Old 07-23-2007, 05:38 PM   #1 (permalink)
seans-fbp-si's Avatar
Sean
how much whp?
what would be an estimate of wheel hp if someone had these parts on an si
PARTS: Forged Pistons, Forged Rods, SS Valves, Valve Seals, Main Bearings, Rod Bearings, Oil pump, Water pump, Cam seals, Timing belt, Head-gasket, Oil pan gasket, Oil pick-up tube gasket, fujita sri, skunk2 60mm exhaust..
i found a place in new hampshire that has this all in a package for our Si's
seans-fbp-si is offline
Old 07-23-2007, 05:43 PM   #2 (permalink)
truflip's Avatar
If you count the threads you've started in the last month, the WHP you gain from those parts wont even come close
truflip is offline
Old 07-23-2007, 05:55 PM   #3 (permalink)
quality_sound's Avatar
Paul
not to mention nothing but the sri and the exhaust would make more power anyway. the rest is just making the internals stronger.
quality_sound is offline
Old 07-23-2007, 05:58 PM   #4 (permalink)
06Si_LoveR's Avatar
Shuzoku 4 Life
why would they offer a package like that for a car w/ no EMS is beyond me... you can't possibly pull the true power from everything w/o tuning the car
06Si_LoveR is offline
Old 07-23-2007, 05:59 PM   #5 (permalink)
sadly the most u see out of all that is bout 185 - 190 TOPS! dont kill the piggy like that... not till later at least when the ret is needed.
Cuban Si is offline
Old 07-23-2007, 06:07 PM   #6 (permalink)
ouija's Avatar
Jason
Why do people think forged piston heads and rods automatically increase horsepower?
While lighter piston heads/rods and better rod bearings can free up hp, all it does is make your engine stronger.
Now if you're talking different style piston heads you can gain some power.
ouija is offline
Old 07-23-2007, 06:09 PM   #7 (permalink)
RANGERSi07's Avatar
stroke that motor
RANGERSi07 is offline
Old 07-23-2007, 06:12 PM   #8 (permalink)
i would say about -30hp off of stock
damnu is offline
Old 07-23-2007, 06:21 PM   #9 (permalink)
car salesman beware
Freq18hz's Avatar
Pretty much nothing extra. The motor might last 300k miles or longer though.
Pretty much all those modifications just reinforce the motor from wear. If you wanted more performance, youd need to increase the displacement, lower the compression, etc.
-Freq
Freq18hz is offline
Old 07-23-2007, 06:49 PM   #10 (permalink)
slostjoe's Avatar
Skyler
The only parts on that list that could even get power at all would be Intake and Exhaust
slostjoe is offline
Old 07-23-2007, 08:53 PM   #11 (permalink)
Jardiniboy's Avatar
Jasten
Is the pistons ment for N/A or boost?
Jardiniboy is offline
Old 07-23-2007, 08:58 PM   #12 (permalink)
ZILLLAAAAAA!!!!!!!!!!
FijiPhil's Avatar
Phil
waste of money. unless ur building up the engine its pointless.
FG Squad Member #382 Tampa Crew Member #3
15% Tint///JDM FD2 Shift knob///JDM Red H emblems///Injen CAI
Join the forum where you can exercise freedom of speech and say what you want -----------> http://tampastreetracing.lefora.com/forum/
FijiPhil is offline
Old 07-23-2007, 09:05 PM   #13 (permalink)
BATANG CITY JAIL's Avatar
id say 285 whp..
BATANG CITY JAIL is offline
Old 07-23-2007, 11:08 PM   #14 (permalink)
Louder than 4 F404-GE-400
Paul
If the Pistons increase compression ratio and you put in stiffer valve springs with cams that have a higher lift and more duration and polish that head, AND get something that can tune it, I'd agree with Batang's 285
Sirbelch is offline
Old 07-23-2007, 11:27 PM   #15 (permalink)
iknowmysh1t's Avatar
forged pistons and all that other stuff is just to get your car ready for a turbo setup. then you can run full bosst pretty much.
iknowmysh1t is offline
Old 07-23-2007, 11:30 PM   #16 (permalink)
CaliGuy's Avatar
J. M. back by popular demand!
At least 500 whp, at least! Do it!
CaliGuy is offline
Old 07-24-2007, 12:29 AM   #17 (permalink)
the thing is, he said forged pistons, which means forced induction basically, theres no point in running forged pistons for NA. So im guessing either 9.5 or 8.5 to 1 compression, ideally of course. Which for the mods he listed, would LOWER hp.
damnu is offline
Old 07-24-2007, 12:31 AM   #18 (permalink)
Asif22's Avatar
Mohamed El-Mubaslat
I saw a build on an rsx-s and they gained 90hp with pistons and rods...not sure style piston or anything...But i would think that would free stuff up and just make the engine stronger
Asif22 is offline
Old 07-24-2007, 12:59 AM   #19 (permalink)
mO 64 StAnG 06's Avatar
-Freq
How would that make you gain more HP on a N/A motor?
mO 64 StAnG 06 is offline
Old 07-24-2007, 01:29 AM   #20 (permalink)
adamhoud's Avatar
Adam
It wouldn't.
adamhoud is offline
Turbo Specialties K20Z3 Extreme Turbo Kit - 290+ whp chilipepper Forced Induction And Nitrous 39 07-18-2007 05:57 PM
WHP HP to the wheels llckll Garage 12 07-06-2007 07:35 AM
Bone stock Si puts down 188 whp!!!! 954K20_SI Civic SI 36 07-04-2007 05:39 PM
AJP Turbo Kit- 376+ whp? Si Speed 317 Forced Induction And Nitrous 38 04-09-2007 06:19 PM
400 whp possible in si? CaliGuy Civic SI 6 08-05-2006 02:37 AM
