Old 08-20-2007, 09:37 AM   #1 (permalink)
Daren07si's Avatar
Daren
Thumbs up What is a best clutch kit for 2007 civic si?
Any one knows whats the best clutch for 2007 civic si? I have a Injen cold air intake,P2r Spacer and gasket, DCRH, DC catback and reflash.
Daren07si is offline   Reply With Quote
Old 08-20-2007, 10:07 AM   #2 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Not sure, but I heard the exedy is good.
Old 08-20-2007, 12:39 PM   #3 (permalink)
k20beast's Avatar
zack
yea i was thinkin exedy...
k20beast is offline   Reply With Quote
Old 08-20-2007, 02:20 PM   #4 (permalink)
I have the Exedy Hyper Single and am very happy with it. After installation, there was a little bit of chatter but that went away completely after the clutch was broken in. When I need a replacement, I am going to stick with the same clutch if I can.
Here is a link where I posted a bunch of PICs and specs on the stock clutch and the Exedy Hyper Single.
P.S. I'd avoid ACT since others have not had positive experiences to report after installing.
blueroadster is offline   Reply With Quote
Old 08-21-2007, 03:56 AM   #5 (permalink)
Daren07si's Avatar
Daren
Thumbs up
what kind of mods do you have? Is 06/07 civic si clutch are the same? what stage should i get for my mods.
Old 08-21-2007, 05:38 AM   #6 (permalink)
FG Squad Member #15
Eric has a modified AJP turbo kit on his SI. The 06/07 civic si clutch is the same. As for what stage you should get, stock works perfectly fine. You shouldn't really need a clutch until you start looking at some FI, or a beefy NA setup like the one that was offered by Hytech.
06Fg2 is offline   Reply With Quote
Old 08-21-2007, 09:08 AM   #7 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
There are alot of people that would disagree with that due to people having probs with their clutches early. It seems like they're all 07's though, but I'm not sure.
Old 08-21-2007, 10:07 AM   #8 (permalink)
NA06Si's Avatar
Christian
Unless you have worn your clutch out already, you do not need an upgraded clutch for the mods you have. If you have worn out your clutch already, I would suggest a driving course before a new clutch.
Exedy makes an excellent clutch and none of their products are refurbished. Some of the other clutch companies take used clutches and re surface or refinish them and resell. I had a stage I Exedy clutch (organic) on my '00 Si that was supercharged and the clutch was still as strong as new after 100,000 miles. The stage I also felt very close to stock with regard to pedal effort & resistance. The organic compound still allows for feathering of the clutch.
I would wait until your stock clutch starts slipping before upgrading. The clutch itself is not that expensive, but dropping the tranny is no easy task.
NA06Si is offline   Reply With Quote
Old 08-21-2007, 10:23 AM   #9 (permalink)
FG Squad Member #15
There is no reason why clutches in the 07s should be going early. If so, it is either a manufacturer defect, which would be covered under warranty and recall/bulletin would be put out, OR it is simple driver error.
Old 08-21-2007, 10:28 AM   #10 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
I agree. I hope we can figure out which it is.
Old 08-21-2007, 10:29 AM   #11 (permalink)
FG Squad Member #15
Maybe it's that whack VSA.....but I hope everyone gets their problems worked out
Old 08-22-2007, 01:24 AM   #12 (permalink)
Daren07si's Avatar
Daren
clutch - if the clutch beginning to slip or / and grinding it is not caused by any of the following items: throw out bearing, pressure plate, bad tranny and vsa. it is mostly commonly a worn clutch or beginning to go bad. Also the stock o.e.m. Honda clutch is thin not really thick for racing nor burn out, it's only good for normal drivng.
Old 08-22-2007, 03:03 AM   #13 (permalink)
FG Squad Member #15
I have to disagree with you on this one. I'm not gonna say that the stock clutch is some high horsepower clutch, but it sure can handle power. My buddy has an AJPed stage 1 4dr si and he was romping on it with his stock clutch, and it held great. My clutch was holding up great on my comptech SCed Si. My other buddy has a greddy turboed Si and is currently running the stock clutch with no problems. I also believe there are a couple other AJPed SIs on here running the stock clutch. I beat the ish out of my clutch from day one, and it was holding up great after 25k miles of fun/spirited driving.
Old 08-22-2007, 06:52 AM   #14 (permalink)
Blown at last
Excalibur's Avatar
Jeremy
Yours is an 06. I've noticed that they have stiffer clutch pedals than the 07's. Maybe they have better clutches than the 07's do...
Old 08-22-2007, 11:29 AM   #15 (permalink)
ZILLLAAAAAA!!!!!!!!!!
FijiPhil's Avatar
Phil
I have not had any probs wit my clutch but a clutch and flywheel combo can help get the power to the ground and help with responsiveness even with the few mods he has.
FG Squad Member #382 Tampa Crew Member #3
15% Tint///JDM FD2 Shift knob///JDM Red H emblems///Injen CAI
Join the forum where you can exercise freedom of speech and say what you want -----------> http://tampastreetracing.lefora.com/forum/
FijiPhil is offline   Reply With Quote
Old 08-22-2007, 02:06 PM   #16 (permalink)
I instaled the Carbonetics Carbon Clutch and it is amazing.
Peter 13th is offline   Reply With Quote
Old 08-22-2007, 02:14 PM   #17 (permalink)
GlxyGry06Si's Avatar
club rsx seemed to like the carbonetics carbon clutch. heres the link. read all the way to the bottom.
http://forums.clubrsx.com/showthread.php?t=499431
GlxyGry06Si is online now   Reply With Quote
Old 08-22-2007, 02:29 PM   #18 (permalink)
SlaNtEyEz
jdmEGO's Avatar
d[-_-]b
I have 07 si and it had 20,000 miles on it and it feel like I just got it. I think is driver error.
jdmEGO is offline   Reply With Quote
Old 08-25-2007, 03:39 AM   #19 (permalink)
Daren07si's Avatar
Daren
yea my clutch always grind everytime i powershift and sometime just regular shifting.
Old 08-25-2007, 03:41 AM   #20 (permalink)
Daren07si's Avatar
Daren
Thumbs up
i have 20k miles already and change my tranny fluid a week ago and still the same problem
