Old 03-23-2008, 10:51 PM   #41 (permalink)
inyong1988's Avatar
Junction Produce
Originally Posted by I Vtec, do you? View Post
I don't really consider any of your mods anything more than minor except the RH, which would be a moderate mod to me. Putting an intake on your car isn't all that wild imo. Good numbers, I just don't see 13s out of the SI. 13s is somewhat fast, and the SI doesn't feel somewhat fast to me. Maybe a RH really opens it up
inyong1988 is offline
Old 03-23-2008, 11:00 PM   #42 (permalink)
Neal
I really don't see the reflash making that big of a difference, Im only not in vtec for one gear. The drag radials are the big helper with these runs. I mean I ran 14.5 with i/rh and just the spare out on stock Michelins. You had the backseat out too which saved probably at least 50 lbs, I'm not sure if you have a FG or FA, if FG then you are at least 110lbs lighter than me. I just feel like with drag radials I could run times very close to these. I'm not saying they aren't great times, just people are comparing these runs to runs on stock tires or better street tires.
nbilyue is offline
Old 03-23-2008, 11:07 PM   #43 (permalink)
udumkid's Avatar
Rene....
when you said minor mods I thought you meant of me having an intake or intake and exhaust.... The car has dynoed well over 205WHP Sae corrected on a dyno jet, there was a meet last sunday at the track that plenty of members saw how different my car pulled compare to that of a person w/ just intake and exhaust which they were runnig 14.9@ 97mph to my 14.0@102mph...so maybe the RH did made that much of a difference.. Sorry that you feel that your car is not fast, maybe a couple of mods might change your mind....
udumkid is offline
Old 03-23-2008, 11:09 PM   #44 (permalink)
udumkid's Avatar
Rene....
Correct... the et tells you how good you got off the line... the 1/4 mph tells you how fast the car is.
so what was you MPH in the 1/4??
Tell you what pay for my gas and entrance on the richmond meet at the track...if you do, I will let you use the drag radials..
udumkid is offline
Old 03-23-2008, 11:56 PM   #45 (permalink)
hawjdude's Avatar
raceheader does wonders for a motor. it essentially is the only mod that when done, you can feel some hp gains (dyno proves this as well). to run high 13s all motor is fast but not impossible, rsx and other k20 cars w/ basic bolt ons, have been doing this for the longest time (in addition, im sure there are a couple SI guys doing it out there as well).
hawjdude is offline
Old 03-24-2008, 12:01 AM   #46 (permalink)
hawjdude's Avatar
Originally Posted by udumkid View Post
wheel hop was at a minimum due to the drag radials + I rode the clutch out.
to the op, did you try to launch at the limiter ( 5500rpm) at all to see if you could get any better times??? also, how far did you take first gear (redline)? did you have to ride first gear in redline a bit before you could get full traction ( as you can see, i haven't taken my car to the drags yet, only street experience)??
hawjdude is offline
Old 03-24-2008, 12:04 AM   #47 (permalink)
Nexx's Avatar
I'm glad the DCRH is doing so well with the smaller collector. My buddies BCRH equipped SI feels no different from my DCRH yet he swears the extra .6" or however much bigger the BCRH is, will pulverize my car at high end. Whether the extra $400 for the BCRH is worth it or not, in terms of price vs performance, there is no doubt that the DCRH is the best bang for the buck header out there for a basic bolt-on setup.
The only thing that's been bothering me is the gas smell. Driving me crazy.
