#123 (permalink) |
One Goal, One Vision, Win
Robert
I dont think so, i followed the instructions and it says 286 hp. So unless it can predict the future when my blower arrives, either i did something wrong or it can't be accurate. You need a dyno to find out the exact WHP anyway..
#125 (permalink) |
Robert
at the moment in GA its been like highs of 32 during the day, so my IAT is about 48 moving, has been 31 when the temp was 17 outside lol.
Normally about 60 stopped. The temp has got to bed about 65 outside for the next few days so i'll get back to you on the readings then :) |
#132 (permalink) |
I stand corrected. The R18 DOES cut off fuel completely under certain conditions to improve gas mileage. Here's why the old SGII never showed 9999 MPG, and the one flashed with XGage does. This is the complete response from Tech Support at ScanGauge:
Modern fuel injected engines use a neat trick to save fuel. If the vehicle is in gear and coasting (foot off the throttle) under certain conditions it will turn off the injectors. When this happens, the MPG goes to 9999 (the largest number the ScanGaugeII can display) for MPG and the GPH goes to 0.00. On some vehicles, the older program could not detect when this happened. The fuel injection would keep computing the fuel it would be injecting if it were not in fuel cutoff and report it to the ScanGaugeII. Starting with version 3.10, we added more checking for this condition. This is why you didn't see it before the upgrade. I have found on my 01 F150 that I have to turn off the overdrive when coasting downhill to get it into this mode, but then if I turn the overdrive back on, it will stay in fuel cutoff until I step on the throttle or drop below around 40 MPH. This is a neat trick to save fuel. This is why you can actually use less fuel in a modern engine leaving the engine in gear than if you put it in neutral when coasting. Ron |
#133 (permalink) |
I can't get the Fillup to work.
Last night, I put in 10liters, Scangauge showed 15.8l in the fillup screen Is that how much it thought I used or how much it thought I put in? I think either way, it got it wrong because I used up a full tank, so thats at least 43 liters but it thinks I used 15liters. Anyway, I keep having to reload defaults now cause I can't get it to figure it out. |
#134 (permalink) | |
-mr. bill |
#137 (permalink) | |
not directed at you Firestrife... i think the hood spacers would decrease Fuel Economy...you want the motor to be as warm as possible..some people even go so far as to block all openings on the front of the car to lock in the heat the motor creates |
#139 (permalink) |
^have you plugged and played with it yet?
it makes you realize what makes FE better and what makes it worse.. while driving to and from work these past couple times i've been experimenting with drafting..the only way i could see it's effectiveness is with the SGII NOTE-I DO NOT SUGGEST DRAFTING..IT COULD BE FATAL..I HAVE JUST TRIED IT FOR MY OWN PURPOSES AND CURIOUSITY.. ATTEMPT AT YOUR OWN RISK |
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/42689-anybody-sporting-scanguage-ii.html
| 8th Generation Honda Civic Forum | This thread | Refback | 12-25-2007 01:41 PM | |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
