Old 09-07-2007, 11:20 PM   #1 (permalink)
Ingalls Power Stick Installed
It came in today, will be installing it Saturday morning.
bioevolve is offline
Old 09-07-2007, 11:21 PM   #2 (permalink)
Take the 3 main 17mm bolts out
Point the rubber end down
Perfect circle to the fenderside and the oblong circle to motor side
Match up length of stock dog bone
Turn with pliers or small wrench to a slight angle, cause body to motor is not a perfect horizontal line. Motor end is a little lower.
ETD will not fit due to the c-clip and washer and mount bar in the way, pushes the ETD over into the pointy bolt and will not go any further. You must grind the side of the the ETD bracket closest to the Power Stick to make it fit. So I just took the ETD off. I wanted to see what just the Power Stick would feel like by itself.
It's in and done.
Only issue I have with it is these two washer spin freely, I would like them to be tight.
ETD reverse = Heavy Vibration
Power Stick = Virtually Non-existent
ETD 1st grear slow to med = moderate vibration
Power Stick = Very little Vibration, feels like a dampened light feeling (kinda relaxing)
Wheel hop 1st gear launch 5500rpm levels:
ETD = Little
Power Stick = Moderate
Stock = Lots
If you want super duper little wheel hop go with both w/ ETD grinds.
If you want little wheel hop and don't care about the vibration go ETD.
If you don't like the vibration but alittle more wheel hop go Power Stick.
If you don't like any of it, stay stock.
I'm sticking with the Power Stick, the light vibration is very pleasant and less annoying.
Old 09-07-2007, 11:38 PM   #3 (permalink)
rp215's Avatar
Ronnie
Is idle vibration worse?
rp215 is offline
Old 09-07-2007, 11:47 PM   #4 (permalink)
Virtually none with power stick.
Old 09-07-2007, 11:48 PM   #5 (permalink)
Whos The Whore NOW
07mugencivic's Avatar
Tony
what does that do
07mugencivic is online now
Old 09-08-2007, 01:46 AM   #6 (permalink)
Hot_Chocalate25's Avatar
thanks for the pics of the install. I ordered mine yesterday. looks like an easy install.
Hot_Chocalate25 is offline
Old 09-08-2007, 09:43 AM   #7 (permalink)
PR_S14's Avatar
Freddy
I'd like one of these with an all metal bushing. Wonder if any plans are in the works? Nice write up/review!
PR_S14 is offline
Old 09-08-2007, 09:56 AM   #8 (permalink)
SpeedDemon's Avatar
They call me, El Diablo.
Worth the 110?
SpeedDemon is online now
Old 09-08-2007, 10:24 AM   #9 (permalink)
sinirgi's Avatar
sounds kinky.
so does this mod only reinforce the torque damper?
sinirgi is offline
Old 09-08-2007, 10:26 AM   #10 (permalink)
Started the car from a cold start, it's alittle bit less vibration than the ETD during warm up until optimal temps are reached.
ETD = Vibration felt thru the pedals, seat, floor board and steering wheel.
Power Stick = Vibration is felt thru the pedals and floor board.
ETD = Dash board shakes and the coins in my center console rattle.
Power Stick = No dash board vibration and the coins don't rattle in the center console.
Old 09-08-2007, 10:30 AM   #11 (permalink)
It's helps with wheel hop during launch.
I think it's worth $110 and $155 for the ETD, it all depends on how much power you want to the pavement and the amount of vibration you can handle.
Yes, it does sound Kinky lol.
Less movment of engine is accomplished with the Power Stick and ETD, that slapping motion is kept under control during hard launches.
Old 09-08-2007, 01:20 PM   #12 (permalink)
Emmanuel
on my to order list now... thanks for the review +1
xfactorwrx is offline
Old 09-08-2007, 02:08 PM   #13 (permalink)
SiRyan's Avatar
Nice, this will be my next mod
SiRyan is offline
Old 09-08-2007, 03:59 PM   #14 (permalink)
954K20_SI's Avatar
wow! great write-up! I plan to pick this up and the stiffy mount!
954K20_SI is offline
Old 09-08-2007, 04:21 PM   #15 (permalink)
Grind this part off to make the ETD fit with the power stick:
Old 09-08-2007, 04:58 PM   #16 (permalink)
SiRyan's Avatar
thats weird I thought they would make those two to compliment each other...
SiRyan is offline
Old 09-08-2007, 05:53 PM   #17 (permalink)
Sean
Etd..?
Jandonian is offline
Old 09-08-2007, 05:55 PM   #18 (permalink)
Supreme Pizza!
Izzy's Avatar
Engine Torque Dampener.
Izzy is offline
Old 09-08-2007, 06:15 PM   #19 (permalink)
F-1 Si's Avatar
Peter
Why doesn't the "Stiffy" and "Powerstick" work together without mods? I'm S.O.L for 3-4 weeks due to a fractured should. I can do bolt ons but not ones that require modifycation. Grrrrrrrrrr!
F-1 Si is offline
Old 09-08-2007, 11:04 PM   #20 (permalink)
ovur ur headz
Qshooter151's Avatar
Jordan
good pics and nice write up...
Qshooter151 is offline
JD Power....Initial Quality Study cbondhonda Honda Industry News 0 06-19-2007 10:54 AM
How to run power to the trunk 07 sedan dradd21 Bolt-Ons And All-Motor 1 05-02-2007 01:00 AM
what power source do I use to power my neons in car? Way2Short Lighting, H.I.D.'s, & Neon 16 10-20-2006 12:57 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
