How does hydrolock work? Why? Answer is here.
Well today we learned about hydralics in class. Liquids unlike gas can not be compressed. If you are pushing 100psi of liquid in tube no matter what wall it's on it will always be 100psi.
Anyway. When water is sucked up through your intake, then throttle body, then manifold into your piston it cant be compressed inside the piston thus bending your connecting arms. Every time your intake valve opens it allows more water in. When your piston is at Top Dead Center(TDC) there is very little clearance between the top of the piston and the valves. So when you are spinning about 4000 rotations per minute your intake valves are opening 2000 times per minute since the crankshaft rotates twice to get a full repetition(intake, combustion, power, exhaust). Anyways you are pulling a lot of water in that doesn't ignite and combust so it just sits in the cylinder as you are spinning your rpms. And since liquid doesn't compress the connecting arm breaks and water is all in your engine, thus needing a full breakdown and cleaning... That's why hydrolock, hydrolocks. Last edited by KingMarineM16a4; 07-17-2007 at 07:45 PM. |
Louder than 4 F404-GE-400
Uhhhhhhhhhhh ... good effort. I already know who, what, why, when, how but someone else might not. You are going to need more that an engine breakdown and cleaning. You will need some, if not all, of these new parts, like rods (not arms), pistions, wrist pins, piston rings, rod berings, valves, springs/retainers, crankshaft, new block, new head.
#3 (permalink) | |
#10 (permalink) |
Behind Firmhonda's beard, there is only another shaved beaver.
humidity is water molecules in the air. because there is so little water, and it is also in a gaseous state, it doesn't cause hydrolock. I think the key here is that LIQUIDS can't be compressed, but humidity is the measure of water vapor in the air.
#12 (permalink) | |
#13 (permalink) | |
#18 (permalink) | |
If a car hydrolocks, the chances of not bending a rod are smaller than winning the lottery. So hydrolocking is more that just cleaning the water out. |
#20 (permalink) | |
Sport Compact Car did an article on that. The CEO of AEM put his own NSX on a dyno and they completely submerged the filter in water. The intake did suck up water for a second until enough of a vacuum was created to open the bypass valve. However, SCC made a hypothesis that if the filter was only partially submerged, there wouldn't be enough vacuum created to open the bypass valve which would cause the engine to suck up both air and water causing the engine to go BOOM!!! |
| man steals police car to get to work - lol | webby | Water Cooler | 20 | 01-03-2008 10:32 AM |
| need help! Work XT7's or XD9's | hoanger | Wheel And Tire Upgrades | 53 | 02-12-2007 03:37 PM |
| Post your work space. | Yodums | Water Cooler | 53 | 01-29-2007 02:14 PM |
| For all the people Hungover at work right now. | dmx | Water Cooler | 17 | 01-03-2007 12:19 PM |
| Dealers and warranty work | xmx250 | Driving Experience | 9 | 12-21-2006 11:52 PM |
