Old 09-15-2007, 04:51 PM   #1 (permalink)
mO 64 StAnG 06's Avatar
(R18) Oil capacity
Here in the past few day's I've been getting paranoid with how much oil I've been putting into my R18.
I always fill up the oil filter completely and then empty out up to 4 quarts of oil into the car.
I think that is the recommended amount, but checking the oil level with our dipsticks is impossible.
Is 4 quarts too much? I didn't know over filling was bad... Or is a little overfill that bad?
mO 64 StAnG 06 is online now   Reply With Quote
Old 09-15-2007, 07:48 PM   #2 (permalink)
Anyone?
Old 09-15-2007, 07:50 PM   #3 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
overfilling is bad.
is Missy a squirter?
http://killyourself1.myminicity.com/tra build my city.
Zeuceone is online now   Reply With Quote
Old 09-15-2007, 07:54 PM   #4 (permalink)
Manual says 3.9 Quarts, including the filter. I think you're saying you put 4 quarts + enough to fill the oil filter (do you pre-load it or something?) - might be too much. I haven't changed my oil yet, though, so...
GreenHokie is offline   Reply With Quote
Old 09-15-2007, 08:00 PM   #5 (permalink)
BigT's Avatar
A "little" over is not horrible. But on a system which holds less than five quarts a little really is a little. Even a half a quart is over 10% too much.
I think the Owners manual says total system capacity is 4.7 quarts. But refill capacity is closer to 4 quarts (Edit: 3.9 quarts. Thanks GreenHokie). I agree it is very hard to see new oil on the dipstick. It is easier to see in the checkered area, so I recommend putting less than the full amount in and then adding little by little (checking as you go) untill it is at the top of this area. If you go over it is very hard to tell how far over.
Edit: Very much over can be bad. The crankshaft will be spinning through more oil than it should be. This can cause oil foaming and other problems.
BigT is offline   Reply With Quote
Old 09-15-2007, 08:56 PM   #6 (permalink)
ryker's Avatar
If your MPG drops then you will know your overfilled.
ryker is online now   Reply With Quote
Old 09-15-2007, 11:01 PM   #7 (permalink)
Well I've always filled a full 4 quarts counting the filter pre-loaded too.
If that .1 quart is actually enough for concern I might just start leaving a tad bit left over next time.
Thanks for the responses guys.
Old 09-16-2007, 09:30 AM   #8 (permalink)
BigT's Avatar
The amount listed in the manual is an estimate. It is usually pretty close, but how much oil you get out can vary depending on oil temp, if the car is level or not, etc. I would recommend you put about a half quart less in and then check and see if you can tell where the oil comes on the crosshatch/checkered section of the dipstick.
However, I doubt you are hurting anything just putting 4 quarts in.
Oil Change DIY ethlar Engine 234 10-04-2008 10:29 PM
THE OIL FAQ - synthetics, intervals, weights, brands jdrumstik Mechanical Problems & Technical Chat 97 09-17-2008 03:45 PM
Everything Oil: All you'll ever wanna know atruhondagrl Bolt-Ons And All-Motor 14 06-16-2008 12:45 PM
Mens vs Women Oil Change 06 Civic Ex Water Cooler 12 08-04-2007 11:42 AM
Oil Life Elmacho Civic SI 28 04-25-2007 06:54 PM
