Old 05-03-2008, 02:53 AM   #21 (permalink)
Originally Posted by 07_FG_4Dr_S.i. View Post
Not really sure what you mean by less gear and more weight , and how would i go along finding out what is the least tire i can get away with ? Would a 16"wheel be fine or should i stick to 17"
Rota slip stream 16" weighs at 14lbs....
This thread is turning out to be one of the most serious drag racing threads on this board, especially with Matauz, who seems on point, weighing in.
What I mean by less gear is that a smaller overall diameter tire will result in a numerically higher gear ratio. This i what is commonly referred to as more gear. The car will get higher in the revs faster with more gear. In most manual transmission cars you want as much gear as you can run to get through the traps in 4th. For what it is worth, most quick manual transmission 4th gen camaros and firebirds run 5:13 rear gears with a 28" tall tire. Since we cannot cheaply change our gears, it makes sense to me to put the smallest tire with the most traction on the car.
You would go along finding out what tire is best with an educated guess and testing. I would run the smallest possible rim so that you have the most sidewall. A 225 tire is the same diameter on any size rim. So if you run it on a 16" rim, you have that much more sidewall offering that much more straightline traction.
A bigger tire is heavier. There is a rumor that rotating weight magnifies something like 4 times when it is rotating weight. From this, evrey pound of tire, rim, brake rotor, axle, and driveshaft should be taken seriously.
On our cars at their current naturally aspirated speeds, every 100 pound is worth roughly a tenth of a second in the quarter mile.
mike07si is offline
Old 05-03-2008, 06:14 AM   #22 (permalink)
ImAuthenticFTW's Avatar
Mike Wagner
[quote=Matauz;2743907]
This is a must for 60's :P
/QUOTE]
and this is on stock tires......id suggest against this on those. You do know street tires are made to NOT heat up.....by doing a burnout all your doing is wasting miles off the life of your tires.....
ImAuthenticFTW is offline
Old 05-03-2008, 06:17 AM   #23 (permalink)
phoenixdrago12's Avatar
^ I learned something new today..
so heat doesn't affect drag tires as much as they affect street tires?
what I mean is.. do drag tires burn less rubber, doing burnouts, than street tires?
phoenixdrago12 is offline
Old 05-03-2008, 01:52 PM   #24 (permalink)
Matauz's Avatar
Matt Da Silva
[quote=ImAuthenticFTW;2748627]
/QUOTE]
First Im not worried about wearing out my tires lol I will just buy some more. Second I was pulling 2.2 60's all day until I started doing the full out burnouts then hitting the 2.1's on stock tires. I have heard this so many times before that it doesnt do anything but I disagree. Any car with crappy radials doing good times is doing a burnout are they not ;P? In my opinion it helped my 60 foot so I will keep doing it and my results show it :)
Matauz is offline
Old 05-03-2008, 03:52 PM   #25 (permalink)
Mike Wagner
to a point, but at the same time another factor is that the concrete on the burnout box will wear your tires more as well.
Old 05-03-2008, 10:51 PM   #26 (permalink)
07_FG_4Dr_S.i.'s Avatar
Jason
So I'm going with 2 16" 14lb rotas, and not completly sure which nitto's to get the 555r's? Or the NT01's
NT01's look like a nice serious tire
245/50/16 is only size I saw available on discount tire website is that good size? Any other site or would another tire size be much more optimal
07_FG_4Dr_S.i. is offline
Old 05-03-2008, 11:13 PM   #27 (permalink)
Jason
Talking
[quote=Matauz;2749607]
^^^^ heard that heating up stockies is pointless so I asked a Honda tech who has a 3 fully built race cars blabla point is he's been racing for over 30years street and track so I thought his answer on that idea should count LOL he said any tire creating friction on the road heating up should make some improvment opposed to not warming up before a run
Enough of an answer for me lawl so I warm my stockies up before a run
Old 05-03-2008, 11:33 PM   #28 (permalink)
udumkid's Avatar
Rene....
555'rs = Drag Racing
NT01's = Road course.....
udumkid is offline
Old 05-04-2008, 02:16 AM   #29 (permalink)
Jason
hmmm didnt know...01's looked more like a slick that's what I figured
Old 05-04-2008, 02:39 AM   #30 (permalink)
Jason
Post
since the 555r's are for drag racing I saw them 245/50/16 for 134$each should I go with these?
Drag Radials...ummm 90b16ed Autocross & Sanctioned Drag Racing 2 04-04-2008 06:14 AM
anyone running drag radials?? hawjdude Wheel And Tire Upgrades 16 03-31-2008 12:34 PM
Should i get drag radials for the SI tvmendoza Wheel And Tire Upgrades 10 02-19-2008 08:06 PM
Rota Slips & BFG Drag Radials SC06SI4U2NV Wheel And Tire Upgrades 7 04-15-2007 12:17 AM
