Old 06-26-2008, 01:03 PM   #1 (permalink)
jasonskater's Avatar
Jason
what intake to go with!?!?
im eventually going supercharged so i know i should stick with a sri or some kind of icebox intake. right now im completely stock under the hood minus the jdm dipstick and i did a crap load of research the last couple days on all of these diy intakes.
i dont want to spend a crazy amount of money.
and i dont want to mess up the AFR with fixing up a homemade intake.
any thoughts?
by the way i have an 08 fa5 if it makes a diff.
jasonskater is offline   Reply With Quote
Old 06-26-2008, 01:07 PM   #2 (permalink)
JEA86's Avatar
Jeremy
me personally i like the factory setup with a K&N drop in filter to be honest with you. It keeps the A/F ratios correct and doesnt hav ethe hesitation or lag all the aftermarket intakes give. Trsut me i have had 3 intakes and finally went back to stock (fujita, K&N, AEM cold air)
JEA86 is offline   Reply With Quote
Old 06-26-2008, 01:13 PM   #3 (permalink)
tsltd's Avatar
Hang
feel any throttle response at all?
any noise change or sounds the same as stock?
didnt really wanna get an intake also...might wanna do this up for just about what 40 bucks?
tsltd is offline   Reply With Quote
Old 06-26-2008, 01:15 PM   #4 (permalink)
Michael
I have a Fujita SRI and I highly recommend it. It sounds amazing, and you can feel it a lil on the butt dyno.
Marine0022 is offline   Reply With Quote
Old 06-26-2008, 01:26 PM   #5 (permalink)
darkrom's Avatar
Matt
Fujita!!!!! Always. I love it sooooo much. I made just about 200 WHP with my civic with just the fujita and the skunk2 70mm exhaust.
Seriously though if you look through my threads any time the Fujita is mentioned I am immediately hyping it up. I also have a wideband and constantly monitor my Air/Fuel and it keeps it perfect!
FUJITA FTW!!!!
darkrom is offline   Reply With Quote
Old 06-26-2008, 01:28 PM   #6 (permalink)
Jason
FUJITA FTW!!!!
what about the heatsoak deal?
Old 06-26-2008, 01:48 PM   #7 (permalink)
JEA86's Avatar
Jeremy
Noise Change BIG YES with an intake the car sounds SO much more aggressive. However the lag was enough for me to pull them all off. It gets annoying trying to get the car to go and it just hiccups all the way to 2-3 thousand RPM's In the upper RPM's you do gain power i will not deny that, however think about how much you are up there and how much you are down low.
Stock INTAKTE FTW
Old 06-26-2008, 01:53 PM   #8 (permalink)
Jason
Stock INTAKTE FTW
do you have the full stock setup in your car or did you take out the resonator or any of the piping?
i was thinking of doing the k&n and take out all the extra piping crap that leads to the fender..
do you think the intake resonator is making the car not hiccup in the lower rpms?
Old 06-26-2008, 01:59 PM   #9 (permalink)
mikehmike's Avatar
Michael
heatsoak will be a bit of a problem with an SRI yes, but for example I use my SI as my DD so that loss of 2-3whp between SRI and CAI isnt a big deal
mikehmike is offline   Reply With Quote
Old 06-26-2008, 01:59 PM   #10 (permalink)
darkrom's Avatar
Matt
I dunno what you are talking about to be totally honest. I have just removed the stock intake and then installed the fujita in its place. I also just have the skunk2 70mm. No header and still using the cat. Nothing special just intake and exhaust combo got me 200 WHP :)
Heat soak will happen in any SRI, but honestly I don't notice it at all. Besides its better than CAI lag in my opinion. It definitely beats hydrolocking your engine in everyone's opinion
Old 06-26-2008, 02:02 PM   #11 (permalink)
Jason
i didnt quote you i quoted jae86.
Old 06-26-2008, 04:34 PM   #12 (permalink)
JEA86's Avatar
Jeremy
i have taken out the resonator box only, i left the piping leading to the resonator because it draws cooler denser air from down in the front bumper.
Yes i think that is a good idea to do a K&N drop in and take out the resonator only and the pipe leading to the fender. But leave the pipe in that connects to the resonator.
No the resonator creates a bottleneck in the airflow and only really is there for tuning the sound of the intake. Does removing the resonator add power.. that i dont know, but i know i have no lag
Old 06-26-2008, 05:38 PM   #13 (permalink)
slow4drsi's Avatar
200whp without header , wow your dyno is very generous . do you have a baseline run?
slow4drsi is offline   Reply With Quote
Old 06-26-2008, 05:42 PM   #14 (permalink)
tsltd's Avatar
Hang
^ maybe he forgot to mention reflash?
Old 06-26-2008, 05:49 PM   #15 (permalink)
slow4drsi's Avatar
reflash won't affect the peak whp.
Old 06-26-2008, 05:55 PM   #16 (permalink)
Mr. Cowl Induction
NitrousG35's Avatar
Wild VTEC'n Bill
For my part, I would go with a CR-V intake tube, Soxfan143 housing, [unless you run a stock exhaust, so you could just section out a stock Si housing] and an Apexi or Fujita cone filter. Soxfan143 sells his own stands that are very sturdy and will keep your intake in place.
Old 06-26-2008, 06:00 PM   #17 (permalink)
darkrom's Avatar
Matt
I do not have a baseline run. I am gunna get it dyno'd somewhere else just for shits and giggles at a different place.
Old 06-26-2008, 10:51 PM   #18 (permalink)
kbeeveer46's Avatar
Kyle
Stock INTAKTE FTW
I'm also looking at getting an intake. Can anyone explain this "lag" and "hiccup" problem? Is it pointless to get an intake if you're only looking for sound and performance isn't a huge deal?
kbeeveer46 is offline   Reply With Quote
Old 06-26-2008, 10:55 PM   #19 (permalink)
Lan Evo VIII's Avatar
Anthony
I did the homemade ice box with a K&N Drop-In filter, and love it.
Lan Evo VIII is offline   Reply With Quote
Old 06-27-2008, 03:14 AM   #20 (permalink)
Asif22's Avatar
Mohamed El-Mubaslat
Injen Cai ftw
Asif22 is offline   Reply With Quote
Stock Intake System vs Short Ram Intake ProspeedCTR Bolt-Ons And All-Motor 272 10-08-2008 10:18 PM
X Intake or A'PEXi Power Intake Filter owners Si Speed 317 Bolt-Ons And All-Motor 4 03-24-2008 06:49 PM
Weapon-R Needs Volunteer Si for Intake Prototype - Free Intake enter801 Bolt-Ons And All-Motor 19 11-29-2006 01:43 PM
Help Intake info needed----Dose a Intake Kill your warty? coach2fast Bolt-Ons And All-Motor 8 06-23-2006 02:51 AM
