k24 head with our k20 block???
i currently have a 2006 civic si and was thinking about getting a k24head to go along with my bottom end.
can someone give me pro's and con's about this. im not to familiar with which k24 comes with which car and which one i should be getting for the most gains? thank you |
#6 (permalink) | |
what caused you to think a K24 head would be better? its bottom end that will help with tourque given the bigger displacement. plus unless you can get ahold of a TSX bottom end you will be giving up oil squirters that we have already with K24A1 or A4. the head on A, A2, Z1, Z3, and K24A2 (TSX) cannot flow any better and shows no gains even with port and polish since it flows to max cfm. let me know if you need further help with this... dont go waisting your money on pointless stuff. |
#8 (permalink) | |
before my FA5Si i had a ITR K20a swapped EP and before wreck i was considering Z1 head and manifold with my PRC cams and spring to give me more gains. on KPRO of coarse. curious about EP setup here's a link... http://www.ephatch.com/forum/showthread.php?t=120843 |
The K20/K24 is a great combo!!! I built a K20A2-(RSX TypeS Head)/K24A1-(02 CRV Block) with 11:1 CP Pistons, ACL Main and Rod Bearings, Carrillo A-Beam Rods, Removed Balance Shaft Oil Pump (replaced with K20A2 Pump), K20A2 Aluminum Oil Pan (5.5 Quarts). Tuned with K-Pro (also by me) made 244whp and 186wtq on STOCK K20A2 Cams, DC TSX Race Header, Custom CAI, and Custom 2.5 Exhaust. 04 RSX Type-S Transmission with Quaife LSD on BFGoodrich Drag Radials in a 94 Civic CX Hatch ran 12.6 at 109.5 MPH all motor. Never got a chance to run it on the gas before I sold it or turn it higher than 8000rpm.
I still have 2 Complete K20A2 Blocks and 1 Bare K20Z3 Block still in the box/plastic that I am thinking about building and will install it in my 07 Si as soon as the warranty is gone. I am glad that Honda went to a MAF instead of just MAP it will be so easy to tune the A/F Ratio. |
#10 (permalink) | |
I agree MAF FTW! |
#11 (permalink) | ||
I remember seeing a TSX with engine management in it and they swapped out the gagues for aftermarket one since there was no engine managent for the TSX, maybe something like this could be done with the Si |
#12 (permalink) | |
#13 (permalink) |
you really wouldnt see any horsepower gains. if anything, you'll just run into fuel management problems and throwing off the ecu. the k20 head opn a k24 bottom would be better. its like putting b16 head on a b18 or doing a gsr head on a b20 block. i say just do the k24 swap. that way, you'll have more options as to what you can do performacne wise versus gettting parts for an si motor.
#14 (permalink) |
| Who was reluctant to go K20? | GalaxyGreySi | Garage | 4 | 01-20-2007 10:15 AM |
| new head unit need help please | civic4ever28 | Inside and Out | 5 | 12-29-2006 12:49 PM |
| song stuck in my head | imtim25 | Water Cooler | 6 | 10-12-2006 02:02 AM |
| Long Block or Short Block?? | WhiteAsian | Bolt-Ons And All-Motor | 2 | 08-22-2006 07:17 PM |
| so a human head in your luggage is bad? | webby | Water Cooler | 5 | 02-15-2006 12:34 PM |
