Anybody sporting the ScanGuage II? - Page 6 - 8th Generation Honda Civic Forum
Old 01-04-2008, 02:33 PM   1 links from elsewhere to this Post. Click to view. #101 (permalink)
Tastycakes's Avatar
Originally Posted by whtdvl View Post
I can understand cutting fuel..but it would seem to me that the motor will not have power available if it is not getting gas sprayed into it.
It would make sense if the gas usage went to the same level as the motor being at idle..but not 0.00gph..
I am not saying you are wrong or that I am right...just that it doesn't make sense to me at least
Well the engine is making no power lol. The computer knows that the cars gearing and speed can keep the engine spinning, so why keep adding fuel when the wheels are spinning the engine?
Originally Posted by reelbigfish241 View Post
Yep, once i get under around 1500 or 2000 it starts reading around 200-250 mpg. but anything above that it reads at 9999 mpg.
Now what bugs me is that when I push the pedal all the way to the ground and I'm at WOT, the MPG reads 9999 and my HP reads 0.0
It's really strange. If I accelerate slowly, it'll keep up with both the HP and MPG. the highest HP rating I've gotten is 135 (R18 auto)
anybody else have this issue?
They must be using the open loop to gauge fuel shut off, cause the SG2 doesnt really know when the fuel shuts off. See when you go into fuel shut off (technically DFCO deceleration fuel cut off) the cars computer goes into "open loop" meaning that the comp doens't look at any sensor data. The comp also goes into open loop when you floor it at HIGH rpms. Under normal driving conditions the comp is in closed loop, meaning it uses data from the sensors in its calculations.
Try this, add open/closed loop to the gauges. See if the GPH goes to 0.0 every time it goes to open lp. If yea, then that sucks and the SG2 ppl used the open/closed loop to gauge fuel shut off which is kinda lame.
Tastycakes is offline   Reply With Quote
Old 01-04-2008, 03:41 PM   #102 (permalink)
mrbill's Avatar
It might be as simple as triggering on open loop, but I doubt it.
The conditions that would show fuel cutoff are one or more of:
MAP low
TPS low
LOD low
Loop Open
I suspect that ScanGauge uses more than just Loop Open to watch for DFCO.
-mr. bill
mrbill is offline   Reply With Quote
Old 01-04-2008, 04:21 PM   #103 (permalink)
reelbigfish241's Avatar
Jason dSLR Squad #27
thanks for the information, I'll definitely check that out and report my findings.
reelbigfish241 is offline   Reply With Quote
Old 01-04-2008, 04:25 PM   #104 (permalink)
Tastycakes's Avatar
Yea but if it uses TPS or LOD then the SG2 would never show fuel shut off at full throttle like it apparently does...
Old 01-04-2008, 07:24 PM   #105 (permalink)
I just went out and tried using the open/closed gauge and for the other three I used Horsepower, Gallons Per Hour, and MPG. Using that combination I went onto a 50 mph road and floored it from 0 mph (which doesn't mean much in an R18 auto, haha) This time everything worked fine. wtf. I'm happy it works, but it's weird.
I also tested it from a 30 mph roll and it worked as well. No more 9999 mpg and 0.0 HP and the GPH was still reading and didn't go to 0.
It worked when it was closed and when it was open. Highest HP I hit this time was 128 hp.
Old 01-04-2008, 07:41 PM   #106 (permalink)
truflip's Avatar
karlitO
Originally Posted by jrotax101 View Post
can you not change the units to gallons.. thats an easy way to go up quicker lol
Yea I tried it that way.. but if you set it to gallons, then change it to liters, it stays at 13.2 liters so then u gotta move it up again
Did you set the tank size correctly? It shouldn't be off by that much once its setup properly. Mines rarely off by more than 0.1-0.2 gallons per tank.
Yes, I set the tank size correctly. I ended up just reloading the defaults.
I guess i'll keep trying.
Hmm.. I hit 150hp, MT
truflip is offline   Reply With Quote
Old 01-04-2008, 07:45 PM   #107 (permalink)
^ Do you have mods?
I'm stock. I've hit 135 or around there before today. I wouldn't completely trust the ScanGauge though, I'm sure it's not entirely accurate.
Old 01-04-2008, 08:11 PM   #108 (permalink)
truflip's Avatar
karlitO
I don't know how accurate it is but I know I didn't jump for joy when I saw that number. LOL!
