Old 06-04-2008, 12:23 PM   #121 (permalink)
Adlh29's Avatar
Adam
Originally Posted by Tredd View Post
are u talking about the super fast clicking noises when the engine is on? I think u'd be hearing the fuel injectors. Also, has anyone encountered any lower MPG's with a TBS? I installed a Helix one a week ago right before i filled up, and now gas has been going down faster than usual, my driving habits are the same.
Yes, several members have been concerned about the clicking noise. This is caused by the fuel injectors. No need for concern, everything is as it should be.
Adlh29 is offline
Old 06-04-2008, 12:30 PM   #122 (permalink)
firstsi's Avatar
really mine went up
firstsi is offline
Old 06-04-2008, 05:06 PM   #123 (permalink)
08usmcSI's Avatar
Michael
can someone explain to me why i would hear the fuel injectors more with a tbs than without? i don't understand
08usmcSI is online now
Old 06-04-2008, 05:09 PM   #124 (permalink)
Behind Firmhonda's beard, there is only another shaved beaver.
ErichPryde's Avatar
Erik
it's possible that the clicking isn't your fuel injectors. Or perhaps after you installed it, you started listening to your car more carefully and you noticed the ticking sound.
If you're concerned about it, either take it to a fellow 8thcivic member who knows quite a bit about Hondas, or try taking it to a dealership. with the car running, ask one of the mechanics what the ticking noise is.
I don't know why the throttle body spacer would cause a ticking noise.
Originally Posted by Slowride View Post
My only Si complaint is that I opened the radiator cap with the car running at full temp, and though common sense would have told me otherwise, I got sprayed in the face with scalding hot liquids.
Originally Posted by ImTheVoiceOfGod View Post
But I dont wanna be banned
ErichPryde is offline
Old 06-04-2008, 08:36 PM   #125 (permalink)
08usmcSI's Avatar
Michael
i wonder what a dealership would say to me with my mods. I haven't taken a car back to a dealership after I've installed after market products.. any idea of what to expect?
Old 06-04-2008, 08:54 PM   #126 (permalink)
hunting69's Avatar
joshua
installed a helix wit my fujita sri ad now i cant hear my intake when it used to be crazy loud ?????????????/help caus ei dont like it lol
hunting69 is offline
Old 06-04-2008, 09:46 PM   #127 (permalink)
Adlh29's Avatar
Adam
Well, I have heard mixed things. All dealerships are different. You don't want to go in an say "are my mods causing ticking noises?" because they are going to charge you to investigate. My dealership has threatened to void my warranty already because of shifter mods. Now i know that the Magnunson Moss act says that they have to prove it but dealerships dont care. You will have to pay for a lawyer (money I don't have) to take them to court to get your warranty back if they decide to be real pricks. One guy on this site kept complaining about a ticking noise. He took it in and they said it was just his injectors. Open up the hood and see if you can zero in on the nise. My guess is its coming right from the injectors. Hope that helps you out a little.
Adlh29 is offline
Old 06-04-2008, 09:52 PM   #128 (permalink)
08usmcSI's Avatar
Michael
Thanks for the input. I will try to take it to a dealership (unfortunately) not the one i bought the car from, since I'm 600 miles away. I have a feeling since I'm young they will try to push me around. I am 80% sure it is the injectors.. but only 100% would satisfy me
Old 06-04-2008, 09:54 PM   #129 (permalink)
firstsi's Avatar
lol good luck, i would think with the usmc in your user name you wouldnt get pushed around
i really had no problems with my dealership and they know what mods ive done
firstsi is offline
Old 06-05-2008, 11:25 AM   #130 (permalink)
Dave
Originally Posted by Gixstars View Post
looking into that little notch, it doesn't look threaded and that little white plug/rivet won't go in it. What's the purpose of the notch exactly and the white rivet???
Sounds like you have the newest one or at least the spacer that doesn't have the hole drilled the entire way through and tapped to accept the threaded plug. My black spacer (bought in March) had the threaded hole but 07_HFP_Si's red spacer (purchased in May) had what I would call a "blind" hole where it looks like the hole is partially drilled into the aluminum and not threaded. IMO P2R might be doing this because most folks won't use the hole for N2O and if you either forget to install the plug or install it in such a way as to cross thread it, etc. then you will have a vacuum leak. Those folks that are knowledgeable enough to install N2O themselves or the shop that's doing the work (This would be a "Wet Single-Point" system if I'm not mistaken) probably have access to a drill press and tap and can finish the hole as required.
OrdnanceMarine is offline
Old 06-14-2008, 01:06 AM   #131 (permalink)
Jason
heyo, i've got an aem short ram intake, and down low (around about 3k-3.5k) when i step on the pedal the car lags for about a second and a half then takes off. will a tbs fix this, worsen it, or do nothing about it?? thanks.
cooleyblues is offline
Old 06-14-2008, 04:08 PM   #132 (permalink)
soxfan143's Avatar
That is normal for an AEM filter on a stick. Actually it's kind of normal for any intake that doesn't incorporate the stock MAF housing with the vanes in it. Good luck trying to get that to stop.
soxfan143 is offline
Old 06-14-2008, 04:31 PM   #133 (permalink)
Rob B.
does anyone have a website where i can purchase the TBS and gaskets?
i have a TBS on my truck and you can really tell in te midrange rpms....
- Rob
Notoriously_rob is offline
Old 06-14-2008, 04:33 PM   #134 (permalink)
ccking85's Avatar
Chris
CorSport Online Store: Honda - 06+ Civic
Click on this http://kingersville.myminicity.com/
ccking85 is offline
Old 06-14-2008, 04:38 PM   #135 (permalink)
Rob B.
what is the difference in the gaskets needed? and with an 08 Civic Si, what specific tbs should i be looking for...
Old 06-14-2008, 04:44 PM   #136 (permalink)
ccking85's Avatar
Chris
you need two gaskets. I dont think there is a difference in years cause it says 06+
ccking85 is offline
Old 06-14-2008, 04:47 PM   #137 (permalink)
Rob B.
TB Power: 2 Throttle Body Thermal Gaskets and 1 TB Spacer - $110 shipped
i wonder if Excelerate is still selling these.///
Old 06-14-2008, 04:59 PM   #138 (permalink)
Rob B.
anyone geta TBS/gaskets from excelerate and how'd you like it....I am gonna get one if they are still selling..didnt see them on the website...
- Rob
Old 06-14-2008, 05:01 PM   #139 (permalink)
ccking85's Avatar
Chris
looks like they are still selling it.
ccking85 is offline
Old 06-23-2008, 04:42 PM   #140 (permalink)
08usmcSI's Avatar
Michael
It shouldn't matter who you go through.. p2r is the most common bought.. and is a good product. Just a preference of which site you want to give your money to :P
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/70434-p2r-throttle-body-spacer-faqs.html
Y esta m... sirve? - www.NipponPower.com.mx This thread Refback 02-07-2008 01:35 PM
Y esta m... sirve? - www.NipponPower.com.mx This thread Refback 02-07-2008 11:56 AM
Y esta m... sirve? - www.NipponPower.com.mx This thread Refback 02-05-2008 11:55 PM
Y esta m... sirve? - www.NipponPower.com.mx This thread Refback 02-05-2008 09:40 PM
Bolt-Ons And All-Motor - 8th Generation Honda Civic Forum This thread Refback 01-04-2008 12:52 PM
