cleaned out my K&n typhoon filter - 8th Generation Honda Civic Forum
Go Back   8th Generation Honda Civic Forum > Honda Civic Technical > Bolt-Ons And All-Motor
Old 08-11-2008, 12:18 AM   #1 (permalink)
Michael
I just cleaned out my K&n typhoon air filter. I followed the cleaning instructions that came with my intake. I bought the K&n recharger kit to clean it out. After I install the filter back on to the tube, I just let the car sit for an hour or so. So after about an hour, I start my S.i. up and start driving around. I notice there is a bit of vibration in my gas and brake pedals when i use them. Has anyone who has a K&n typhoon intake on their fg encountered this? Right now, i'm gona let the car sit overnight and try it again in the morning.
S.i.6 is offline
Old 08-11-2008, 12:23 AM   #2 (permalink)
Demisedgabe's Avatar
Gabriel
did u reoil it? maybe to much oil?
was it fully dry?
Demisedgabe is offline   Reply With Quote
Old 08-11-2008, 12:23 AM   #3 (permalink)
FG-JOE's Avatar
Joseph
im pretty sure the filter is rubbing on the lines.
thats why i sold mine...hated the vibrations.
nothing really to worry about.
FG-JOE is offline   Reply With Quote
Old 08-11-2008, 12:24 AM   #4 (permalink)
mix
OG VIP Member
mix's Avatar
Chris
ill say it again, Oiled filters are not the best for our car. Oil is not good if a bit hits that MAF sensor
mix is offline   Reply With Quote
Old 08-11-2008, 02:18 AM   #5 (permalink)
Michael
i've had my typhoon intake for about a year now. I installed it myself. Never had any problems since then. The only issue i might of had was maybe when i took off i would hear a slight metal vibration coming from the engine bay. But when my friends are around sometimes, I would drive past them, they would tell me my intake sounds good. I'll probably loosen a few of the bolts and re-adjust the kit and see what happens then.
S.i.6 is offline   Reply With Quote
Old 08-11-2008, 02:20 AM   #6 (permalink)
Michael
what lines are you talking about?
Old 08-11-2008, 02:20 AM   #7 (permalink)
Zeuceone's Avatar
check and see if it rubs on the brake lines by the firewall
Old 08-11-2008, 02:51 AM   #8 (permalink)
my friend used a K&n oiled filter, and when he took it off to replace his intake he found oil building up in his throttle body which is probably why i would never use a K&N
Tredd is offline   Reply With Quote
Old 08-11-2008, 11:49 AM   #9 (permalink)
8thcivic Sponsor
Z1 Performance's Avatar
His problem is because the intake is not properly positioned and has nothing to do with the K&N oil.
His intake is physically rubbing the brake lines by the fluid reservoir and is transmitting that vibration to the pedals. He needs to adjust the intake tube position is all.
Also, oiled filters function just fine with our car and all MAF equipped cars. The trouble is, people often OVER-OIL them and potentially gum up their sensors. When re-oiled properly, they work just fine.
Jonathan AIM: z1auto www.z1auto.com 631-863-3820 Check out our BLOG:http://cornerbalance.wordpress.com/
Z1 Performance is offline   Reply With Quote
Old 08-12-2008, 12:08 AM   #10 (permalink)
Gabriel
K&N 69 Series Typhoon filter question ericsd241 Bolt-Ons And All-Motor 1 08-08-2008 06:38 AM
k&n typhoon filter "sock" , does anyone have it (i do>pic) ? xheartcore_boyx Bolt-Ons And All-Motor 7 07-18-2008 03:47 PM
K&N replacement filter vs. K&N typhoon intake..! new06Civic Forced Induction And Nitrous 6 03-15-2007 05:12 PM
