Old 08-08-2006, 02:49 AM   #1 (permalink)
Corpsman's Avatar
Hydrolock and you...
Hydrolock is:
In automotive terminology, a hydrolock is the immobilization of an engine's pistons by a liquid (usually water, hence the prefix "hydro-"). Hydrolocking occurs when liquid fills a cylinder on the intake stroke and, due to the incompressibility of a liquid, makes the compression stroke impossible. This, in turn, prevents the entire engine from turning, and can cause significant engine damage if one attempts to forcibly turn over or start the engine.
I used to drive a 2003 Nissan Spec V. I had it until I traded it in for the Si. I also had a CAI the entire time and never had an issue. Now to say that because I never had an issue nobody else will would be a huge hastey generalization. So allow me to try to set some minds at ease...
If you drive thorugh a large puddle of water and water splashes up to your filter.... You WILL NOT get hydrolock. If, however you were to stop your vehicle in a huge puddle of water, allow the filter to become completely submerged, you will get hydrolock.
Water is much denser then air, so unless the intake of air were completely occluded by water, air would still flow into the filter instead of the water. If you do not believe me, take a straw, punch a hole less approximately half the size of the open end of the straw. Place the end of the straw in liquid while the hole you just created is above the liquid.... then suck. Then you will understand.
Corpsman is offline
Old 08-08-2006, 04:07 AM   #2 (permalink)
Funny story, and I swear its true...
Guy I work with (whos a retard, but thats neither here nor there) had a CAI on his GTS. Has the bypass valve to prevent hydrolock, and it damn near flashfloods here a couple of weeks ago. Hes driving along, and hits a section of road covered in water. He figgures, Ive got the bypass valve, so just dosen't WOT it and whatever. Bypass valve works beautifully, water goes out, air goes in.
UNFORTUNATLY his bypass valve was setup about 1" from his MAF sensor, so when the water sprayed out, he shorted out all the electronics in his engine bay (=
Beacuse Im kinda a bastard, and I do love some good irony, I found this more than slightly amusing.
CMByrd is offline
Old 08-08-2006, 11:50 AM   #3 (permalink)
hoanger's Avatar
Jason
i was wondering...
i know its a COLD air intake... but would extremely cold conditions in the winter with a combination of wet snow, and all the other things related with winter affect the CAI? since it may freeze on the CAI filter?
winters here are horrible and long...
hoanger is offline
Old 08-08-2006, 05:44 PM   #4 (permalink)
CivicWithNav's Avatar
bypass valves dont work unless the filter is completely submerged in water causing pressure change.
CivicWithNav is offline
Old 08-08-2006, 06:09 PM   #5 (permalink)
i was worried about hydrolock...thats why i didnt get the intake yet. good find Corpsman, thanks for clearing it up for me.
imtim25 is offline
Old 08-08-2006, 06:20 PM   #6 (permalink)
UnDeRcOvErHiPpIcHiCk
Sleepy's Avatar
Susan
ok i have a dumb question.
What are the chances of getting a rock sucked into the intake? and inturn getting sucked into engine.
I was speaking with my honda tech and he has said that this is possiable.
Is it possiable?
Sleepy is offline
Old 08-09-2006, 12:47 AM   #7 (permalink)
I woudlnt think so, unless your runnign without a filter. Which would be pretty dumb methinks.
CMByrd is offline
Old 08-09-2006, 02:14 AM   #8 (permalink)
Corpsman's Avatar
Thank you but that was not a find. I wrote that last night after taking two Percocet. LOL, I was just amused by all the posts by people worrying about hydrolock.
Corpsman is offline
Old 08-10-2006, 10:16 PM   #9 (permalink)
stevieray's Avatar
DP Squad Member #2
Mos def a retard. The mental image of this is priceless....
stevieray is offline
Old 08-10-2006, 10:20 PM   #10 (permalink)
MaKo's Avatar
Put a Injen Hydroshield on the filter and forget about it. You won't pull any water through it.
MaKo is offline
