#223 (permalink) | |
Specifically CANLF according to my Scangauge II. (Which if I'm understanding LinearLogicSpeak, is Long Fast, or 29-bit & 500 kbps.) Are you sure you didn't FORCE ISO? First try MORE> MORE> MODE>, scroll through and select AUTO then FORCE> I'll be surprised if it doesn't come up CANLF. Otherwise, try to force CANLF. And finally, a swag. I suspect your C1555 might be a garbled U0155, which is "F-CAN Malfunction (Gauge Control Module-Engine Control Module) (ECM)). -mr. bill |
#225 (permalink) | |
If you are still having trouble, I'd also try: MORE>MORE>MORE>USE DEFAULTS>YES To get your ScanGauge II in a known good state, then try again. -mr. bill |
#228 (permalink) |
Bottle Fed!
Well ive been at it the last hour with this POS,....and it isnt connecting! Ive tried all the combos I can think of, Slow Norm and Fast with CANLS and CANLF. Maybe im just not giving it enough time. Im gonna go put it on fast and try them again!
N2O TW FTW! ![]() 216 N/A 250.57 N2O ![]() Mid Atlantic Member# 17 |
#231 (permalink) |
Bottle Fed!
Yeah I sure did. The car is on but this thing WILL NOT connect. I see lights flashing in the dash (speedo goes to 0 and coolant gauge goes blank) but it still isnt working! Theres only one OBD2 port right? directly near the right knee under the dash! This is frustrating!
#232 (permalink) |
Mad Destroyer
The scangauge should work even if you:
-plug it in, then turn car on. -turn car on, then plug it in. should work within 10 seconds. It sounds like yours is defective. I suggest you try a known good device on your OBD2 port.
![]() ------------------------------------------------------------------ we need your vote for 8thcivic photo challenge! click here and vote please :)
#233 (permalink) |
Smooth
Um, new issue:
Free Vtec?????? So I reset to defaults b/c the gas thing was still inaccurate after my 3rd fillup. I reset everything after filling up and also adjusted the fillip from 14L to 12L fine. So I took my car on the highway tonight and accelerated a few times only to find that I was in 'free' territory: My LHK, LPH, HP all went to 0! I'm not so thrilled with my new results ![]() I'm also not so thrilled that the DTE gauge/trip thing is a little to "current" for my tastes. I like it in other cars when it tells you you have 400kms+ left in the tank, not 200kms based on current driving right after filling up. I mean I guess it's good when you're trying to get to the next gas station, but what good is the meter until then? It's not what I thought it would be. Any one else notice that? |
#234 (permalink) |
Mad Destroyer
^^ The reason it does that is it needs to get an average as you accumulate km's. I think everything gets reset to zero when you do the fill up thing then bases everything on averages. Sorry to hear its still not accurate. Don't feel so bad, it took me 5 tries/fillips to get it working right.
As for the LHK, LPH, HP all to 0, not sure whats up with that.
#235 (permalink) | |
if you were..our cars when you let off the gas and the rpm is above 1100 the ECU shuts off power to the injectors only when in gear..so you aren't using any fuel and the wheels are turning over the motor through the trans.. |
#236 (permalink) | |
Smooth
No its unfortunately the exact opposite, its when I push the car past 4000 RPMs was this happening. |
#238 (permalink) |
Bottle Fed!
Well I e-mailed the company and their being very supportive! Great customer service too! Their saying my scangauge2 will work and must be defective! So there going to send me another one, and i'll send this one back. So well see what happens.
#239 (permalink) |
Mad Destroyer
Advanced exchange? Nice!
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/42689-anybody-sporting-scanguage-ii.html
| Scangauge II problems - GreenHybrid - Hybrid Cars | This thread | Refback | 04-02-2008 05:15 AM | |
| 8th Generation Honda Civic Forum | This thread | Refback | 12-25-2007 01:41 PM | |
