#21 (permalink) | |
![]() Join Date: Jun 2006
captain obvious
http://iamnotabookofanswers.blogspot.com |
#23 (permalink) |
Just went at streets again yesterday with ACRA
Also had my new alignment and turns out that I have -2.5 neg on front. and -3 on the rear. Took tire temps on the front was good 140-160 all even across But the rear was bad outside was 80 middle was 90 and inside was 119 all that with -3 neg on the rear. I will be ordering the SPC kit that takes -1.25 degree maximum out I guess, I will settle for -1.75 on the rear. |
#24 (permalink) |
Not a bad time :). I will be doing some testing with my FA5 at streets once i get some tires that can hold up to heat better than the stock michelins.
Your tire temp in the front sounds very typical for a front wheel drive car. Can't really comment on anything else unless we have some data + video but keep up the good work. |
#25 (permalink) | |
Great!!! ... once you get the tire temps optimised by getting your camber right, you know that you have got your contact patchs close to optimised. To help initial turn in, you can play a bit with front Toe out to get the response you are looking for. How low are you on the C/O's ... anything below 1" of drop and the roll centers start to get funky ... beyond 1.5" they pretty much go below-ground. You have to go nuts and compensate with high spring rates to keep the roll moments minimised. I would reccommend that you get the car corner balanced ... this will allow you to better analyse what is happening (from a handeling perspective) as the car will respond evenly and repeatbly under all conditions (RH / LH corner Braking / Accelerating) This will help you make educated decisions on what next in the setup needs to be addressed in each stage of the corner (Entry / Mid / Exit) You can then start to look at Spring rates, spring rate stagger (F/R), swaybar sizes and stagger, and Damping to tune the transitional and steady state charateristics thru all stages of a corner. Moose Last edited by Moose; 04-11-2008 at 08:10 AM. |
| feb 9or10 streets of willow anyone? | fg2!kid | California South | 65 | 02-12-2008 01:37 AM |
| Streets of Willow, antelope valley, ca. | METALLICO | 8thcivic.com Site Questions/ Problems | 0 | 12-09-2007 05:30 AM |
| SpeedVentures Streets of Willow May 12-13 | MikeColangelo | Autocross & Sanctioned Drag Racing | 4 | 05-18-2007 04:32 PM |
| may 13th streets of willow springs track day | eugenekim.net | California South | 1 | 05-03-2007 10:24 PM |
| march 2nd... streets of willow | eugenekim.net | California | 4 | 03-03-2007 12:14 AM |
