changing Auto. Transmission Fluid
i hav 26,000 km on my R18, decided to change my AMF. any suggestion for the fluid except the OEM honda AMF. i push my engin hard all the time... often Redline btw 1 - 3 gears. therefore; im looking for a better AMF...
thx for suggestion! Alex |
If you're not doing a flush, then what's the point of changing the fluid brand?? There's gonna be more than half that old fluid left inside the tranny (torque converter, oil passages, valve body.... tranny cooler, etc.) if you're just doing a drain & refill. I guess the total capacity of the ATF used in a complete overhaul is about 5 to 7 litres... at least that's how much I used when I flushed my 98 EK.
Just a thought. becuz that amount of Amsoil ATF is not cheeeeeeeep.
My experience with my past Honda auto trannies is this - - stick to the factory ATF Z1. Not cheap compared to Dexron, but cheap compared to synthetics. My friend owns a local independent tranny shop, and says to stay away from anything other than Z1...
The reason there are different ATF types isnt because of quality, or weight. It has to do with the operating heat range. Dex 3 has a different operating heat range and boiling point then Z1. Any ATF other than AUDI/PORSCHE yellow atf with a heat range that is the same as Honda Z1 or higher will work just fine.
| DIY: Changing Manual Transmission Fluid | BATANG CITY JAIL | Transmission | 380 | 08-25-2008 09:43 PM |
| Transmission Fluid | 1twojay | Mechanical Problems & Technical Chat | 5 | 03-25-2007 01:09 PM |
| Any way to check the transmission fluid? | hiphopaddict | Mechanical Problems & Technical Chat | 8 | 01-15-2007 05:18 PM |
| Kind of interesting - Honda Chronology 1946-2005 | webby | Water Cooler | 4 | 10-04-2006 09:39 PM |
| Changing tranny fluid & filter on Accord 01lx | Bugs1066 | Garage | 2 | 07-18-2006 02:24 PM |
