Hey Guys,
The guys finally had a decent night out and decided to take the Si to moroso for some shakedown runs. The Car was taken as-is to give it some runs to work out any bugs in the system. The car was kept at Low Boost/Street Tires (40psi) the car delivered a 13.9@106. The Boost Controller Came alittle loose so the guys decided not to go into higher range for now until they could lock the Controller in tightly and maybe get different tires on the car. pics and videos should be up shortly. |
#2 (permalink) | |
Bat-Wing
Yea it does seem slow, I've seen people run 14.3 ¼ mile with only bolt ons like instake, header and exhaust.
My Ride: http://www.8thcivic.com/forums/showthread.php?t=9677 |
#5 (permalink) | |
#6 (permalink) | |
#7 (permalink) | |
So you're saying that it was a bad driver? And really, whats the lowest boost you have ever seen a wastegate run? Lowest I have every seen was 4.5 psi (and nothing usually comes that low unless you order it that way). |
#8 (permalink) | |
Bat-Wing
This 06 Civic Si ran 14.113 @ 98.03 Here is the link where I saw it posted. http://www.honda-tech.com/zerothread/1648886
3-7 psi is a big difference on a 60-1... I ran a t70(which is a bit bigger) and made 20whp on each lb till 20psi... BTW the lowest I've seen is 3lbs...
Im not saying it was a bad driver, I would just like to see the 60's and 1/8 #'s... He could've been spining alot.. |
#10 (permalink) | |
#11 (permalink) |
Bat-Wing
Well that said his launch off the line must have sucked really bad. I would think the Civic with a turbo could be running high 12’s easy.
#12 (permalink) | |
#14 (permalink) | |
#18 (permalink) |
14.1 @ 98 means the driver is great at launching and has no traction issues and will romp on you for the first 1/8th mile or so
13.9 @ 106 means the driver is having crazy traction issues and after the first 1/8th mile the car once it grabs pavement will fly by the other Civic. |
#19 (permalink) |
Moderator
just called.
listen to all talking about the 14.1 time it was 75 outside in the north. the guy powershifted the guy had his tire pressure at below 20 psi... his 60' was like 2.1 another person ran 14.1 with a 60' of like 1.9..call it 2with drag radials intake, header and exhaust.... South florida temp last night was atleast 88 and humid as hell all jap tire pressure was 40 psi (street tires i was told)...i know they have a set of falken azenis on hfp 18s...don't know if they used that...regardless 40psi is shitty for a drag race. boost was set at 4psi stock cat still in place stock exhaust in place 60' was 2.4 trap was 107mph 1/4 was 13.9 removal of cat + addition of catback exhaust = more power = higher trap = lower time now tell me... with drag radials OR deflated tires of a lower psi....will u not drop ur 60' by a lot? thus increasing trap + reducing 1/4 time? boost was @ 4psi....regularly it's at 7psi... that makes for an even bigger drop in time. i say that car hit 12s easilly with a lower 60' and better tires/tire pressure with 7psi....and low 13s by just improving the 60' with 4psi setting and better tire pressure. who would disagree? who has more to add?
Shift when it blinks! http://www.cardomain.com/ride/2640940 FA5 http://www.cardomain.com/ride/2216565 FG2 Last edited by sickyute; 06-22-2006 at 01:25 PM. |
| Dumb Laws | C2i0v0i1c | Water Cooler | 58 | 10-03-2008 09:27 AM |
| China to bring cars to US | webby | Garage | 66 | 09-26-2007 11:02 AM |
| Sout Florida, Boosted Si, Moroso, tonight. | sickyute | South | 7 | 06-22-2006 02:41 PM |
| GM vs. The New York Times | CameronJr9 | Water Cooler | 30 | 06-15-2006 09:46 PM |
| New to this site, hello! (pics of my cars) | SonicK20Z | Introduction & Pictures | 16 | 06-09-2006 12:30 AM |
