well i got off work and tested it out. the throttle response is more crisp. in that i mean quicker accel and it just about eliminated the bogging issues we all have. it revs faster and going thru the gears you have full power right out of teh gate. i chirped 3rd like i chirp 2nd gear. as soon as you hit the next gear you have such a surge of power that you cant help but chirp no matter what you do. atleast in my car with my mods. i highly reccomend. installed was $110.00. next mod will be ? any thoughts on what mod should be next. sc will be done after i get all other mods on. i want to wait to do the sc because i wanna build teh car with all the bolt ons i can get until there is nothing left to do but sc.
Your grounding kit DID NOT improve the performance aspects of your car whatsoever.
What you are experiencing is what I like to call "phantom speed." You are fabricating all these "improvements" in your mind, and it's making you think the car is actually faster. I'm not saying you are lying, because I believe you genuinely think the car has improved. Unfortunately your brain is playing tricks on you.
Sorry to burst your bubble.
Also, you couldn't install a ground kit yourself? Really?
your grounding kit did not improve the performance aspects of your car whatsoever.
What you are experiencing is what i like to call "phantom speed." you are fabricating all these "improvements" in your mind, and it's making you think the car is actually faster. I'm not saying you are lying, because i believe you genuinely think the car has improved. Unfortunately your brain is playing tricks on you.
when your working 12-14 hr days how do you find the time
I DID INSTALL ALLL MY PARTS INDIVIDUALLY AT DIFFERENT TIMES AND DID NOTICE IMPROVEMENTS FROM ONE PART TO THE NEXT. YOU CAN BE SURE THAT WHAT IM SAYING IS ACCURATE. IM NOT A NOOB TO THE AFTERMARKET PART WORLD SO I DID NOTICE A DIFFERENCE. IF YOU ARE SKEPTIC BUY A KIT AND SEE FOR YOURSELF.
The ground kit helps the car idle smoother while improving throttle response. Overall, it improves the feeling of your car's engine - it doesn't add HP.
the ground kit helps the car idle smoother while improving throttle response. Overall, it improves the feeling of your car's engine - it doesn't add hp.
If you want to justify your $100 purchase to yourself, that's fine, but don't start saying how much difference it makes when we all know it's in your head.
I have used grounding kits before, twice, and I got them both free. One kit I won in a gymkhana event, installed it, noticed no difference in performance. The second I got for free from a friend and installed it on my old 180sx, same results.
By doing this, some noob is gonna read your post and be like "OMG! If I get these I'll be able to chirp the tires!"
every car is different. did you use it on an si? i also could chirp before the kit but now its easier to chirp. the result i seen was this: on a slow roll in 1st it accelerated slower when i floored it. it accelerated faster if i revved up. now on a slow roll it accelerates just as fast as it would if i revved up.
Well that car with "no race parts" cut 3-4 seconds off of the stock FD2R lap time at Tsukuba.
Here's the fully built 2.4:
Where's the grounding kit in there?
edit:
Look, I get it, you genuinely believe that there is a difference, if you believe that, fine, it was worth your money. But just know, these are a gimmick, ESPECIALLY on a new car, so don't go spreading around false information.
You are also the same guy who posted that his 18" cast Konig wheels with 225mm tires weighs only 40lbs. So, uh, no, I don't believe you, sorry.
Im sure this has to free up a lil bit of something since it should create a better flow through the electrical system........but maybe im wrong but im sure it does something.
Thread cleaned up. Stay on topic or infractions will be issued.
Related Threads
12M posts
157.5K members
Since 2005
