PLEASE HELP GUYS!!! Searched google and 8th civic but didn't get any solid results or suggestions on this. So here's my question...
My friend's 06 civic dx coupe's front left suspension is squeaking almost whenever it goes over bumps or rough surfaces. The noise started couple weeks ago, but the noise has been becoming more and more obvious. Not sure if that's because the weather is getting colder or the problem is getting more severe as time goes on. Some fellows on 8th civic have their struts/shocks replaced but still have the squeaking noise...The unfortunate part is "shocks, struts and dampers" is under warranty for only 3 years and has already expired for an 06 civic... So reluctant to get stealership to do inspection for $100+ and likely not solving the problem...Please throw out some ideas... THANKS!!! |
Patrick
sounds like it needs some greasing or something may be bent and its making contact with the rotors...but again, it could be another problem, best bet is to bring it the dealership and have them check it out...
#5 (permalink) | |
Thanks! |
Patrick
Did you buy the car off honda?? if so, you should try bringing it back since its under warranty.. and you are running on stocks right? no mods?? if its under warranty you should be fine and you can ask them if they will charge you for inspection but most likely not
#10 (permalink) | |
I am surprised that newer Honda don't seem to be as reliable as the earlier models |
#14 (permalink) | |
I'd give a dealer a call and ask how much it will be and be nice about it and they might do something for you. Better yet call the dealer you bought the car from they might be more willing to do an inspection for a lower cost/free. |
#15 (permalink) |
if you're in richmond, go to minit-tune across from aberdeen. the owner there has always been very nice and explains fully what the problems are and even shows you. there's also a mini window where u can keep an eye on everything they're doing on your car. unless you wanna watch from outside where it's -5 and below these days.
ask for jackson |
#18 (permalink) |
So I bought a silicone grease and sprayed the bushing at the front sway bar and the bushing somewhere near the CV boot (not sure what it's called) and it didn't help. I didn't loosen up the screws to spray the interior of the bushing, only sprayed from the outside with everything mounted, and hope that the grease would leak into the interior.
Still got the noise, when temperature gets colder, the squeaking noise is more obvious. Help help! By the way, called the Honda stealership and they'll charge $120+ just to do inspection... |
#19 (permalink) |
Updated some experience in dealing with the dealership and Honda Canada!!! See the link below.
Honda Canada Dealership Rip Off - Front Suspension Noise |
#20 (permalink) |
Mine does that too. I brought it to Richmond Honda and they didn't find out why it does that. One of senior techs drove my car with me and he heard the sound. Well at least they replaced both rear shocks under warranty as they were leaking.
| Front Suspension Squeaking noise | snoogle | Suspension and Brakes | 107 | 01-25-2013 07:23 PM |
| Squeaking in front suspension! PLEASE HELP! | yah yah | Suspension and Brakes | 5 | 11-08-2010 09:55 AM |
| front right suspension CLICK when turning left up or down an incline? | s2k600rr | Mechanical Problems & Technical Chat | 0 | 04-16-2010 09:34 AM |
| Sedan, rattle on the left front, near suspension | leonsphinx | Mechanical Problems & Technical Chat | 3 | 10-17-2006 08:40 AM |
