Old 11-19-2006, 04:25 AM   #1 (permalink)
What makes a type r motor?
jus wondering if the 06 si and the type r DC5 motors have compatible parts so the we can convert the K20z3 into a type r motor?
thanx
losboyfg6 is offline   Reply With Quote
Old 11-19-2006, 01:38 PM   #2 (permalink)
Moderator
sickyute's Avatar
Marvie
the k20z3 is a type R motor...
see the new EDM type R hatch....k20z3 is utilized.
but to answer ur question...the parts from the dc5r can be used.
but there's no point in using them as the k20z3 has dynoed better stock than the z1(which is said to have type r cams).
i'd suggest u use cams for the 2006 tsx....both intake and exhaust...they are the most agressive honda oem cams
what other parts would u be looking for?
Shift when it blinks!
Old 11-19-2006, 01:51 PM   #3 (permalink)
blaznhot_23's Avatar
MS Motorsports kicks ass!!!
are 06 tsx cams compatible with stock ecu??? wouldn't it throw the idle off a little becuase you have a cam with a different profile than stock...
blaznhot_23 is offline   Reply With Quote
Old 11-19-2006, 01:54 PM   #4 (permalink)
RWatters's Avatar
While I don't know the exact measurements, I can't imagine it'd be a HUGE change over stock so the ECU should cope with it fine. Hondata said it can be used with the stock ECU or the Hondata reflash fine so it should be okay. The question is if the differences are enough to require further tuning to fully utilize the different camshafts, though.
RWatters is offline   Reply With Quote
Old 11-19-2006, 01:59 PM   #5 (permalink)
how much hp can you get from a tsx cam swap??? is it worth all the hassle?
Old 11-19-2006, 02:01 PM   #6 (permalink)
Moderator
sickyute's Avatar
Marvie
nobody knows...
everyone just throws out numbers...
it's just a known that u will make power...with proper tuning u'll be able to make even more...
till someone does it the right way and reports back...we'll never know.
Old 11-19-2006, 02:11 PM   #7 (permalink)
actually marvie the type r intake cam has a higher lift in vtec(high cam profile) than the tsx intake cam. the tsx intake cam has a higher lift on the low cam profile tho, so you'll have a little more low-end torque.
the exhaust cam is bigger over all so that's definitely the one to go with.
Old 11-19-2006, 02:21 PM   #8 (permalink)
how much does a set of tsx cams go for?? what about the reflash if you need it?
Old 11-20-2006, 04:25 AM   #9 (permalink)
so why does the DC5 make 220 hp and the si makes 197?
Old 11-20-2006, 08:46 AM   #10 (permalink)
dREsTrUcTiON's Avatar
Higher compression (11.5:1)
dREsTrUcTiON is offline   Reply With Quote
Old 11-20-2006, 09:32 AM   #11 (permalink)
Moderator
sickyute's Avatar
Marvie
higher compression.
different standards for calculating BHP...had we been on last years method of calculation, the Si would be over 200hp.
that amongst other things i'm sure.
Old 11-20-2006, 11:51 AM   #12 (permalink)
yep they changed the rules for advertising HP when the new si came out. SAE wanted the advertised HP to be more accurate. they did this before when automakers would advertise crank HP without any accessories connected.
plus the type r would be tested differently in a different country.
dannn is offline   Reply With Quote
Old 11-20-2006, 03:16 PM   #13 (permalink)
higher compression.
hey did that hytech kit come out yet and how much is it gong to be? also is it reliable and a strong setup somthing i wont regret later on?
Old 11-20-2006, 03:19 PM   #14 (permalink)
Moderator
sickyute's Avatar
Marvie
i have no info. on the hytech setup...
sorry can't help u there.
whatever they release will be of high quality though...it will be pricey and will not give u big power per se...but it's an NA setup...u'll pay for what u get.
Old 11-21-2006, 12:35 AM   #15 (permalink)
KingMarineM16a4's Avatar
David
A. It was 210.
B. After the ratings were changed it was 200 and the si was 197. Pretty close bhp.
C. Still identical whp numbers on dynos.
KingMarineM16a4 is online now   Reply With Quote
Old 11-21-2006, 02:02 AM   #16 (permalink)
fa1
fa1's Avatar
FA Squad Member #17
k20z1 = 210hp / new SAE rating 201hp
k20a1 = 220hp (DC-5R motor)
k20z3 = 197hp / <<SAE rating
Old 11-21-2006, 04:42 AM   #17 (permalink)
did ne one see the car and driver review?
the 05 type s go 0-60 in 6.4 and the si goes 0-60 in 7.3
and the type s getting a 14.9 qt mile
i kno that there are many other comparison test but most of the tests out there prove the the type s is faster.
dont get me wrong, i love the si i just ordered my asm. but u guys are saying there so much alike so then why in all these reviews say the type s faster?
jus let me kno
thanx
Old 11-21-2006, 08:50 AM   #18 (permalink)
k20a = 220hp (DC-5R motor)
Corrected. JDM motors don't have a number after the last letter.
Old 11-21-2006, 10:23 AM   #19 (permalink)
civsnake's Avatar
English Classassin
jus let me kno
thanx
You can't really base the performance of a car off of one test in one magazine. There's a thread in the racing section where a person claims a <14.3 quarter mile in a bone stock Si, and many other magazine tests have seen the Si get to 60 in <7 seconds. Remember, C&D is giving you their best of the very short time they have the car. I've driven both cars and I can't tell you which is faster down a straight line. I can tell you that the Si handles better despite being slightly heavier. In fact my friend has a stock RSXS and I regularly beat him in just about everything driving related in my stock Si.
civsnake is offline   Reply With Quote
Old 11-21-2006, 11:01 AM   #20 (permalink)
Shark Tek's Avatar
And adding to that ...
The SI needs to get into 3rd to 60MPH thanks for the High Ratio Differential the Type-S don't need to shift into 3rd.
Shark Tek is offline   Reply With Quote
Official pics of the new Type R FujiBlueSi Garage 22 03-03-2007 08:48 PM
Kind of interesting - Honda Chronology 1946-2005 webby Water Cooler 4 10-04-2006 09:39 PM
Honda Announces new Civic TYPE R Euro........... sfccrx Civic SI 2 09-16-2006 12:05 PM
Honda Civic Type R Europe. RODSCIVIC Garage 45 09-16-2006 01:19 AM
Motor Trend Announces 2006 Car of the Year webby Honda Industry News 0 02-04-2006 12:49 AM
