Old 11-25-2006, 03:49 AM   #1 (permalink)
FlyWheel Upgrade
I really want to upgrade to an ACT Prolite flywheel in my Si, but I need to know if I can change the flywheel with out changing the clutch. I've heard that it will not cause any problems to change just the flywheel, but then I have also heard that due to the design of the stock flywheel, the clutch and flywheel must be changed together. Can anybody clarify this issue please?
dannyboy's06Si is offline
Old 11-25-2006, 05:28 AM   #2 (permalink)
eugenekim.net's Avatar
captain obvious
i know im not answering your question but why would u want to change the flywheel without changing the clutch? i dont see the logic in choosing to change just the flywheel.
eugenekim.net is offline
Old 11-25-2006, 09:54 AM   #3 (permalink)
Shark Tek's Avatar
That is like changing your timming belt without touching the belt tensioner and water pump.
Install both things (flywheel, clutch) you will save a lot on labor fees and time. Unless that your doing it by yourself but I recommend (ex auto part advisor) changing both things since you have to remove the clutch in order to access the flywheel, that is the reason of why people are telling you this.
Shark Tek is offline
Old 11-25-2006, 10:15 AM   #4 (permalink)
makes more sense that way..................thanx
Old 11-25-2006, 11:57 AM   #5 (permalink)
dREsTrUcTiON's Avatar
Do the clutch and flywheel at the same time.
Also, ACT doesn't seem to be a good brand for K series transmissions. Many people have had trouble with them.
dREsTrUcTiON is offline
Old 11-25-2006, 12:51 PM   #6 (permalink)
Shark Tek's Avatar
I had a very good experience with Clutch Masters kits, I never hear bad things about them. But unfortunately they don't have a kit for our cars.
Old 11-25-2006, 02:57 PM   #7 (permalink)
Im Pogi...Ur Not
pogi666ako's Avatar
Pogi
Originally Posted by Shark Tek
I had a very good experience with Clutch Masters kits, I never hear bad things about them. But unfortunately they don't have a kit for the our cars.
You know its the same kit as the RSX-S right?
REVS 2
pogi666ako is offline
Old 11-25-2006, 11:46 PM   #8 (permalink)
Shark Tek's Avatar
Really !?!?
Who try it in a K20Z3, what about the ClutchMaster flywheel?
Old 11-26-2006, 01:17 AM   #9 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
Heard good shit about exedy on k-series. Would be my 1st choice is I had a K
fa1 is offline
Old 11-26-2006, 10:28 AM   #10 (permalink)
F.I.A.T's Avatar
Really !?!?
its the same transmission assembly as all the rsx-s except it has the countershaft driven speed sensor. the clutch kits for the rsx-s work just fine. Nox has a ACT flywheel and clutch in his car. as well as we carry our own flywheel as well as clutch kits to support our products.
F.I.A.T is offline
Old 11-26-2006, 10:30 AM   #11 (permalink)
F.I.A.T's Avatar
Exedy make the oem clutches for your car. unfortunately the dont hold any real power unless you invest in a hyper single or twin plate. the averarge owner would like it just fine. a turbo fg2 would benefit more from a different brand clutch.
F.I.A.T is offline
Old 11-27-2006, 01:03 AM   #12 (permalink)
silvsi24's Avatar
Matt
If you change out the flywheel you cant use your stock pressure plate i dont think so i would recomend changing the clutch disk too, buy an assembly
silvsi24 is offline
Old 11-27-2006, 02:15 AM   #13 (permalink)
Hotwheels's Avatar
Chris
Try this out
http://www.exedyusa.com/race/car_make_search.asp
Exedy Lightweight Racing Flywheel
Product Image May Not Be Vehicle Specific
Part Number: HF02
EXEDY Racing Flywheels are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response.
Most incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel.
no prices tho
Hotwheels is offline
Old 11-27-2006, 10:59 PM   #14 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
We still have excellent deals going on for Exedy clutch and flywheel combos that are perfectly driveable :) Check our vendor thread or PM for details...
Jonathan - www.z1auto.com - 631-863-3820
GT-SPEC FENDER BRACE PRE-ORDER!
http://www.8thcivic.com/forums/z1-pe...-preorder.html
Check out our BLOG for:
-Customer rides
-New products
-Original articles
Z1 Performance is offline
Old 03-28-2007, 03:43 AM   #15 (permalink)
Hello... Any feedback on clutch master clutches?
I understand the flywheel is not out yet for the 1.8L version...
beck7777 is offline
Old 04-21-2008, 02:47 PM   #16 (permalink)
Jeremy
I have a clutchmasters stage 3 on my 1997 Maxima 3.5L (segmented kevlar with a 2400lb pressure plate) on a proto 6.8Lb flywheel. I love that clutch to death! I would definitely do clutchmasters when I put my Toda Flywheel on my car. The only thing is I don't want a pressure plate that heavy on my Civic. It's a daily driver and a pressure plate that heavy will give you a workout.
Zigg is offline
Old 04-21-2008, 03:24 PM   #17 (permalink)
You might want to look into Fidanza as well. They have alot of cutting edge clutches and flywheels for all different power applications. They can provide the right set up from street to strip and everything in between.
1osunut is offline
Stock Nav Upgrade? 8thCivicNut I.C.E., Electrical, Security, & Navigation 3 08-23-2006 12:28 PM
Factory Alarm Upgrade Pics 2006civic808 I.C.E., Electrical, Security, & Navigation 16 07-31-2006 01:30 PM
ACT Clutch Kits, Flywheels and Greddy SP2 Exhaust skittleslegend Civic SI 43 06-22-2006 07:34 AM
what performance upgrade should i do 1st icycivic Inside and Out 0 04-24-2006 03:57 AM
