do u have stock cams? the aftermarket cam gear might not give u any power if some at all. there usually available for aftermarket cam setups so that u can adjust the aftermarket cam for optimal power. I dont wanna say that u'll get none but u probably wont get a lot if any.
#11 (permalink) |
while on the topic of cams, what would be the drawback to installing turbo cams on an NA car? I plan on getting the X MAF V.2 with Skunk2 Turbo cams..I am aware that it wont be a helpful as NA cams but with the addition of an exhaust cam gear cant I make it work just like an NA camshaft?
#12 (permalink) | |
#13 (permalink) |
well if i were to FI the car later I would not have to buy another set of cams. SO take the poor mans rout for now, make it as good as possible cause NA cams have a greater lift and duration on the intake side and Turbo has it on the exhaust side, and by using the exhaust cam gear I can adjust timing to better sync to an NA setup!....
#14 (permalink) | |
#17 (permalink) |
Why sure! If your going to do cams, and from what ive read the only cam gear you would need ever would be the exhaust side, then make it usable for a variety of applications and make it future proof! BTW looking at you avatar is making me think twice about this idea of mine....
#19 (permalink) |
true. but I was in the market for X's V.2 for cammed motors. Knowing it will work for all cammed motors It looked like a good idea for a nice bump in power and it will work nicely with all other upgrades from there on. And I was hoping it would offset the issue, along with the exhaust cam gear, of the Turbo cams in the NA
