#1 (permalink)
Throttle Body Coolant Bypass On ((R18))
hi guys ...
i'v been think'n about this trick thay call it Throttle Body Coolant Bypass i think most of you guys know what it is so i learned this trick yesterday and i have a DIY guide too ((not for the r18)) but it will help and iam ready to do it ... my question's are :::.. 1- is this trick going to damage any thing in my car ????? any thing at all ??? 2- did it work on any of your civic's ??? any deffrence ?? 3- did you feel any thing deffrent even on any other car ?? 4- if its going to help ... why it didn't came like this from the factory ??? 5- any thing you want to say about this trick ??? this topic is on other forums too ((by meee))
1. it might freeze up your throttle body in cold climates.
2. i did it on my si. no power difference at all. 3. i've only done it to the si. 4. i'm guessing they run coolant through the throttle body so it won't freeze up in the winter times in some parts of the country. you can always reverse it when winter time comes though. 5. it's harder to do on an r18 than an si. i was going to do it to my friend's r18, but it looked like a lot of work. the bypass on the si takes like 10-15 mins. |
Unless you still have the stock intake system in the R18, it shouldn't take more than 5 minutes.
I was able to re-route the existing line and bypass it without spending a dime. I didn't notice any difference though, but im sure it made on on paper no matter how minute. |
I did this on my Supra, didn't actually bypass but had those passages welded shut on the intake and return pipe. Biggest benifit was that now I had less hoses to break and taking things apart was _much_ easier. It took forever just to get those hoses off the TB, and then you have coolant everywere. Now I can tear down in about 10 minutes to the cams with no mess! With no performance benifits, unless you get similar time saving benifits I would leave it alone.
-Mike 07 SSIP http://www.CygnusX1.net/Civic |
#9 (permalink) | |
Or description? Looks like some other lines run to or from the TB as well. Didn't check to see if they were coolant or vacuum. |
#10 (permalink) |
Man, from what I can remember, there are only two lines that go to the TB. Both of which are also connected to the engine. Both of them are coolant lines.
What you want to do is re-route the lines where both TB inlets/outlets are connected together by one hose. And the same for the two inlets/outlets on the engine. Fairly simple. |
#13 (permalink) | |
Idk what DIY your using but when you connect the new coolant lines, CLAMP{ THE CRAP OUT OF THEM! |
#14 (permalink) | |
#19 (permalink) |
dude im looking at your diy, and it seems like you did alot of things that arnt necessary? am i correct? you were just being super safe?
and about the little filter, if you have an aftermarket intake you've already taken that thing off and its now attached to your new intake ex. my injen CAI So i wouldnt need to do that step at all. But would i be able to just use the original long hose and connect it to the other engine port? then did you cap off the two throttle body ports? Do you know what size caps i would need for those? |
LinkBack to this Thread: http://www.8thcivic.com/forums/bolt-ons-all-motor/18687-throttle-body-coolant-bypass-r18.html
| DIY: Throttle Body coolant by-pass... - Page 2 - 8th Generation Honda Civic Forum | This thread | Refback | 01-23-2008 06:44 AM | |
| Just a thought about our throttle body | legendman | Civic SI | 12 | 10-02-2006 01:12 PM |
| TB Coolant bypass. | muxtang67 | Bolt-Ons And All-Motor | 1 | 09-20-2006 12:23 AM |
| How to install heat shield intake gasket and bypass TB coolant on 06 si. | 06redsi | Civic SI | 30 | 08-16-2006 10:20 PM |
| Big-Bore Throttle Body for the K20 | Ep3racer954 | Forced Induction And Nitrous | 2 | 02-12-2006 09:07 PM |
| 06 si vs 02-05 rsx intake manifold and throttle body.. | OneSi | Forced Induction And Nitrous | 11 | 12-28-2005 08:02 PM |
