#101 (permalink) |
John
I blocked off the coolant the my TB when i first got my Si.....
also I just bought the TBG TBS TBG from Corsport in a special color.....yahhhhh pics soon |
#102 (permalink) | ||
From what I understand about our cars, 13's/14's are a good mix to produce power without overheating the engine. Anyone else have info on this?Also, this from my speed shop guy when I emailed him about the full bottom end to top end results of my car over bone stock: Quote:
Once I dyno with my spacer on prior to installing the race header, I'll post the gains and charts here.
Fujita F5 SRI / S2 MPR 70mm / Eibach Sportlines / Ingall's ETD & Fr Camber Bolts / Prog Rr Sway / P2R TBS/Gs / CorSport IMG / S2 Rr Camber Kit / CT STS / JDM CTR Shift Knob + Boot / Hondata ECU RF ![]() http://www.btrobertson.com Last edited by BTRobertson; 04-22-2008 at 10:41 AM. |
#103 (permalink) |
I promised pictures for some users regarding the fit of the P2R TBS/G with the Fujita F5 SRI. What we did was create a bracket extension for the F5 mount instead of trimming the rubber inlet hosing. Why? Well, you're shortening the air travel path, which will mess with the AFR, even if slightly, because you're changing the flow dynamics. That was my theory anyway, albeit untested.
So, here's two pics: one of the spacer installed (seen before) and one of the custom bracket extension we made out of a simple piece of scrap metal lying around the shop. Enjoy.![]() ![]()
Fujita F5 SRI / S2 MPR 70mm / Eibach Sportlines / Ingall's ETD & Fr Camber Bolts / Prog Rr Sway / P2R TBS/Gs / CorSport IMG / S2 Rr Camber Kit / CT STS / JDM CTR Shift Knob + Boot / Hondata ECU RF ![]() http://www.btrobertson.com |
#105 (permalink) | |
#107 (permalink) | |
the throttlebody has a radiator line running through it, to warm the air going in to the engine by bypassing the throttlebody you get cooler, heavier, denser air in |
#108 (permalink) | |
That being said, there is still *some* controversy regarding doing this here but many members have been doing it on the K20Z3 for a while and have done it on other cars for many, many years. That being said (again), I have done the coolant bypass on my throttle body. If I'm ever concerned about the slim possibility of icing in the winter time then I will reconnect the hoses (takes maybe 10 minutes) and I'm back to stock. To me there seems to be no point in trying to get cooler, more dense air to the engine by using tricks such as a CAI or using the intake manifold gasket if you are still heating the air at the throttle body. In theory you should see a slight decrease in MPG doing this since WARM air often better for fuel economy but I can't say I've seen any change. I get exceptional fuel economy. Last edited by OrdnanceMarine; 05-12-2008 at 05:36 PM. |
#109 (permalink) |
thanks firstsi and ordinancemarine. one more thing. if you do the bypass, where do you bypass it to? as in where does that hose go? To ordinancemarine, you say you have exceptional gas mileage w/ or w/out the IMG? what are you running? (intake, spacer, gaskets, tb, etc.)? i'm all for gas mileage
#110 (permalink) | |
Other tips: -I took a funnel and poured water to flush the throttle body, then blew it out with my air compressor to completely dry it out. -You can partially drain your coolant into a clean bucket for reuse. This keeps you from having to deal with leaking coolant when you disconnect the hoses. I didn't do this on my car and it made a bit of a mess. I lost probably a cup of coolant. On my friends Si we were changing his upper radiator hose to a flexible stainless one and installing the IMG at the same time so we had drained the coolant, making this even easier. I believe there is a DIY on this. Use common sense as with any mod! |
#111 (permalink) | |
The bottom line is I haven't noticed anything but my mileage getting better and better. All I can conclude is that a combination of my engine breaking in, temperatures getting warmer, gasoline switching to "summer blends", and me learning how to drive my car more efficiently has netted huge improvements in mileage over the past four months I've owned my car. |
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/70434-p2r-throttle-body-spacer-faqs.html
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-07-2008 01:35 PM | |
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-07-2008 11:56 AM | |
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-05-2008 11:55 PM | |
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-05-2008 09:40 PM | |
| Bolt-Ons And All-Motor - 8th Generation Honda Civic Forum | This thread | Refback | 01-04-2008 12:52 PM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| P2R Power Package: Intake Manifold Gasket, TB Gasket and TB Spacer | Excelerate | Excelerate Performance | 141 | 05-15-2008 11:31 AM |
| P2R Throttle Body Spacer dyno with I/H/E?? | k20z3civic | Bolt-Ons And All-Motor | 25 | 05-01-2008 11:09 AM |
| need help with p2r throttle body spacer | bigmsi | Bolt-Ons And All-Motor | 8 | 12-26-2007 12:37 AM |
| P2R Throttle Body Gasket & P2R Throttle Body Spacer | KDUB-FODATAZZ | Bolt-Ons And All-Motor | 6 | 10-30-2007 10:39 AM |
