Old 03-23-2008, 10:46 PM   #301 (permalink)
oj88's Avatar
Originally Posted by whtdvl View Post
nice vid...you should have set one of the gauges to show km/l, so it would show how that measurement jumps to 9999km/l when the injectors cut off...
The thing is, it does not provide Km/L... just L/100Km (as per post #297). I still had to do mental math to come up with Km/L (which is the more common expression for fuel economy in my country).
oj88 is offline
Old 03-23-2008, 10:53 PM   #302 (permalink)
Lucas
^well then put that(L/100km)...y you gotta give me a hard time? lol...
i like that the metric system goes by all 10's and such...i think it makes more sense...us Americans gotta be different tho
whtdvl is online now
Old 03-27-2008, 09:11 PM   #303 (permalink)
tomasro's Avatar
Turner
can someone with a fully stock r18 tell me what their MAP, IGN and LOD reading is when at warmed up idle? I got an intake manifold recently and i want to rule out some causes for a stalling problem I'm having. Thanks!
tomasro is offline
Old 03-27-2008, 10:10 PM   #304 (permalink)
oj88's Avatar
I'll get back to you later. I'll get the reading on my drive home tonight. A/C off, I suppose?
oj88 is offline
Old 03-28-2008, 03:10 AM   #305 (permalink)
tomasro's Avatar
Turner
here it is...midnight...any reading?
tomasro is offline
Old 03-28-2008, 11:46 AM   #306 (permalink)
oj88's Avatar
Different timezones. Anyway, here goes.
IGN= 8
LOD= 30
MAP= 4.2
oj88 is offline
Old 03-28-2008, 12:04 PM   #307 (permalink)
tomasro's Avatar
Turner
at warm idle your car's LOD is 30?! wow, your car is working hard to keep it idling. And is your IGN pretty steady at 8, or does it fluxuate? Thank you very much!
tomasro is offline
Old 03-28-2008, 12:25 PM   #308 (permalink)
oj88's Avatar
The IGN changes between 5-8. But it's usually pegged at 8 most of the time.
oj88 is offline
Old 04-02-2008, 09:59 PM   #309 (permalink)
Smooth Moderator
wing_gundam's Avatar
Civic Type Stock
See, I debate that getting 0L/hr is accurate...
I had that too - and I also had 0/hr when I hit Vtec.... and we know that's not right.
After a few tanks, it stopped reporting 000s, which I accept, and my proof is in the increased accuracy of the fuel used. When I go to fill up, I'm always within a few 10ths or hundreths of what I filled up, which is fine because of measurement error on the gauage, the gas reader, and what actually goes in vs drips out.
I'll take my 93-99% accuracy :)
Trying to sell? Read the updated for sale forum rules here
wing_gundam is offline
Old 04-04-2008, 10:30 AM   #310 (permalink)
Lucas
^ i am with you...
i don't think it's far fetched that the motor doesn't need fuel when you aren't applying the throttle..as long as all the moving parts are lubricated and there is a force/energy to turn the moving parts it makes sense
Old 04-04-2008, 10:46 AM   #311 (permalink)
mrbill's Avatar
There is *no* *question* that both the R18 and the K20Z3 fuel cuts at times with throttle closed. Asked and answered, source is the Factory Service Manual.
The only question is does your Scangauge II incorrectly report 0 fuel at WOT. If you are incorrectly seeing 0 fuel at WOT, play with the cutoff value.
(Okay, it'll also almost certainly get things wrong at the rev limiter too. If you are spending any significant time at rev limiter, you are doing it wrong.)
-mr. bill
mrbill is offline
Old 04-04-2008, 11:32 AM   #312 (permalink)
mattsbobo's Avatar
" I am forever!"
I know this is a stupid question, but when you clear out a CEL with the Scangauge, does it just turn the light off, or does it clear the CEL out of the ECU?
mattsbobo is online now
Old 04-04-2008, 01:37 PM   #313 (permalink)
oj88's Avatar
It's the latter.
oj88 is offline
Old 04-04-2008, 02:18 PM   #314 (permalink)
mattsbobo's Avatar
" I am forever!"
Originally Posted by oj88 View Post
It's the latter.
Why thank you very much
+10 imaginary rep
Old 04-04-2008, 09:50 PM   #315 (permalink)
anavrin351's Avatar
Tyler
will this keep track of RPMs ran on a trip? In otherwords if i drop my car off at a shop for something and they take it for a destdrive, will i be able to see if they vtaaakkked the hell out of it. The description looked like it could i would just like to make sure. I am on a spending spree for some reason, and this may be my next purchase.
Thanks
anavrin351 is offline
Old 04-04-2008, 10:10 PM   #316 (permalink)
Lucas
it will keep track of max RPM for the day...so if you only take it to 3k rpm it will remember that...you could write that number down and take a look when you get it back
if they were to unplug it b/c they needed access to the OBD2 port then i think you would lose that info...
Old 04-04-2008, 10:22 PM   #317 (permalink)
anavrin351's Avatar
Tyler
thanks
Old 04-04-2008, 10:50 PM   #318 (permalink)
anavrin351's Avatar
Tyler
just ordered one. will be here wednesday
Old 04-04-2008, 10:53 PM   #319 (permalink)
Lucas
it's a cool tool...i'm sure you will enjoy it
Old 04-06-2008, 08:38 PM   #320 (permalink)
Dave
If your ScanGauge has been unplugged it will show an * next to the values. If you're concerned be sure to instruct them not to unplug your OBD2 scanner unless they call you first.
OrdnanceMarine is offline
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/42689-anybody-sporting-scanguage-ii.html
Scangauge II problems - GreenHybrid - Hybrid Cars This thread Refback 04-02-2008 05:15 AM
8th Generation Honda Civic Forum This thread Refback 12-25-2007 01:41 PM
2007 Civic Performance Monitor. Help? CandyBuyDaPound Civic Coupe And Sedan 28 04-11-2008 01:29 PM
