Old 11-27-2007, 04:41 PM   #1 (permalink)
JZILLA's Avatar
Helix Tb Spacer??
so I got the helix tb spacer and I already have the p2r tb gasket and am wondering if I should use it on one side of the helix or just use the two supplied
JZILLA is offline
Old 11-27-2007, 04:58 PM   #2 (permalink)
JZILLA's Avatar
bumpy
JZILLA is offline
Old 11-27-2007, 05:00 PM   #3 (permalink)
Soichiro Jr.'s Avatar
If your budget permits, I think you should buy one more p2r tb gasket and use both of those. Good luck.
Soichiro Jr. is offline
Old 11-27-2007, 05:02 PM   #4 (permalink)
Driversound's Avatar
No need to use it on both sides. Just use it on the Intake Manifold side to isolate the throttle body spacer from the manifold. That's where the heat is coming from.
Driversound is offline
Old 11-27-2007, 05:12 PM   #5 (permalink)
JZILLA's Avatar
thank you do think i should double up the helix gaskets on the other side?
JZILLA is offline
Old 11-27-2007, 06:25 PM   #6 (permalink)
Unless you do the TB coolant bypass, the TB is also a source of heat, correct? Not trying to be a smartass in any way . I understand that most people do do the TB coolant bypass when they install a spacer, but..... If you did the spacer mod, w/o doing the TB coolant bypass, and used the non-thermal gaskets on the TB side; wouldn't the spacer and TB become "one big HOT metal piece"?
Old 11-27-2007, 06:25 PM   #7 (permalink)
no, never double up. wot seal properly and cause blo-by.
Cuban Si is offline
Old 11-27-2007, 07:18 PM   #8 (permalink)
JZILLA's Avatar
thanks guys i didnt i just put the p2r on the manifold side and one helix gasket on the other btwn the spacer and tb
JZILLA is offline
P2R Power Package: Intake Manifold Gasket, TB Gasket and TB Spacer Excelerate Excelerate Performance 156 07-07-2008 11:39 PM
Helix Throttle Body Spacer Driversound Bolt-Ons And All-Motor 135 06-10-2008 05:11 PM
HELIX Spacer Review.. DeVoTeD_1 Bolt-Ons And All-Motor 35 11-07-2007 11:46 PM
