#61 (permalink) | |
Thanks for the insight! |
#63 (permalink) | |
Moderated
there is an increase in throttle response, however minute it may be. your jumping analogy was a good one, too. too bad I can't rep you.... not that it matters. consider this a +1.
#64 (permalink) | |
bizzybear, thats it pretty much. |
#66 (permalink) |
Do you mean to take it out and not seal up the hole with something? That would be called "vacuum leak"! Very bad!!! If you choose not to use the nylon plug you will have to seal the hole with something. Be sure you're sealing it with something that can't possibly come off and get ingested by your engine.
#67 (permalink) | ||
![]() u will have a ridiculously crazy idle... and it prolly won't let u rev to the limit... |
#70 (permalink) |
This is a great write up. I'm now considering picking up a TBS as one of my next set of mods. Just a question... What would the effects of adding an aftermarket TB (such as the Skunk2 pro series) alongside a TBS be? Would it help recoup lost throttle resonse? Would a larger diameter be better?
#71 (permalink) | |
as of right now there's not enough market to make a TBS with a bigger diameter... which is why it's not made in different sizes... |
#73 (permalink) |
Speaking of matching internal diameters here's one to ponder. I noticed that the ID of the TBG's are something in the neighborhood of 3-4mm less than the spacer (this is from memory when I installed mine about a week ago, I should have put a caliper on it but didn't). While I'm sure it's not disturbing the flow much, wouldn't it make sense to shave off this excess to smooth out the transition? I didn't have time to do it when I did my install but I'm considering it when I take things apart to install my IMG.
Another note: Before I noticed that the TBG's are smaller than the TBS I tightened the nylon plug as far as I felt it would go before rounding off and noticed the plug doesn't end up flush with the inside of the spacer so I squirted some RTV in the hole and tooled it flush. I figured it can only help keep the flow a little bit smoother. Again, probably won't make any real sort of difference but I'm always looking to optimize where possible. |
#75 (permalink) | |
hopefully that sealant wont pull free and get sucked into the intake |
#76 (permalink) |
Definitely something to be concerned about but I've worked with RTV for over a decade and paid close attention when I filled to void to ensure that there were no air bubbles behind it (to expand and contract as MAP varies from ~2-15 psi). I'm pretty confident in it's holding characteristics but will check on it when I have it apart to install my IMG.
#77 (permalink) | |
Juuken!
With the amount of vibration the intake sees, i'd really be worried about it without the modification. As you can see, it fits fine:
#80 (permalink) | |
Best, VTECnical
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/70434-p2r-throttle-body-spacer-faqs.html
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-07-2008 01:35 PM | |
| Y esta m... sirve? - www.NipponPower.com.mx | This thread | Refback | 02-07-2008 11:56 AM | |
