Check Engine Light Results - 8th Generation Honda Civic Forum
Old 03-04-2007, 12:39 AM   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Type_R_Nammer's Avatar
Jason
Now that I finally got my lazy butt up, brought it to the dealership to find out what's throwing the CEL with the aftermarket intake.
"Codes indicating the MAF Signal Voltage is low and Fuel Metering Problems"
Is there any way to solve this problem now?
EDIT: It's a Fujita SRI on an Acura CSX
Type_R_Nammer is offline
Old 03-04-2007, 12:54 AM   #2 (permalink)
freakvision03's Avatar
Kevyn
do you have the AEM intake?
freakvision03 is offline   Reply With Quote
Old 03-04-2007, 12:59 AM   #3 (permalink)
Jason
Fujita SRI
on an Acura CSX
Type_R_Nammer is offline   Reply With Quote
Old 03-04-2007, 01:53 PM   #4 (permalink)
drexp2000's Avatar
Did they provide you with a CEL code? (usually starts with a P### or a DTC ##-##)...
drexp2000 is offline   Reply With Quote
Old 03-04-2007, 07:12 PM   #5 (permalink)
does that mean that your intake is malfunctioning or does it mean that you MAF sensor isnt use to the SRI?
Siwhiteboy is offline   Reply With Quote
Old 03-04-2007, 09:09 PM   #6 (permalink)
Jason
nope, that's all it says on my invoice
Old 03-04-2007, 09:29 PM   #7 (permalink)
drexp2000's Avatar
Well did you have them clear it? If you cleared it and if it doesn't come back on, you're OK at this time...
According to the Service Manual, that MAF Sensor code is a DTC P0102. I can't find a code with Fuel Metering problem... There's a whole procedure on troubleshooting this problem out... But the basics include: Check for poor connections or loose terminals at the MAF sensor and the ECM. Maybe even take out the MAF sensor and make sure the little probe on it is not soaked in the oil or dirty from the air filter (it could happen..)
Old 03-04-2007, 09:31 PM   #8 (permalink)
Jason
They cleared it and came back on afterwards =p
Ok thanks for your help!
I'll try to figure out everything from here
Old 03-04-2007, 10:39 PM   #9 (permalink)
m1k3's Avatar
my old AEM CAi was throwing a similar code.
'fuel metering to lean' it was like p0171 and it was directly related to the maf sensor.
does your intake have an indent where the maf sensor goes or is it hte same diameter all around?
m1k3 is offline   Reply With Quote
Old 03-04-2007, 10:44 PM   #10 (permalink)
Jason
photo for reference
Old 03-05-2007, 10:06 AM   #11 (permalink)
it's the same diameter all around (not like injen)
I have the same problem on my CSX
kinda weird
Max2.0 is offline   Reply With Quote
Old 03-05-2007, 10:56 AM   #12 (permalink)
baz938's Avatar
try renistalling the MAf and make sure that it is fully insereted into the slot...its kinda a tight fight but it seels the hole pretty good..
baz938 is offline   Reply With Quote
Old 04-18-2008, 07:47 PM   #13 (permalink)
Well I have the same problem (P0171) on R18 with K&N Typhoon... basically just comes on once a week or every two weeks, stays on for a couple of days and goes away on its own. Reseating the battery cable works too, but gets old after about 5 times. Had dealership reprogram ECM/PCM today, if that doesn't work (and it comes back on) they tell me I'll have to put it back to stock or it won't be covered under warranty.
flyride is offline   Reply With Quote
Old 04-19-2008, 05:00 AM   #14 (permalink)
mad monkey's Avatar
Jeremy
CAI in general causes the motor to run a bit lean. Though there are a few out there that seem to richen the A/F. As for your intake, Fujita is the leanest running SRI out there. Most likely how deep they have the MAF mounted into the pipe. Best thing you can do is clear the code, remove the MAF and make sure it's clean and assure that it's fully seated into the housing plate. One thing I have seen is when people install they MAF into the housing plate, the O-ring on the MAF has a tendency to stick in the bore of the housing causing it to not go in as far. Give a light coat of some WD40 on it when you re-install it.
mad monkey is offline   Reply With Quote
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/30967-check-engine-light-results.html
Throwing a CEL? - 8th Generation Honda Civic Forum This thread Refback 12-11-2007 04:00 AM
HID Retrofit Progress Tim Lighting, H.I.D.'s, & Neon 106 08-02-2007 02:04 PM
Engine conversion Enderz Civic Coupe And Sedan 14 03-28-2006 09:15 PM
Check engine light Wrathchild Civic Coupe And Sedan 6 12-19-2005 12:41 PM
