a little bit so that there's not a buch of pressure on it. However, no matter what you do, you'll eventually get a cut in you pipe down there due to rubbing that will happen even with the shock mount or whatever you want to call it. It happens with aem and injen alike even though they both mount at different locations.
Old 01-28-2008, 01:22 PM   #10 (permalink)
C0mat0se's Avatar
Nick
Happened to me and I had a gash in my intake, hard to keep that from happening. I guess if you used some zip ties you might could help the situation but you still woudn't want to pull on it too much. You shouldn't have to worry about water getting into the filter though, since you cut where the intake curves.
C0mat0se is offline   Reply With Quote
Quick last minute question before I place order on wheels (lug question) I Vtec, do you? Wheel And Tire Upgrades 8 01-29-2008 07:39 PM
Graphics Card Question and Motherboard question BlackSi10 Technology 13 12-07-2007 04:20 PM
Last question about 18" HFP on non-si + Tire PSI question amdhunter Wheel And Tire Upgrades 2 06-26-2007 05:11 PM