Nexx is offline
Old 03-24-2008, 12:11 AM   #48 (permalink)
hmmmz...
bizzybearfigiblue's Avatar
Roberto
well maybe with the minimal mods on his car this is true... but it's already proven that the BC makes wayy more than the DC... my friend had his FG2 supercharged... his dyno with DC = almost 260whp... now with BC = 275whp+ same everything but the header...
i'd say out of the OPs whole setup the DC header is hurting him...
in case u don't know... http://www.8thcivic.com/forums/intro...-pix-here.html
For today's Entrepreneur... http://www.8thcivic.com/forums/group.php?groupid=48
Your spot for 8th's youtubers... http://www.8thcivic.com/forums/group.php?groupid=49
bizzybearfigiblue is offline
Old 03-24-2008, 12:17 AM   #49 (permalink)
hawjdude's Avatar
the bolded statment hasn't been proven to my knowledge yet w/ basic bolt on SI's. maybe so for that particular setup (SC) but none i've seen yet w/ NA setups. i agree that w/ more extensive setups (aggressive NA, or SC) that the DC may hinder max power but in terms bang for buck and simple NA setups, DC should be the rh of choice.
hawjdude is offline
Old 03-24-2008, 12:23 AM   #50 (permalink)
hmmmz...
Roberto
glad we agree... except for the bang for buck part... b/c i only feel that if i'm gonna put a part on my car i only want to put the best from the beginning... that's my prerogative tho...
the P2R TBS/TBG combo gives the best bang for buck... if u want to be technical...
Old 03-24-2008, 12:28 AM   #51 (permalink)
Drop Babies not Bombs
Demisedgabe's Avatar
Gabriel
very good times.
Demisedgabe is offline
Old 03-24-2008, 01:42 AM   #52 (permalink)
Nexx's Avatar
....in terms of price vs performance, there is no doubt that the DCRH is the best bang for the buck header out there for a basic bolt-on setup.
:P Just wanted to make sure I wrote the basic bolt-on part the first time around. Obviously the 1.8~1.9" DCRH collector will hamper the system as more high-end mods are added.
Nexx is offline
Old 03-24-2008, 01:52 AM   #53 (permalink)
SoCal07Si's Avatar
Just call me Daddy
real nice times, congrats man
SoCal07Si is offline
Old 03-24-2008, 07:21 AM   #54 (permalink)
Bboy_Burst's Avatar
13.8@103MPH N/A
nice times, you've enter the 13 second boundary. any car that can trap 100mph+ is consider fast in my opinion. once i get my bc header, maybe i can get in the 13s.
Bboy_Burst is offline
Old 03-24-2008, 07:52 AM   #55 (permalink)
20strong's Avatar
Marcus
Whaat type of MPG's do you get on an average tank of gas with you mods?
20strong is offline
Old 03-24-2008, 08:17 AM   #56 (permalink)
Neal
I'll be S/C by then, but I am excited about the meet and seeing you run. I'll be interested to see how everyone's cars do at Richmond. The best I have run there is a 14.7 @ I think 98 and I am the fastest Si I have seen there. Anubis will tell you it is a horrible track, so I'll be curious to see what others do. Really Rene I am not knocking you, from just reading through the post I felt like a lot of people didn't realize you were on drag radials. I look forwarding to meeting you and am glad my intake is doing better on your car.
nbilyue is offline
Old 03-24-2008, 11:18 AM   #57 (permalink)
the op's trap speed is really indicative of the power those mods gave you...really good stuff. I am sure it restores some faith in our cars ability to get down the 1320 quickly without spending a fortune. Excellent times
adamk20 is offline
Old 03-24-2008, 07:46 PM   #58 (permalink)
udumkid's Avatar
Rene....
For Na the DCRH is great, for FI...well havent tried it yet..here is a Dyno that you can compare the DC vs BC Raceheader:
WhiteSicivic06 w/BCRH
My Car w/ DCRH
Both cars had the same set up,Dynoed the same day on the same dyno jet dyno. Except that the car w/ the BCRH had NST pulley set..
udumkid is offline
Old 03-24-2008, 07:59 PM   #59 (permalink)
8yourv8's Avatar
nice #s
8yourv8 is offline
Old 03-24-2008, 08:08 PM   #60 (permalink)
caveman74's Avatar
Kevin
BCRH isnt all that. DC is proven to be just as good and less than half of the price.
