Go Gators!
I think.The problem with using an intercooler without F/I is the long piping and the flow would probably negate any gains from the cooling. dont quote me on it though.
IMV Films
Vehicular Lunacy at its Finest Firestrife's Nighthawk Wonder Gainesville/UF Guys check in here! |
Go Gators!
well what i was saying is like you know how a SRI works by reducing the length of pipe air needs to travel to increase flow. I think the Intercooler and longer pipe would/could bottleneck that flow, without F/I.
IMV Films
#8 (permalink) | |
Pit Stop !?
The only way this idea would work is if you had a very small intercooler like those found on the last model GST eclipse and you hooked up a CO2 intercooler sprayer kit to ice down the intercooler. You see, when a turbo compresses air it becomes hotter than outside ambient air temperatures. Also the exhaust side of the turbo is making the compressor side of the turbo hot as well. The idea of the intercooler is to reduce the temperature of that air which I'm sure is well over 150 degrees. I have heard it can as hot as 300, but I can't be sure on that as I am not an expert on how hot the air is. |
Intercoolers only work if your cooling media is colder than the intake air. So if you heat up the intake air a lot with a compressor (supercharger or turbocharger), then you can use the outside air (that is cooler) to cool off the heated intake air.
Now if you are naturally aspirated and you have a cold air inlet (like the stock inlet) there is no cooling media that is colder than the intake air so an intercooler will not work. All you need is a good cold air intake, that's it. |
#11 (permalink) |
Hmmm...well, I wasn't thinking of having the filter AS the "intercooler" like that pic. But more like a cone filter on one end of the intercooler, and the metal of the intercooler allowing the air passing over the intercooler to chill the air going to the throttle body. That CryO2 thing that sprays the intercooler might be a good idea to chill the air...but adding an intercooler might be excessive/unnecessary. I just feel that a normal CAI doesn't produce the kind of cold air that it should. Thoughts?
#12 (permalink) | |
Blown at last
#15 (permalink) |
8thcivic Sponsor
BUY MY CIVIC |
#17 (permalink) |
Yes... they are NEON ORANGE!
you cannot cool air below ambient temps using ambient air. If you are minimizing the heating of air from a traditional CAI, you would be wasting time, money, space and everything else involved.
#18 (permalink) |
What about a water intercooler CAI? (Air comes in through a cone filter, passes through an intercooler that is air or peltier cooled, and then goes to the throttle body) I don't know if this exists...but it would purify the temperature of the air...maybe even drop it as well.
Would this be just as effective as getting a CryO2 kit for a CAI or better? |
#19 (permalink) |
You are adding restrictions into the air stream with any of these options... the $1000 or so you would spend would be better put out on a race header and Hondata...
| 2009 Acura NSX? Honda HSC Concept ***Updated sketch inside***- Merged Threads | firmhonda | Garage | 42 | 10-14-2007 02:08 AM |
| Injen CAI vs AEM CAI Review....hesitation etc. | sickyute | Bolt-Ons And All-Motor | 118 | 10-07-2007 08:40 AM |
| Fujita CAI | DazeSi | Civic SI | 6 | 04-17-2007 10:47 PM |
| Honda At The 2007 Geneva Motor Show | webby | Honda Industry News | 6 | 03-12-2007 07:20 PM |
| Honda Demonstrates the FCX Concept Vehicle | webby | Honda Industry News | 0 | 10-27-2006 02:44 AM |