No more engine mods
Old 01-04-2008, 11:11 PM   #109 (permalink)
mrbill's Avatar
Wonder how long it will be before "street dyno" threads are banned?
-mr. bill
Old 01-04-2008, 11:17 PM   #110 (permalink)
I've been using the SGII for almost a year, and just had it upgraded to XGage this week. Now it shows 9999MPG when off the throttle while at speed. No way that could be right. The car never cuts off fuel completely - old wives' tale. If it did, you'd know it. You can try it sometime, just turn the ignition off at 65. Why would you need it if there is no fuel being sprayed, right? I have written the manufacturer and am waiting for a response. Has anyone figured out what the problem is? Changing the fuel type to hybrid did not do it for me.
07_civic is offline   Reply With Quote
Old 01-05-2008, 08:59 AM   #111 (permalink)
^I was gonna suggest changing the type to hybrid b/c that worked for me on my 06 LX AT...I don't know what to suggest otherwise
whtdvl is offline   Reply With Quote
Old 01-05-2008, 10:54 AM   #112 (permalink)
mrbill's Avatar
ROTFLMAO. The old wives are writing factory service manuals these days.
K20Z3:
Fuel Cutoff Control
During deceleration with the throttle valve closed, current to the injectors is cut off to improve fuel economy at engine speeds over 1,150 rpm [emphasis mine]. Fuel cutoff control also occurs when the engine speed exceeds 8,200 rpm, regardless of the position of the throttle valve, to protect the engine from over-revving. When the vehicle is stopped, the ECM cuts the fuel at engine speeds of over 7,700 rpm. Engine speed of fuel cut is lower on a cold engine.
R18:
Fuel Cutoff Control
During deceleration with the throttle valve closed, current to the injectors is cut off to improve fuel economy at engine speeds over 910 rpm (A/T model) or 950 rpm (M/T model) [emphasis mine]. Fuel cutoff control also occurs when the engine speed exceeds 6,900 rpm, regardless of the position of the throttle valve, to protect the engine from over-revving. When the vehicle is stopped, the ECM cuts the fuel at engine speeds of over 5,000 rpm. Engine speed of fuel cut is lower on a cold engine.
-mr. bill
Old 01-05-2008, 10:55 AM   #113 (permalink)
Thats Lame Y Whould You Get That?
trdracer21 is offline   Reply With Quote
Old 01-05-2008, 03:29 PM   #114 (permalink)
06ggex's Avatar
brandon
i love mine! but i wish it showed oil psi. r18 mt i've got 152 highest hp read. K&N drop in and moded air box.
06ggex is offline   Reply With Quote
Old 01-05-2008, 03:48 PM   #115 (permalink)
NcSi's Avatar
Bryan
i want one !!!!!!!!!!!!!
NcSi is offline   Reply With Quote
Old 01-05-2008, 06:33 PM   #116 (permalink)
^they are nice and it gives you an idea of what effects fuel economy and what speeds reward you the most
Old 01-05-2008, 10:17 PM   #117 (permalink)
fg2!kid's Avatar
エリク eric
how do they hook up ? through the DLC?
fg2!kid is offline   Reply With Quote
Old 01-05-2008, 11:21 PM   #118 (permalink)
mrbill's Avatar
Yes, the DLC. (OBD II connector in anything but Hondaspeak.)
-mr. bill
Old 01-05-2008, 11:27 PM   #119 (permalink)
are the Hp figures accurate? it showed me at 212 hp, and i got all the bolt-on's on my Si. Accurate to real whp or no?
mugenhonda25 is offline   Reply With Quote
Old 01-06-2008, 04:50 AM   #120 (permalink)
truflip's Avatar
karlitO
I don't see how it could measure whp without actually getting a 'feel' for the tires
Anyway, I'm getting bored of mine *yawn*
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/42689-anybody-sporting-scanguage-ii.html
Scangauge II problems - GreenHybrid - Hybrid Cars This thread Refback 04-02-2008 06:15 AM
8th Generation Honda Civic Forum This thread Refback 12-25-2007 02:41 PM
2007 Civic Performance Monitor. Help? CandyBuyDaPound Civic Coupe And Sedan 28 04-11-2008 02:29 PM
fast lenses for low light or sporting events skiz Photography 9 03-14-2007 12:20 PM
