Skunk2 Installed, small prob
Installed Skunk2 catback today, took about an hour, used jackstands on the passenger side and was able to access the whole thing. The skunk parts matched up perfectly with the stock parts in terms of hangers and such. Only problem was it seemed like the 3 bolts on the cat were machine threaded in and i couldn't break them loose. So i used those bolts and just put the nuts on them, only thing was these bolts didn't extend all the way to the end of the nuts, but it was secure as hell, figured it was fine
Started driving home, sound was great, extremely loud but a very nice deep sound, didn't get raspy at any RPM, and sounds its absolute best at midrange and on the switchover to the performance cams. Drive home from the garage i was doing it in was around 7-10 miles, near the end of the trip i could hear some vibration, sounded like the exhaust was bouncing a bit and rattling. Pulled in the driveway to check it out but couldn't see anything in terms of rattle. Took it for a drive down the road, it was fine for a while then the vibration started again. It got bad enough that it was rattling where i could hear it very easily. Pulled in, prodded it a bit trying to find where and why it was hitting but i couldn't, gonna get it up on a lift tomorrow when the places are open. Every hanger was secure and bolt bolted on to extreme tightness. The only thing i could come up with was that being that i used the bolts that were already sticking out of the cat, and that they didn't extend all the way thru the nuts (even though they were tight) that once i'm hitting bumps it's causing the pipe extending from the cat to move, i dunno i can't think of anything else i just wondered if anyone had any ideas on what it could be or has had an exhaust rattle right off the bat before. Thanks in advance. (BTW once i get this resolved i'll post pics of the install as well as vids) mods so far (AEM sri, and skunk2 catback obviously) |
ya i too used the bolts connecting the cat to the piping...i couldnt take the bolts out so i took the whole cat and piping up the axle out and unscrewed the cat off the piping..i then had to hammer the bolts out to use them on the dcrh and new exaust..no rattles..just sometimes when i throw it in reverse or take off...and that rattle is like below my shifter..i think it might be a heatshield....or jsut engine rocking. Yea man check all your bolts, get under the car and move the piping up and down and around to see if it does or can come in contact with any heatshields or any part of the car to that matter.
good luck with the rattle though...maybe it will go away |
are any of you planning to go boost? 70mm is typically F/I terriroty. i dont know if all of you can feel it, but there's definitely backpressure power loss at 4000rpm and under with this exhaust installed on a stock Si. i just emailed skunk2 to see if installing aftermarket cams would help the engine utilize this exhaust better (i know an intake and header wont be enough for sure). otherwise, im putting mine up for sale (since i dont plan on boosting).
well my setup is fujita SRI, DCRH, Tanabe touring medallion and i feel the power great...I dont feel any power loss...total opposite i feel a gain. When i just had a muffler tip welded on, i did feel a loss in power..even when i put my intake in..but it was very slight...Now that i got the i/h/e going it feels good.. Also you tip if your tip is more than like 3in yea your gonna be loosin power..your car is gonna be super airy with no turbo
#8 (permalink) | |
#11 (permalink) | |
let me know if u go through with selling your exhaust! im actually planning on getting a skunk2 exhaust too so the better price i can get it the better for me! |
#12 (permalink) |
well i'm pretty sure the K20 responds differently to larger exhaust diameter w/o boost. the AJP full 3" catback actually showed top end gains w/o boost. check out the dyno graph: New exhaust on the market. (AJP)
#13 (permalink) |
well yea with any exaust system you do end up gaining top end power but at the sacrifice of low and mid range power...w/o any other performance peice like an intake or header..especially without boost. you gotta see how a car works..basically it sucks in air and at the end it lets air out...if your getting a performance exaust your letting that air out better..quiker and more efficiently...so what about at the other end? if you got that air coming out nicely and faster then you gotta have something sucking more and better air so it can be even better and make up for that loss...which by the way wont make up completely
#14 (permalink) |
OK so is the midrange power loss really that noticeable? Because something like that would piss me off. When I did a catback on my Mazda 3 I gained power everywhere in the revs. The skunk2 system souds so damn good compared to the Touring Medallion, but nobody has said anything about midrange loss with that exhaust.
#15 (permalink) | |
"..When we dynoed this Exhaust system we showed gains across the RPM range. intake, header and camshafts would give this system even a better feel and provide more HP." the last portion was a response to me asking if the exhaust would work better with more mods such as cams, I/H. |
#16 (permalink) |
*All Motor Beast*
i have tha whole setup on my car except... i have a greddy evo2... and im selling it... and im buying tha skunk 2... but i think it should work better with tha setup i have now... which is i/h/e... you guys are making me doubt gettin this exhuast..... errr.... and does skunk 2 have cams for our car?? just askin???
#17 (permalink) | |
#18 (permalink) |
put it up on the lift and moved the midpipe away from the heatshield, start driving today and the rattle comes back occasionally
going to look more into the rattle tomorrow as for performance, i have an AEM sri (not going CAI until i can get one with a bypass valve) and the skunk2 catback, no noticeable losses but seems to perform much better at WOT throughout the full RPM range |
#20 (permalink) | |
| Skunk2 exhaust installed | adamhoud | Bolt-Ons And All-Motor | 7 | 09-16-2007 08:52 PM |
| a question about skunk2 shift knob... | oda11 | Mechanical Problems & Technical Chat | 43 | 08-07-2007 03:49 PM |
| TWM Short Shifter + Bushing Installed | Shiznet | Bolt-Ons And All-Motor | 2 | 10-05-2006 11:27 AM |
| just installed... | imtim25 | Bolt-Ons And All-Motor | 10 | 09-21-2006 02:32 PM |
| Skunk2 Parts | twistedframe | Civic SI | 5 | 02-24-2006 01:31 AM |
