#23 (permalink) |
Yes, it's only 12 volts but it's not the voltage that kills you. It's the amperage. Amps can be calculated using E (voltage) / R (Resistance). So if you have 12 Volts and a ring with say 1 Ohm of resistance, 12/1 = 12 Amps. 1/10 of an amp is enough to kill somebody. Don't get me wrong the voltage hurts but it's not what kills you. Luckely the person that I saw with the ring only lost his finger and not his life.
#27 (permalink) | |
If you start by removing the positive terminal with a metal tool, and that tool accidentally hits any metal part of the car (which is ground and still connected to the negative terminal).... fireworks! But if you start with the negative pole first, even if your tool touches the chassis or engine, it won't cause a short. With the negative terminal removed, you can safely work on the positive terminal without fear of shorting it with the chassis or engine. Of course, you still need to be mindful as to not short the battery terminals, especially if the tool you're using is long enough to reach both poles. |
#29 (permalink) | |
Touching the negative battery terminal isn't very different electrically than touching any metal of the car. |
#32 (permalink) |
Ok, here is automotive batteries for dummies.
Remove all jewelry before beginning work. When you need to disconnect the batteries you should first disconnect the negative side(black), then the positive side(red). Chance of shock is greatly reduced in this manner. Any time you work with electricity you should be mindful of metal on metal contact. Your car battery can but probably won't kill you. |
#33 (permalink) |
If you instal a CAI you have to take the battery out....so follow the above recs.
other than that dont bother.When I instaled my CAI that was the only time I did the battery thing it was my first mod.After that and meny meny bolt ons never did it again. I pullen 206 hp |
| CEL - Reset ECU? | FBP_Si | Mechanical Problems & Technical Chat | 3 | 11-06-2007 03:25 PM |
| reset ecu | BiggJ12 | Bolt-Ons And All-Motor | 3 | 09-04-2007 02:30 PM |
| ecu reset | kene79 | Bolt-Ons And All-Motor | 6 | 08-16-2007 03:40 PM |
| ECU Reset, when and why?! | amirh | Mechanical Problems & Technical Chat | 16 | 01-30-2007 08:43 PM |
| Is There A Way To Reset Rep? | P4rD0nM3 | 8thcivic.com Site Questions/ Problems | 14 | 01-03-2007 01:11 AM |
