#42 (permalink) |
John
here we go.........eBay Motors: 04 05 06 07 ACURA TSX 2.4 K24A2 ENGINE (item 110243470204 end time May-14-08 15:47:55 PDT)
already a start.... |
#43 (permalink) |
If you use the 06 TSX block you will not have to bump compression at all to make 250+. The TSX is already at 10.5:1 or it might even be at 11:1 already. Use the TSX cams and all the basic bolt ons such as pullies, race header, exhaust, intake. And you should be close to the 250 mark. But I would recommend the X intake or the stock MAF housing with an Apexi filter. This will let the MAF sensor work perfectly to keep safe AFR's with the TSX block and cams. I read a thread where Doug from Hondata did this swap and with the stock MAF housing the stock ECU was able to keep the AFR's extremely safe without any tuning. Just a little extra info that I forgot in my first post. But if you want to up the compression I would recommend some kind of piggyback ECU for now. Or you will definately blow something up.
#44 (permalink) | ||
I do look like a monkey
The ports flow the same. We have a stronger valve train for the higher redline.
I'm currently in the making of a DIY frankenstien conversion. Stand by for the thread!
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG Last edited by mad monkey; 05-01-2008 at 11:39 PM. |
#45 (permalink) |
Louder than 4 F404-GE-400
With the "standard" driveline loss of 12% for a fwd car, 221 to the wheels is 247 at the fly wheel. Thought it might help with some comparisons.
Waking up dead inside of my head will never never do, there is no med, no medicine to take. I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break. |
#47 (permalink) | ||
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG Last edited by mad monkey; 05-02-2008 at 02:29 AM. |
#48 (permalink) |
^^^ Hence the quotes around "standard" when I used 12% to do the math. Its not perfect, its an used estimate. If he put down 221 and the cars in your area average 181 that's a 40 hp gain which is only 2.7% off of the estimate I came up with. That's not to shabby for a guess. Also, when you had torque, you add hp. hp = (tq x rpm)/5252.
Waking up dead inside of my head will never never do, there is no med, no medicine to take. I've had a chance to be insane, asylum from the falling rain. I’ve had a chance to break. Last edited by Sirbelch; 05-02-2008 at 03:01 AM. |
#52 (permalink) | |
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG |
#53 (permalink) | ||
Pit Stop !?
Indentical head, different cams and valve springs
![]() For a few dollars more you can have oil squirters, better internals and a higher compression ratio. Definitely build the K24A3/4.... Rod bolts would be good enough for mild to moderate K24A2 set-up. Youd definitely make more power with the A2 vs any other K24 block. You couldn't be further from the truth. Perhaps you should say "we have nothing plug and play to tune with." Undoubtedly you are referring to K pro. There are so many methods to tune the FA/FG platform it's not even funny. It's all the cry babies that are whining about not having plug and play. Either rewire your car or shut up and wait. Quote:
![]() I dont know if we are talking about the same guy but I have seen a guy around with a CRV block, intake, DCRH, Reflash and emanage ultimate tuned. Then he was putting about 210 down Did he use the CRV oil pump?
#54 (permalink) |
If you're going to build a 9-10k rpm NA monster with forged rods, pistons etc), you certainly don't need or want the oil squirters! I believe the CRV block (A4) doesn't have the squirter ports drilled out, and being that it is cheaper than a TSX block (A2), it makse sense to start from here.
#55 (permalink) | |
#56 (permalink) |
I just guessing here, but for a race engine, oil squiters could cause more friction and add weight to the rods/pistons which will only slow the engine down. Are we talking about a big drop in hp, probably not, but if it is a race engine, every hp helps.
#58 (permalink) | |
No, he used the rsx-s oil pump and chain to delete the use of the balance shafts. Correct, in race applications alot of times the squirters are blocked off not just because consistent oil pressure is needed but majority of the aftermarket piston skirt designs hit the jets themselves upon intake and combustion strokes. People usually catch it when they're doing their final spin check before installing the oil pan on their build.
My Mods: Home made CAI, BCRH, QTP Electric Cutout, P2R TB spacer and thermal gaskets, Hondata IMG Last edited by mad monkey; 05-05-2008 at 12:05 AM. |
#59 (permalink) | |
I appologise if I caused some confusion, I thought that the thread starter wanted to use jest the K25 block & install aftermarket pistons & rods. I agree, if you going to use stock Honda parts then go for the TSX short/long block.
Oil cooling does add a measure of reliability for a stock engine with cast pistons and manufacturers include them for just that very reason. However, forged pistons in an n/a application don't really need this. Quote:
