Old 06-03-2007, 02:10 PM   #1 (permalink)
Install exhaust without lift?
Searched everywhere, but I can't find an answer... Is it possible to install a new cat and catback exhaust on my Si with only a pair of jackstands?
If I need a lift, then how do I go about finding one to use? It seems like almost everybody on this forum has a lift they can use... I haven't asked, but I bet my local shops in Orlando, FL (even the one I've spent thousands at) are going tell me I can't use their lifts because of liability reasons...
concept8 is offline
Old 06-03-2007, 02:12 PM   #2 (permalink)
Kill Your Self Krew
Zeuceone's Avatar
its possible but not as easy if you had a lift
is Missy a squirter?
http://killyourself1.myminicity.com/env build my city.
Zeuceone is online now
Old 06-03-2007, 02:13 PM   #3 (permalink)
is stuck at work...
SiliconX's Avatar
Eric
It is possible to do exhaust+cat with just a couple jackstands. Hoist just makes it easier.
Check your yellow pages, see if there's a do-it-yourself kinda place that rents bays. We have one here in Calgary that will rent you a bay loaded with tools and a hoist for $20 an hour.
SiliconX is offline
Old 06-03-2007, 02:15 PM   #4 (permalink)
Gr3y Goose's Avatar
Goose
yeah its possible, try installing a turboback exhaust on a lowered gti with just stands...took a long ass time but its possible
Gr3y Goose is offline
Old 06-03-2007, 02:19 PM   #5 (permalink)
Thanks for the quick responses!
I'll probably try it with the jackstands... would it be easier to install by lifting the car from the back or from the passenger side?
concept8 is offline
Old 06-03-2007, 02:34 PM   #6 (permalink)
Gr3y Goose's Avatar
Goose
just to stay safe i would try to find a lift...but put the car up where you jack the car up when changing a tire...you cant just put a jack stand on a bumper or anything
Old 06-03-2007, 02:36 PM   #7 (permalink)
qwerty :)'s Avatar
kyle
it isnt very hard to do from jackstands.. even a header isnt very hard
qwerty :) is offline
Old 06-03-2007, 02:39 PM   #8 (permalink)
it's possible,but would be easier to do with a lift becasue you have more room to move your arms and torque down bolts with.I have crawled under my car to install my axle back and have done the same when bolting by header back up to the rest of the exhaust when I(stupidly) ran an open header at the track.
bossman is offline
Old 06-03-2007, 02:39 PM   #9 (permalink)
Kurt's Avatar
I did my header and exhaust with stands
Kurt is online now
Old 06-03-2007, 02:43 PM   #10 (permalink)
UnDeRcOvErHiPpIcHiCk
Sleepy's Avatar
Susan
my exhaust was done with jackstands....It was fun to watch.
Sleepy is online now
Old 06-03-2007, 02:48 PM   #11 (permalink)
honda06si's Avatar
justin
its easy without a lift...try putting a turbo kit on without a lift
honda06si is offline
Old 06-03-2007, 02:49 PM   #12 (permalink)
If you know someone with a sloping driveway, you can park the car in a way so that when you jack it up, you get some extra clearance due to the elevation change. Just make sure that both wheels are chalked at the bottom and your jackstands are very secure. It worked wonders for me and my friend when we did my old wrx's exhaust. On and off in 45 minutes flat. Then again, we also had some air tools which made a difference...
mieczkow is offline
Old 06-03-2007, 03:07 PM   #13 (permalink)
Gr3y Goose's Avatar
Goose
been there..same gti with a super 60...took forrreverrr
Old 06-03-2007, 07:42 PM   #14 (permalink)
Yeah, my dad has a slightly sloping garage... I used that to my advantage when changing transmission fluid with only two jackstands...
concept8 is offline
Old 06-03-2007, 07:53 PM   #15 (permalink)
NA06Si's Avatar
Christian
It is a lot easier with a lift, but don't forget the air gun and the WD40.
NA06Si is offline
Old 06-03-2007, 07:55 PM   #16 (permalink)
Raging's Avatar
Got any friends in the military?? Most military bases have a DIY shop with lifts and tools that you pay to use.... If that's not an option, make friends with someone who owns a shop....
Raging is offline
Old 06-03-2007, 07:56 PM   #17 (permalink)
TampaSi07's Avatar
It took me 30 minutes once I had the car up on the stands.
TampaSi07 is offline
Old 06-03-2007, 08:24 PM   #18 (permalink)
Kidekat's Avatar
It is easy with jackstands as well. We done turbo kit install, full engine rebuilts, and even clutch replacements with only 4 jack stands, and a quality hydraulic jack.
If you want to perform work on an incline, please use wheel chock.
Keep safety in mind whenever crawling under a car. We always use the removed wheel and place under the frame just in case something should fail.
Kidekat is offline
Old 06-03-2007, 08:28 PM   #19 (permalink)
Raging's Avatar
I just can't muster the courage to crawl under those jack-stands....
Too many horror stories from ppl, but ramps are a different story for me...
Raging is offline
Old 06-04-2007, 01:56 AM   #20 (permalink)
adamhoud's Avatar
Adam
Easy, I just jacked up the passenger side on two jackstands.
adamhoud is offline
Si exhaust fits on my Fg1? Nighthawk R18 Mechanical Problems & Technical Chat 3 02-20-2007 09:26 PM
Does the skunk2 exhaust come w/ all gaskets? 86zccrx Bolt-Ons And All-Motor 1 02-19-2007 09:27 AM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 07:34 AM
