Old 01-18-2008, 05:21 PM   #181 (permalink)
Photobucket
wing_gundam's Avatar
Civic Type Stock
go for it! it's a great location!
wing_gundam is offline
Old 01-19-2008, 06:44 PM   #182 (permalink)
thats actually where I ended up mounting mine, but I took the panel out of the top of that little compartment and drilled a hole in it and ran the cord through that so you cant see it at all.
AtomicLX is offline
Old 01-19-2008, 07:19 PM   #183 (permalink)
dorkiedoode's Avatar
sorry guys im new at this threat where do you plug in it? i know the telephone end go into the ScanGauge where do the main end go to?
dorkiedoode is offline
Old 01-19-2008, 07:23 PM   #184 (permalink)
truflip's Avatar
look under the steering wheel to the right where your right knee would go.
you really have to duck down there though.
truflip is online now
Old 01-19-2008, 07:27 PM   #185 (permalink)
that what i thought too cause there no where else in the car with the ScanGuage end beside under there...just making sure thank.
Old 01-19-2008, 08:51 PM   #186 (permalink)
mattsbobo's Avatar
Frank the rabbit
Actually, I went a different route. I'll post a pic tomorrow.
mattsbobo is offline
Old 01-20-2008, 12:58 AM   #187 (permalink)
truflip's Avatar
anyone else fine the cable is a bit hard to unplug?
It's not like removing ethernet cables from router/modems thats for sure (for me anyway)
Old 01-20-2008, 06:50 AM   #188 (permalink)
Bottle Fed!
WhiteSicivic06's Avatar
Ryan
Ok, im going to cave in and buy one of these for sure!
WhiteSicivic06 is offline
Old 01-20-2008, 10:58 AM   #189 (permalink)
Lucas
it is difficult to plug/unplug from the unit..
but at least you know it won't just pop out on it's own
whtdvl is offline
Old 01-20-2008, 10:59 AM   #190 (permalink)
Lucas
they are pretty entertaining...
if you care about mpg...this is a great way to see what helps and what hurts it
whtdvl is offline
Old 01-20-2008, 01:34 PM   #191 (permalink)
truflip's Avatar
thanks. at least i know im not alone
Old 01-23-2008, 11:36 PM   #192 (permalink)
Go Gators!
Firestrife's Avatar
DJ K-spec
Hey when you guys sent your scanguage II in for an upgrade how long did it take for them to get back to you? or at least contact you about your unit. I sent it in and arrived at their place last friday. And I was just curious how long it takes before they would contact you about receiving it.
IMV Films
Vehicular Lunacy at its Finest
Firestrife's Nighthawk Wonder
Firestrife is offline
Old 01-25-2008, 09:22 PM   #193 (permalink)
mattsbobo's Avatar
Frank the rabbit
Anybody who's thrown a CEL: Is the Scangauge supposed to be able to clear the CEL light from the dash?
Old 01-25-2008, 11:00 PM   #194 (permalink)
Go Gators!
Firestrife's Avatar
DJ K-spec
woot its on its way back cant wait to get hp readings
IMV Films
Old 01-25-2008, 11:09 PM   #195 (permalink)
mattsbobo's Avatar
Frank the rabbit
The hp gauge really isn't that acurate. Of course, where I have mine mounted, I can't really afford to glance down at it while I'm at WOT, turning 8k rpm's
Old 01-26-2008, 12:07 AM   #196 (permalink)
truflip's Avatar
^^ Turn the updating to slow. Then it'll stick around long enough for you to glance at it.
Old 01-26-2008, 12:25 AM   #197 (permalink)
One Goal, One Vision, Win
jrotax101's Avatar
Robert
Any of you have the P2R TB spacer?
After installing this and resetting the ECU, i seem to be getting 18.6 MPG at WOT, compared to 6mpg before.
I know the new reading isn't right purely from working it out from a full tank of gas
jrotax101 is offline
Old 01-26-2008, 01:09 PM   #198 (permalink)
Photobucket
Civic Type Stock
HP is definately not right - I showed 222hp yesterday on my stock R18!
Anyways I think I'm having other issues with it now
I did a fillup and it thought I put in 21L so I corrected to 43L (which it says was many % off), I clicked save and then the errors started happeneing.
when I went to fuel econ - it tells me that I only have 180 kms left on a full tank!!
that I know is completely wrong. Even on full city/winter/vtecing I still get 400km
plus my fuel being used has risen to more like 12L/hr instead of 1-2 as it usually is.
**** what should I do?
I want to fix the HP gauge too - mine is ridiculous
Old 01-26-2008, 01:22 PM   #199 (permalink)
truflip's Avatar
Try:
Fill up tank. Park car by gas station and load the SG2 defaults.
then set up the engine size, custom settings and what not. then drive off.
In about 100km's fill up to full tank and the more> fillup option should get it right (mine was off by .2 liters)
then fill up again in 100km's to check accuracy. mine got it right that time.
as for the HP, i thought it was cool but never thought it was all that accurate.
not sure about 222hp but you sure you don't have a K20?
Old 01-28-2008, 09:27 AM   #200 (permalink)
mattsbobo's Avatar
Frank the rabbit
This is where I mounted mine.
I hate to ask again, but isn't the Scangauge supposed to clear the CEL from the dashboard? I thought it was.
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/42689-anybody-sporting-scanguage-ii.html
8th Generation Honda Civic Forum This thread Refback 12-25-2007 01:41 PM
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests)
