Problem with O2 sensor using defouler - 8th Generation Honda Civic Forum
Old 07-03-2009, 06:06 PM   #1 (permalink)
Unhappy Problem with O2 sensor using defouler
Hi,
I have 08 siand I just made the installation of my vibrant w/hfc header with strup defouler yesterday. Everything goes right but today the check engine came out. I went to autozone and after put the car code reader, the problem was the O2 sensor. How can I have problem with this sensor if I am using a defouler? and what can I do??
thanks
yoefg08 is offline
Old 07-03-2009, 06:11 PM   #2 (permalink)
Si-Onara
JEA86's Avatar
Jeremy
it can still trip the sensor. mine did
JEA86 is offline   Reply With Quote
Old 07-03-2009, 06:24 PM   #3 (permalink)
humboldt1498's Avatar
Forrest
Why even run a defouler? I have a vibrant header w/hfc with no defouler and have never thrown a cel and I have put over 15K on my car since the header.
humboldt1498 is offline   Reply With Quote
Old 07-03-2009, 06:27 PM   #4 (permalink)
Zeuceone's Avatar
i wouldnt use a defouler if it has a HFC. take the defouler off and just put the 02 sensor on without it.
Old 07-03-2009, 08:20 PM   #5 (permalink)
sivtecboi80's Avatar
Nick
Hey i been hAVINin the same problem with mine i ran a random tech cat with vibrant exhuast for the longest time with no problems and no i have the vibrant heade rwith cat and angled defouler and been cel light
sivtecboi80 is offline   Reply With Quote
Old 07-03-2009, 08:21 PM   #6 (permalink)
Zeuceone's Avatar
what????
Old 07-03-2009, 08:22 PM   #7 (permalink)
NewBernSI's Avatar
I have a CEL every once in a while. Strup. I just reset the ECU and usually doesn't show up for a while. Usually comes on when it's raining a lot.
NewBernSI is offline   Reply With Quote
Old 07-04-2009, 09:53 AM   #8 (permalink)
cuzzybubba1's Avatar
Jason
cuzzybubba1 is offline   Reply With Quote
Old 07-04-2009, 10:08 AM   #9 (permalink)
rileyrat's Avatar
Anyone running a HFC shouldn't need the defouler. You have to consider how a defouler works, chances are the HFC+defouler are putting you back out of an acceptable range for the ECU.
Plus if the defouler wasn't done right to begin with (some require drilling) then that could again be the issue for those running a RH with a defouler.
rileyrat is offline   Reply With Quote
Old 07-04-2009, 11:29 AM   #10 (permalink)
Nick
the angled strup defouler doesnt need drilling comes all set to screw in the factory 02 bung however I beleive you to be right rileyrat its not getting a right reading so i will try taking it off and just running it without the defouler to see how that plays out thanks
Old 07-06-2009, 08:05 PM   #11 (permalink)
Talking
Well, I took off my defouler and my problem with the O2 sensor is gone. So, never use a defouler with vibrant w/ hfc.
thanks for your tips.
yoefg08 is offline   Reply With Quote
Old 07-06-2009, 08:15 PM   #12 (permalink)
Admin Ninja
obert's Avatar
obert
I think it just depends on luck,I have a random tech high flow cat with a home made defouler and have had no problems. Some other people have problems and some dont so yea its just luck.....................LOL
My Civic Feature On NW-Built
Old 07-06-2009, 09:40 PM   #13 (permalink)
DeePStr33tzOfTn's Avatar
Joey
about once a month i get a CEL because of my test pipe, i have a strup angled defouler on it. it always says "slow response secondary 02 sensor"
DeePStr33tzOfTn is offline   Reply With Quote
Where to get a angled o2 Defouler RedLineSi Bolt-Ons And All-Motor 5 05-12-2008 10:53 PM
O2 sensor bung for race header!!! Problem jsb03f Header Discussion 1 01-29-2008 04:00 PM
RT Cat install problem.....help with o2 sensor jimmychoi Bolt-Ons And All-Motor 7 06-15-2007 10:11 AM
O2 sensor removal problem...please help jimmychoi Mechanical Problems & Technical Chat 0 06-13-2007 09:30 PM
