Old 06-25-2007, 12:15 AM   #1 (permalink)
NewYorkJon's Avatar
Jon
Question Skunk2 Pro Series TB with P2r Spacer & Gaskets
I found a Skunk2 TB online and I have some questions, should I get it in 68mm or 70mm size? and will it work with the P2R TB Spacer + P2R Gaskets(2)? And is there any advantage in upgrading the Throttle body?
Heres the link:
http://www.kingmotorsports.com/category.aspx?cat=5
Just scroll down a lil' bit
Thanks for any help you can give
NewYorkJon is offline
Old 06-25-2007, 12:41 AM   #2 (permalink)
DeVoTeD_1's Avatar
E_Flo
good stuff. In for what hp gains can be obtained!
DeVoTeD_1 is offline
Old 06-25-2007, 12:44 AM   #3 (permalink)
NewYorkJon's Avatar
Jon
I just want to know if the whole set-up can be combined, and what size Throttle Body to get: 68mm or 70mm.
If someone knows if it will all work together, I will buy it and let you all know the difference in power.
Thanks for your responses
Old 06-25-2007, 12:45 AM   #4 (permalink)
k20beast's Avatar
zack
The spacer and gaskets would be nice... but the TB isnt for dbw. soo wont work. unless its out recently. i kno it says 06-07 si but not dbw soo
k20beast is offline
Old 06-25-2007, 09:01 AM   #5 (permalink)
NewYorkJon's Avatar
Jon
o ok, never mind on the Skunk2 TB, I will probably be better off with the P2R Spacer & Gaskets anyway, Thanks for yor help
Old 06-25-2007, 01:22 PM   #6 (permalink)
k20beast's Avatar
zack
yup no problem... im think ab that and the hondata IMG soon also
k20beast is offline
Old 06-25-2007, 02:31 PM   #7 (permalink)
jmillz's Avatar
jamell
i just called kingmotorsports and they said it should be out late summer
jmillz is offline
Old 06-25-2007, 03:35 PM   #8 (permalink)
Zer0smilez's Avatar
Brett
What should be...the DBW Skunk2 TB?
Zer0smilez is offline
Old 06-25-2007, 03:36 PM   #9 (permalink)
NewYorkJon's Avatar
Jon
The Skunk2 TB is already out, in 68mm and 70mm sizes
Old 06-25-2007, 05:55 PM   #10 (permalink)
k20beast's Avatar
zack
not for our dbw tho
k20beast is offline
Old 06-25-2007, 06:42 PM   #11 (permalink)
Not for drive-by-wire-equipped vehicles it's not.
RWatters is offline
Old 06-25-2007, 07:31 PM   #12 (permalink)
NewYorkJon's Avatar
Jon
o ok, what would you think is better: Buying the P2R Spacer & Gaskets or waiting for the Skunk2 TB?
Cause right now I am probably going to be buying the P2R stuff, just wanted to be sure.
Thanks for your advice
Old 06-25-2007, 07:39 PM   #13 (permalink)
qwerty :)'s Avatar
kyle
i dont think there arnt any plans for the skunk 2 TB to be comming out anytime soon
qwerty :) is offline
Old 06-25-2007, 07:45 PM   #14 (permalink)
NewYorkJon's Avatar
Jon
ok, forget about the Skunk2 TB then, lol
Old 06-25-2007, 07:50 PM   #15 (permalink)
Unless you're making a lot more power than stock I really don't see the need for a throttle-body, anyways.
RWatters is offline
Old 06-25-2007, 08:02 PM   #16 (permalink)
k20beast's Avatar
zack
dont worry ab tb...
k20beast is offline
P2r throttle body spacer problem polgas07 CorSport 5 09-13-2007 10:38 PM
Injen CAI + P2R TB Spacer Question NewYorkJon Bolt-Ons And All-Motor 4 06-24-2007 09:53 AM
Does the skunk2 exhaust come w/ all gaskets? 86zccrx Bolt-Ons And All-Motor 1 02-19-2007 09:27 AM
